lil layzie
- Jan 7, 2004
Does anyone on this forum have this board yet? I know it's a little early but if you got the board, please post your results.
AMD T-type said:Why you make me think about it again
Mine will be in my machine Monday
will let you know
240fsb and no mention in your profile of the type of memory you're using.AMD T-type said:set her to 240fsb @ 1.55v and she's running good so far
Gundamit said:240fsb and no mention in your profile of the type of memory you're using.
Got my mobo today. Won't have a chance to play with it until the weekend. I have my Adata PC4200 waiting to go in there. My goal is 250x10.
oopsie. Missed that. heh.PureBooYah said:he's got it in there... 2 x 512MB KHX PC3000, bh-5
xcoldricex said:anyone getting a chipset fan for theirs? if so which one? (anandtech was saying how the chipset heatsink was running really hot... and that they might have gotten better overclocks swapping out the heatsink).
also what hsf combos will you guys be using?
Anantech did a 754 "roundup" BTW- Is it a roundup with only 3 mobos? Anyway, its the first time I've seen time I've seen anyone try the 1.5CAS setting. They ran it 1.5-2-2-10 with some OCZ. But they didn't post any test results at those timing. I wonder if anyone with some low latency could give it a try and post the results. I'll give it a try with my HyperX PC3000 and Mushkin Promo 2-2-2 after I finish with my Adata.
AMD T-type said:as my roomate said, I do have it in my sig, the same KHX3000 you have
I have my vdimm set at 3.1V and the memory is running 2-3-2-10
not bad for some $170 memory
as it turns out though, the highest i can run the HTT clock is 240 MHz, anything beyond that the external SATA ports don't work (ports 1 and 2 on lower part of the board), and this goes for all the boards
The board does go higher stable but i have 3 SATA hard drives so unfortunately i have to stay at 2.4GHz for the time being until they fix the problem
c'mon people, get those boards running and post some results !!!
Gundamit said:Anantech did a 754 "roundup" BTW- Is it a roundup with only 3 mobos?
only got mine 2 days ago, with my AMD64 3400+ Newcastle which did 2660mhz (10x 266mhz 2-2-2-6 1T) on AN50R, my first oc (just testing) at 10x 240HTT 2-2-2-6 at 1T at 3.0v vdimm with vcore, vAGP, vChipset all AUTOlil layzie said:Does anyone on this forum have this board yet? I know it's a little early but if you got the board, please post your results.
mcgirkz said:i haven't got my board yet. it's on back order. i have a question about ram for this board.
what is single rank and what is double rank? the online manual says that using all 3 dimms in single rank, i can get ddr 400 speeds. if all 3 dimms are double rank i can only get ddr 333 speeds?
i am looking at 1.5GB of Kingston HyperX DDR500. i can get a pretty good deal on them. i know the spec sheet says these modules need +2.6 volts, so there shouldn't be a problem with them on the DFI board as it supports dram voltage control.
will this memory work with the DFI board?
here's the link to the pdf manual for the DFI board:
http://www.dfi.com.tw/Upload/Manual...081000414-r.pdf
AMD t-Type said:as it turns out though, the highest i can run the HTT clock is 240 MHz, anything beyond that the external SATA ports don't work (ports 1 and 2 on lower part of the board), and this goes for all the boards
The Mofo said:First of all, you need to be using the SATA ports closes to their AGP port. The limitation on your OC has something to do with the onboard Marvel chip. Also, set your LDT to AUTO.. If you choose to set it to something else, be sure it doesnt exceed 2.5 - 3.0.
For the real scoop on this board, hit www.xtremesystems.org. Anandtech has more lames running around then i care to count.
More info the you could digest on this board.
AMD T-type said:single sided memory and dual sided memory
2dFx said:Someone tell me why DFI didn't use the Nvidia MAC and opted to use the pos Marvell chip for LAN?
well here's where i am at the moment with this board not 100% stable still figuring it out but....
9mmx19 said:Just checking - are you guys all using ClockGen to OC? I read that thats the way to go - and not the constant rebooting and using the BIOS that Ive done with my 2.4C and XP-M 2600+?
I hope to get this board and move to the A64 soon - will post if/when that happens.
