KodiakStar
/'s by 0
- Dec 13, 2004
skudmunky said:wow, that is WAY gettoer than mine. Mine uses Real Metal Screws to hold it in place!
3.5 foodstamps.
g[H]ettoer?
3.5 foodstamps.
aohellasux said:![]()
This is my pc is a cardboard box... finally got to use my 120mm Delta fan. My system runs nice and cool in its new home.
JL_Audio_User said:Simple and effective......and ghetto.
4.2 foodstamps
ikellensbro said:4.2 foodstamps + 0.3 for watching Family Guy & the Penny Arcade sticker, - 0.1for using metal screws = 4.4 foodstamps
those are the z-560s, i believe.Lawler said:no subtraction for having those awesome Logitech z5500[?]'s lol![]()
and i totally don't blame youaohellasux said:![]()
sorry, forgot the model number. logitechs removed it from their site, as has newegg. thanks for clearing that up!SolidFeather said:Z-680
aohellasux said:Actually, I was watching Dilbert, just FYI. And the cardboard box is great, my pc is running 5 to 10 degress (F) cooler in it.
sabrewolf732 said:hey, what keyboard do you use?
Ah, I was too eager to see someone else watching Family Guy, but Dilbert was and still is just as genius.aohellasux said:Actually, I was watching Dilbert, just FYI.
Maybe add another 0.1, for pure laziness by using WMP, instead of another program that you would actually have to download & install to useknaSen said:No foodstamps for using Windows Media Player?![]()
ikellensbro said:Maybe add another 0.1, for pure laziness by using WMP, instead of another program that you would actually have to download & install to use![]()
TSS Modder said:sorry, forgot the model number. logitechs removed it from their site, as has newegg. thanks for clearing that up!![]()
JL_Audio_User said:Actualy WMP should be a mandatory .02 DEDUCTION...for being a hogging unreal piece of shit.
One Ghetto creed is not being lazy....Its being smart with what you've got.
NOOO - now all the cold will get stuck in the PSU and not fall to the CPU!!!! Errror Error ErrorDlStreamnet said:![]()
had to turn my pc upside down because the internals faced right instead of left which i wanted
ghettoist mod i've ever done!!!
theshadow27 said:meet: the super cooled IceMat
HAHAHAtheshadow27 said:ghetto bandaid:
Daggah said:Sorry, JL_Audio_User, that fan controller mod is actually pretty cool...too cool to be ghetto.
Um, in my old computer a few years ago, I mounted a 92mm fan to the front of my computer. Only thing was, the screwholes were for an 80mm fan. So I screwed the fan in with one screw and secured the other three corners of the fan with sticky tack (you know, the stuff you use to put posters up on a wall.) I also drew some kanji on the right side panel...with a magic marker.
Still can't believe I did that.
In my current case, the only thing I've done ghetto was using electrical tape in place of heatshrink after sleeving a fan's power cable and a fan extension cable. Just haven't gotten around to opening the case up and replacing it with proper heatshrink.
Decius said:This is mine, it's my room-mates system. We upgraded his POS computer with some old old parts of mine. Basically a Duron 700 to Athlon T-Bird 1GHz, some more RAM, and a GeForce4 Ti4600. Anyhow his crappy case doesn't have sufficient cooling. Basically just one 60mm fan in front and the same in back. Our solution....well check out the picture.
