The pink isn't the problem. The problem is it doesn't reduce the gamut at all. It's basically a bad 6500K preset, not sRGB.nikolausp said:Interesting. I'm guessing it's probably because you haven't calibrated your monitor to it.
...If you go into the info screen in the menu and press AUTO + SOURCE + EXIT...
Oops, I meant AUTO + SOURCE + MENU, I think.
Are you doing it in the info screen in the menu?amikoenig said:Nope. tried both ways.... nothin'.
Settings will vary from unit to unit. It doesn't really matter. It only affects the presets.amikoenig said:And why are MY setting a bit different than your's Toasty? Is that the difference in the version?
Smart approach. Most amateurs that try to do aRGB or ProRGB are jerking themselves off and creating more work for no result.Jefe, the reason I want to get things to be sRGB on all ends (camera + monitor profile settings), is so I DON'T have to edit things ("sham" in your eyes) much on the computer to get it to print well at the photo lab on their sRGB printer (which most all Pro Photo Labs are)...
If I understand what ToastyX has reported the sRGB profile in color aware applications works fine on this monitor so it should not impact your colorwork flow at all. Its not a concern for color aware applications. This problem is more fundamental. Given that all content outside of graphics applications is sRGB the failure to display the appropriate sRGB profile means that the colors for everything outside of Photoshop is blown, oversaturated. That is much bigger issue as it effects everything else you do. Images viewed on the web and games won't be right, etc.
Given that this is such as W3C and OS standard, I amazed that this hasn't been dealt with on a driver level before launch.![]()
...Does it mean that I'll set the monitor to it's sRGB mode, do a calibration with the Eye One Display 2 to 2.2gamma, and 6,500 kelvin, 120 luminance, etc..... and then my Photoshop CS3, Lightroom, DxO Optics Pro, and PainterX will all look good in correct sRGB, but the anything else I do like surf the web, etc, will look worse?...
Thanks for the info. I'm trying to understand what this all means to me, as far as what I'm going to have to do in order to get the setup I want, as it pertains to calibrating with my Eye-One Display 2.
Is there some kind of way I can save modes? Like, switch to the sRGB when I want to be in Graphics programs, and then switch back to wide-gamut mode when I'm surfing the web?
I think you have that one backwards. sRGB is the standard unless another color profile used by a coloraware program. I think the burden is on the monitor manufactures as they are aware of this standard and how it works. I see no reason why this couldn't be fixed on a firmware update. And given that this is a known standard, it begs the question why it is even an issue?!?I wonder if there is any way that Windows itself can be made color aware for desktop applications....
Yes, if Windows and our browsers were coloraware that would be cool. There is a coloraware browser for Apple but yes, if that were the case it would be very pimp. But on the flipside 99% of content is currently sRGB so as of today it wouldn't make much of a difference.Yeah but wouldn't windows look a hell of a lot better if it could take advantage of the wide gamut?
