Post Your 3DMark Vantage Score!
Not to shabby at all.
http://service.futuremark.com/compare?3dmv=246977
Main test results
3DMark Score P27819 3DMarks
CPU Score 39420
Graphics Score 25334
Test Results
Graphics Tests
Jane Nash 72.12 FPS
New Calico 76.37 FPS
CPU Tests
AI Test 2139.28 Operations/s
Physics Test 135.5 Operations/s
Feature Tests
Texture Fill Test 2189.6 GTexels/s
Color Fill Test 21.2 GPixels/s
Pixel Shader 98.78 FPS
Stream Out 25.79 FPS
GPU Particles 37.53 FPS
Perlin Noise 183.99 FPS
edit: Sig needs updating. I just upgraded my cards a few weeks ago.
3dmark score was p9149 with the system in my sig (but cpu clocked at 3.4 due to my watercooling system being changed and using air in the interim).
I've got an OT question to the above poster...why do you have a QX, ddr3, and tri-sli but a 22'' monitor?
Main test results
CPU Score 39420
Test Results
Graphics Tests
Jane Nash 72.12 FPS
CPU Tests
Feature Tests
Nice rig, we have very similar setups!:D
I have a 32 inch Samsung being delivered on Monday ;) I had to save up for it and I used my 22 for the time being.
How does that Striker work for you? I have either heard really good things or really bad.
Ugh, I think I got around P12500 with a GTX 260 and the PhysX driver
Not on my Vista boot ATM so I cannot re-test without restarting
the new Nvidia PhysX driver drastically improved my Vantage scores...3DMark Vantage went up by over 2000 points
3DMark Vantage= P6637
Vanatage: 8158 w/ physx software driver. (For some reason the Physx icon didn't pop up in my Control panel, but then again neither does the familiar NVIDIA shortcut on my status bar. Must be a vista 64 thing :confused:)
3DMark Vantage: P8936
CPU Score: 8380
Graphics Score: 11157
With sig rig...
ive heard that the 3dmarks vatange is bad but im dling in a moment. ill post my score in a bit.
P8962 with the rig in my sig. I have no idea what sort of 3DMark Vantage scores are considered decent, but this seems a little low to me, for some reason.
System in sig. Catalyst 8.8 beta drivers.
Extreme:
3DMark Score X11131 3DMarks
CPU Score 12820
Graphics Score 11055
Performance:
3DMark Score P14569 3DMarks
CPU Score 13039
Graphics Score 15162
Does this look right for 4870 X2 Crossfire? Most of the reviews show conflicting numbers between them.
Performance:
3DMark Vantage Score P9496
Seems lower than I expected. What do you think based on my specs:
Power Supply
850 Watt Power Supply - Nvidia® SLI™ Certified
Motherboard
Asus® P5N-D nForce 750i SLI, Socket 775, PCI-E, DDR2
Processor
Intel® Core™ 2 Quad processor Q9450, quad 2.66GHz cores, 12MB L2 Cache
CPU Cooling
Arctic Cooling® Freezer 7 Pro Heatsink, Ultra Quiet Fan, Copper Heat Pipes
Memory
4096MB Corsair XMS2 DDR2-800 Low Latency Extreme Memory with Heat Spreader
PCX Video
2 x 512MB EVGA GeForce 8800GT DDR3 in SLI, PCI-E, Dual DVI/HDCP
Audio
On-Board Integrated High Definition 7.1 Channel Sound
Hard Drive
750GB Hitachi 7200rpm 32MB Cache SATA 300 w/NCQ [Deskstar 7K100)
Operating System
Microsoft Windows Vista Ultimate 64-bit
After an upgrade to 4GB (actually, 3.25GB due to myself using a 32-bit OS) of memory and an upgrade to a Radeon HD 4850, this is my score now:
P6851
And that score was with the Catalyst 8.7 drivers with all of the driver settings at their defaults.
I will retest my system tonight with the current Catalyst 8.8 drivers and the driver settings set for maximum performance. The results will follow shortly...
Extreme:
CPU Score 12820
Performance:
CPU Score 13039
Yes its fine , i got on Extreme 7K and my GPU on performance is 13K so its seems to be right.
Used drivers that came with the CD 8.7 I believe. Also 3dmark sees my quad at 3.6 but its really 3.2ghz. weird
Well, here they are:
P7128
The 8.8's boosted my score slightly over the 8.7's.
SLI GTX280 one shitty vanilla that dont do past 1404 on shader and one really good SC that do pure H20 speed on air.
X10461 3DMarks
P23424 3DMarks
Now i found another SC that on air do push 1512 on shader with no problem to go along with the other SC i got from stepup, but need a dedicated GPU-loop before trying find the absolute max.
P7123
Cpu score- 30648
Gpu score- 5672
why is my cpu score so high?
P7123
Cpu score- 30648
Gpu score- 5672
You probably have an Nvidia card which is accelerating PhysX, and that is something that the benchmark attributes to the CPU score.
I think that is a decent score for 4850 Crossfire. My PPU does PhysX though it doesn't add to the score as much as PhysX via Cuda does; it helps a little.
My latest score:
Total: P6836
GPU: 6477
CPU: 8202
3DMark is of course pretty useless since Nvidia hijacked the CPU benchmark portion and made it into a GPU benchmark...
With my system currently set to:
Processor: Q6600 @ 3.780GHz
OS: Vista Ultimate 64
GPU: (1) 280 @ C=734 SH=1512 M=1242
Driver: 178.15
PhysX: 8.09.04
I can set my CPU to 3.8GHz or higher, and hit 15K now. :p
I think that is super for a 1 card system. ;)
