Unknown-One said:I have one of those Linksys USB Wireless (802.11B) Network Adapter's, and I've had no end of problems with it. You know the one I mean, its a little black and blue box you plug in via USB so you can connect to a wireless access point...
It was dropping my connection every 5 seconds and just generaly pissing me off. Turns out, this little box is overheating. Well, it isn't now![]()
Quick tutorial to getting a "WUSB11 ver 2.6" to sub zero:
1) Crack open the case and pull out the board inside.
2) Smother the board in thermal grease.
3) Put the whole mess into a sandwich bag.
4) Pop holes for, and run the antenna and USB cable through the bag (zip tie around them to make it air tight!)
5) Set the bag onto a salt water soaked cloth.
6) Fold the cloth over the bag once.
7) Add some cubes of ice to both sides of the card, then wrap the cloth around one more time to seal them in.
8) Put the whole thing into another sandwich bag so it wont make a mess.
9) Plug it in and prey that it still works.
Yes, it actualy works. I'm using it that way right now...allthough changing out the ice every 8 or so hours is going to suck![]()
The thread title is "Post your 'Ghetto Mod' pics" not "Post your 'Ghetto Mod' descriptions"Unknown-One said:I have one of those Linksys USB Wireless (802.11B) Network Adapter's, and I've had no end of problems with it. You know the one I mean, its a little black and blue box you plug in via USB so you can connect to a wireless access point...
You want a pic of a bag stuffed with a wet rag, with a USB cable and antena sticking out of it?ChingChang said:The thread title is "Post your 'Ghetto Mod' pics" not "Post your 'Ghetto Mod' descriptions"
Oh yea, how many food stamps did I just rack up?joemama said:...Not even worth one foodstamp![]()
I'd go with internal personally....Unknown-One said:I'll probobly just buy a new one...any suggestions?
NO LINKSYS CRAP!
nice setup you've got there, I see you went for the gallon sized bagreins said:Thanks for the heads up on that solution unknown-one, I had the same problem. I've been doing this for about a week now and connection is rock solid. Not the same design but it works just as well.
*image snipped*
fam said:Im guessing I win the gheto mod for duct tape!
Is it just to redirect the warm air to warm your feet or what?
