Woot! I made the front page with my ghetto cardboard fan holder colored with sharpie.![]()
I have been using a rez that looks very similar. Nice mod.
I ran into a snag fitting enough power into an mATX case to power my pair of GTX 480s last year and I ran out of time to get the machine ready for a LAN I was attending. This is the result, enjoy
*Bunch of BORKED pix*
Pizhihong, your pix need to be rehosted. All we see are the ChipHell lego men brigade.
How about this one.
Made it in 2 hours![]()
Sorry, don't have the inside pics.
Hehe, my old PC
http://imageshack.us/f/5/dscf0002vr.jpg/ was the outside
http://imageshack.us/f/687/dscf0005bj.jpg/ was the inside, yes that's a container of dental floss holding up the videocard for support to keep it from flexing
Phenom II 1090t, Gigabyte MA-770 UD3 mobo, 4x2GB 1066mhz OCZ Reaper ram, 6 hard drives, 4 internal 2 external for 4TB of space, DVD drive, Corsair 750TX power supply, Radeon 5850 with Aftermarket Arctic Accelero V2 with 2 Antec 80mm fans attached to cool it, both of which are attached to the heatsink via twist ties
behold the old world craftsmanship oh wait...ambitious but rubbish
meh it is alright i guess... it was sort of a mess trying to build it...took awhile and I nearly threw it out at one point. i learned things... like don't buy pine or more notably don't try to stain pine as it sucks... i also learned don't leave pine shelf to dry out in the hot socal sun (as the heat made sap come out.. this is when i was going to toss it..but i cleaned it off with some mineral spirits and put another coat on then brought it into the garage to dry and no more sap issue so far sooooo yeah).
but it works i guess.
Uploaded with ImageShack.us
Not the most ghetto mod out there but after having installed my Accelero Twin Turbo onto my 5850 and finding out the fans were no longer functional, I decided to slap on 2 120mm fans. Zip ties are like the duct tape of the computer world.
Okay, first, this is my arm/elbow padding for extended comfort during extended gaming/studying/working sessions. the pads are those intended for use with toddlers so they dont get hurt while bumping all the tables. got the idea because of my toddler and because the table edge was rather sharp lol![]()
And this, when the main crossfire card started to overheat because of Texas weather i grabbed my Dremel, tool set, double sided foam tape and took a trip to fry's... the rest is 30°C cooler at full load
Eggshell removed
Position of cooling device attached with sticky tape
The improved cooling device with trimmed intake and exhaust for noise reduction and better airflow
Not sure if this qualifies, but I converted an old shelf unit to a standup desk...
added some caster to roll it, used velcro to attack a light for the desktop area, and a whole mess of electric tape to hide wires.
added some caster to roll it, used velcro to attack a light for the desktop area, and a whole mess of electric tape to hide wires.[/quote]
I wouldn't call that too ghetto from the angle, even though the tower is flat, but that's a cool mod nonetheless.
I can't actually tell what you've attempted there... it looks like (especially on the left) you just took a random object and taped it to the desk for decoration, which is pretty funny in and of itself.
the cardboard taped on the table are to raise the back of the keyboard just enough to clear the base of the monitor and allow for a better angle on the keyboard.you see, the keyboard legs stand on the taped cardboard, i had to move the keyboard down to allow vision of such aesome table mod... lol
