You say all that without even having used the monitor.Scyles said:Guys, there shouldn't even BE a sharpness setting if you're using DVI like you should be. Is this sharpness setting something that you're adjusting in the NV control panel? Because, through DVI, the monitor's built-in sharpness setting is disabled since it is perfect.
If you have an issue with blurry text through DVI, then your issue is with ClearType or font smoothing.
When calibrated properly, the Planar should look just as impressive as the 2407, except without the black crush and color shifting issues. If pixel pitch is an issue, move the monitor back three inches...voilà!
Yes, there is a sharpness setting, even with DVI. The sharpness should be set to 40%. Lower settings are blurry, and the default 50% has very subtle sharpness artifacts. I saw no difference between 50% and higher settings at the native resolution, so 70% shouldn't even make a difference except at lower resolutions.
One thing I didn't mention is I don't like the way H-IPS panels look. They look fuzzy to me. This applies to both the Planar and the NEC. I find it harder to focus on the image. It just doesn't look right to me. I really didn't want to mention this because it's highly subjective, but now that I see people trying to jack up the sharpness, I know it's not just me. I don't know what it is. It's not the pixel pitch because I've used 19" LCD monitors, which have larger pixels, and those never bothered me. No other panel type bothers me like this.
