plz help, Ram problem!!!
bitibomer
at 1st my computer have 8gb of ram, after 1 month of use(brand new computer)(selfbuild) the ram went up to 6.8gb of 7.9 ram , the computer is very slow so i bought another 2x4gb ram(just yesterday). So in total i have 16gb ram, and now the ram has taken 12gb of 16gb. plz help to solve. i play like league of legend ,Assassin's creed unity, the crew,... I use firefox and i usually open 4 or 5 tab.
my computer spec:
Intel core i5 6500
Gigabyte H170 gaming 3
Coolermaster Hyper T4
Sapphire R9 Fury tri x oc(i overclocked from 1020mhz to 1070mhz)
EVGA 600B Bronze certified
PNY 240gb SSD
2x4 Crucial ram
2x4 Geil ram
HeavensCloud
Oswego, not shitty as Buffalo
Open task manager and see what is utilizing it all? Are you on Windows? What version?
bitibomer
at 1st my computer have 8gb of ram, after 1 month of use(brand new computer)(selfbuild) the ram went up to 6.8gb of 7.9 ram , the computer is very slow so i bought another 2x4gb ram(just yesterday). So in total i have 16gb ram, and now the ram has taken 12gb of 16gb. plz help so solve. i play like league of legend ,Assassin's creed unity, the crew,... I use firefox and i usually open 4 or 5 tab.
my computer spec:
Intel core i5 6500
PNY 240gb SSD
2x4 Crucial ram
2x4 Geil ram
im on windows 10 64bit, i turn everything off but the system ram still taken at 10gb of 16gb
bitibomer
im run on windows 10. i turn everything off but the ram still at 10gb of 16gb. i open the taskmanager to see what took the most and it's firefox 268mb, other thing not that significant amou (from 35mb to 0mb)
HeavensCloud
What does task manager say is using the memory? System idle process, explorer.exe, SVCHost? Something has to be claiming the memory.
bitibomer
There is scvHost(0.4mb), alot service host(but they are like 6mb) , there is qtweb that i have no idea what is it, avast, adobe flash player and more, i didnt see explorer.exe, the only thing that claim the most is firefox right now
drescherjm
You probably want to start looking at the largest allocations first. Sort by memory usage.
bitibomer
Dont worry unless you get an out of memory error ?
but the pc got slow when it's using this much ram(usually), and it doesnt show memory error when it's taken like 99%(8gb ram not 16)
HeavensCloud
Are you sure your PC is even reading all that RAM you have installed? Right click the start menu and click system, does it say installed RAM: 16GB?
defaultluser
thing that use the most is firefox, now i boot the computer up, the computer still at 10gb of 16
I'd say you got owned, and someone else is making use of all that lovely ram. reinstall Windows 10 from scratch, and try to stay away from torrent sites in the future.
Any time Windows is using as much ram THAT, but can't credit it to a single process, that's when you know you've got malware. Often it's a kernel-level exploit, which means there's no removing it with a virus scanner.
Nuke it from orbit, just to be sure.
bitibomer
i never go on torrent site tho, but im gonna try to reinstall windows. update: and now the ram became normal
defaultluser
Doesn't matter, you can get drive-by downloaded on anywhere. Hackers seize mainstream sites all the time and insert malicious ads. Sometimes it takes days for them to be taken down :(
Glad to hear it's working now. Luckily Windows 10 installs VERY fast on USB stick to SSD.
SvenBent
its generally not adviced when you are standing in a situation that you dont understand to deny listening to suggestion on how to obtain more info about the situation. aka don ask for help and then refuse to follow advice.
Where do you see the memory usage?
bitibomer
im not denying to listen to anything, im just follow his instruction by reinstall windows
SvenBent
I have have misread your intentions but it looked like you where denying the possibility for malware when people where suggestion to do a scan.
long day at work. Easy to get things wrong.
bitibomer
yeah, it's ok. im new with english too so it's my fault to make u misunderstand
