Kliter said:For the third time, it's pre-released hardware running on un-official drivers. What don't you understand about that? 0_o
ToddMcF2002 said:I'm assuming the cobblestone pattern so cleanly rendering into the distance is what 16x AF is buying us?
R1ckCa1n said:Ummm..... did you not look at the pictures in the first post and see this is a RETAIL card purchased from a RETAIL STORE? This is far from "pre-release" hardware.
Still looks good once the drivers bring the IQ up to standard and start to show off some of the new goodness.
Jodiuh said:I'll take 2-4 hours of mad nuts gaming speedz!!
Mike an Dec:
Have you gamed for more than that? Any issue?
decapitator said:The only thing I noticed was when playing oblivion was that the body shadow looked like a screen, but I figured it was the beta drivers.From answering PM's and questions I never got to play anything for any amount of time
I had more fun reading the post about the cards
D4hPr0 said:Less reading and playing and more getting SLI to work. I need someone to do all the hard work for me.
decapitator said:I hope the 680i comes this week without issueIf not I will pick up something already out there.
So do we!!decapitator said:I hope the 680i comes this week without issue![]()
SlamDunk said:This thread needs some high resolution GOTHIC 3 screenshot loving with maximum details and AF (and with transparency AA if possible!).
...plus these \Gothic III\Ini\ge3.ini settings:
VegetationAdmin.ViewRange=10500.0 (3x distance for grass etc.)
Entity.ROI=8000.0 (2x distance for AI entities)
...and with and without Depth Of Field.
Thank you![]()
Self-shadows? I'm not certain that those work correctly on any hardware.decapitator said:The only thing I noticed was when playing oblivion was that the body shadow looked like a screen, but I figured it was the beta drivers.
phide said:Self-shadows? I'm not certain that those work correctly on any hardware.
Bo_Fox said:The cobblestone pattern is on the flat, level ground that has an angle of zero degrees. So, at that angle, 16X AF is exactly the same for all of the cards: 7900GTX, 1900XTX, and 8800GTX.
Jodiuh said:Apparently there was a guy in there on Sunday begging and willing to pay more than sticker, haha!
thespymaster said:But will the GTX fit in a Qpack?...That's my question.
i_am_mustang_man said:dremel it, FTW!
Arcygenical said:Hahah. Have 1 1/2 inches of PCB hanging out the back![]()
decapitator said:EVGA wants me to return my cards back to FrysI just wanted to know if I should register the unopened one and he started to go off on me
So I said first you need to stop talking to me like I'm dirt under your F***ing shoe, its not like I held up the F***ing store or I walked out of there without paying for them. I spent over 1300.00 dollars on your F***ing product, now he gets nice and suggest Frys holds two cards for me on release day( like that is going to happen ) if I return the two I have .
Holy s***...masaville said:I'll post some of these on Tuesday or Wednesday. I am running G3 in 1920x1200 with the ini tweaked using a 7900GTX SLI setup. I'll be throwing two EVGA 8800 GTXs in tomorrow night on a 680i EVGA board (everything is in stock - woot!). I'll post some benchmarks as well.
mike686 said:LOL What do you mean he went off on you? What did he say exactly?
decapitator said:Word for word
Sir ( in high tone) you need to return the cards back to the store now!! Its against the law to have the cards. So I correct him and tell him he is confused and in fact I did nothing wrong.![]()
this sounds like a sound plannobody_here said:it was breaking NDA for them to sell them to you, they are the ones who screwed up
but you know they probably are only wanting to get them back to swap them for ones that went through the recall process, to make sure you dont have faulty cards and start bad mouthing the GTX in public as a result of getting them before you were supposed to
it's only fair, but if i were you, i would probably take them back the evening before they are publically available, and then show up the next morning to pick up the two they reserved for you, to make sure you have the best quality cards
i_am_mustang_man said:this sounds like a sound plan
and who knows, they may not let you register the cards even for warranty and stuff (which would be retarded of them, but possible)
it is completely the retailers fault, and the manufacturer should have kindly asked you to return them due to the call back, apologizing profusely for the retarded retailer
even though we love their lack of smarts![]()
I'll let you know if the upgrade was worth it. Hopefully.
P.S. Look for my bargain basement 7900 GTXs on e-bay on Wednesday. lol
decapitator said:Its against the law to have the cards.
