intercollector said:Well, unfortunately I'm not all that lucky compared to the rest of the guys here.
I know I have a lot of testing still to do, but the preliminary results do not look good.
First of all, I know my ram isn't all that great. Have some cheaper OCZ PC3200, and it will do 225 Mhz @ 2.5:3:3:6 timings, which isn't all that bad. Had to bring VDim up to 1.7V to achieve that.
But the part I'm worried about is my processor. It's a 3000+ newcastle (CO Stepping). Originally it was fine when I brought it up with the memory to 225. I dropped the multiplier down to 5:4 and kept going with the FSB. I had to up the voltage to 1.525V to get it past 230 HT (still no increase in temps). Anything past 238 freezes it, and prime95 fails at anything past 235, even though the temps held around 55c (as reported by the smartguardian tool). I'm not too happy with increasing the voltage any higher without additional cooling, but with those temps, I'd hope that it could handle a little more than I'm getting.
Any help would be appreciated. (specs are below).
A64 3000+ Newcastle (CO stepping) @ 2.35GHz (235HT)
DFI Lanparty UT nF3 250Gb
2X512MB OCZ PC3200 (5:4 ratio @ 195Mhz 2.5:3:3:6)
ATi 8500 (soon to be X800XT PE)
Stock AMD fan, + 2 case fans. Temps are 43c idle, 55c load (as reported by smartguardian, which apparantly this board reads a bit high, but I have no way of telling).
CPU V = 1.525
VDIMM = 2.7
sadvocate said:decrease your processor stepping. I have a 3200+ newcastle core with default stepping of 11 x 200 mhz HTT = 2200 mhz or 2.2ghz. By lowering the stepping to 8 I can increase my HTT to 300 easily and put my memory at a 3:4 ratio so it tops out at 250.
Also, decrease your LDT from 4 to 3. This will give you the headroom you need to go higher (even if you don't want to lower your stepping on the proc).
Give it a try, these boards like being pushed.
orkan said:he means lower your multiplier. You cant decrease your "stepping" ... lmfao.
this is the funniest noob mistake ive seen in a while.
Don't think so.intercollector said:Whats the point of running with a higher HTT with a lower multiplier and a 3:4 ratio on the ram? Is there any noticable increase from having a 9 X 260HTT = 2340MHz with a 9:10 ratio compared to a 10 X 235HTT =2340Mhz with a 1:1 ratio?
orkan said:grammar... ?
has nothing to do with grammar. has to do with STEPPING of a cpu being a WHOLE hell of a lot different than the MULT! Some people that read these forums are here to get accurate information. ... not go trying to change their CPU stepping in bios.
dfx said:
i'm more interested in his RAMintercollector said:Nice memory timings. Mind posting what kind of cooling you have, temperatures, and benchmark results?
1:1 265HTT? Could it be anything else but the BH-5 on an extreme amount of voltage? The new Samsung TCCD is great but I've never seen anyone post CAS2.5 with it over 250HTT.AMD T-type said:i'm more interested in his RAM
rowbear62468 said:ive got the gigabyte cooler and it fits perfectly and keeps things nice and cool
They work well with a bios upgrade. Or so I've seen.Bullitt said:Are the a64 DTR proccies supported well by this mainboard?
I'd really like a 1MB l2 cache, but unsure on the support. DFI forums are giving me some really weird jsp errors when I try to access them.
Torn between a 1mb cache or the 200 extra mhz... Cool and quiet doesnt thrill me, but the dtr's seem to be the only 1mb caches commonly available in the a64-3200 price range (about $200)
Jason711 said:to put this clearly to ppl...
memory speeds above 200mhz on a64 setups does NOTHING.
sadvocate said:why's that?
Jason711 said:the a64 isnt bandwidth starved like the p4. there is just too little gain in performance by ocing the mem. the whole system runs async anyway, so just keep the memory at 200 and oc the fsb for the higher overall clockspeed.
so you can save some cash and get some regular cas2 pc3200 (doesnt really even have to be 2-2-2)
AUDSCOTT said:Is that the 3D Rocket Pro, by chance?
Summoner said:Something isnt right, i dont think even BH5 is capable of running 265 1:1 @ 2-2-2 timings.
PureBooYah said:
Yea, with a simple bios update.Visable-assassin said:will a DTR Mobile A64 work with the DFI mobo? What about a "regular" mobile A64?
Couldn't have said it any better....emphasis on real world. xtremesystems are in fact quite extreme. gr8 site though. running 265 1:1 @ 2-2-2 timings are envious I'll agree but also look at how many guys over there that fry hardwareSummoner said:Interesting stuff, but in the real world you arent going to be running 3.4-3.7v through your memory and gaming and so on. If you did, i cant imagine the life of your A64 is going to be too long with that amount of stress on the memory controller
lil layzie said:Yea, with a simple bios update.
