Black Octagon
- Sep 15, 2012
I'm sorry to nag but I'm on the point of buying this monitor...can anybody who has this monitor make a good youtube video of the screen about gaming on 1080p res on this monitor?
What does it look like, does it look like garbage or is it doable to watch?
I want this monitor for workspace, but I don't want to render at 4K for games
Haven't seen a YouTube yet, but did you read this from the TFT Central review?
The massive 40" screen size really comes in to its own when playing games. It adds a lot of immersion and you have a really huge area to view. You can comfortably sit a few metres back from the screen like you would with an LCD TV and play games. The Quad HD resolution is also very impressive for games, providing a very high resolution and a lot of detail. Images look sharp and crisp even up close. One big consideration you need to make is that the 3840 x 2160 resolution is likely to be a major drag on even high end graphics cards and PC systems when it comes to gaming. You really need to think about the type of game you want to play, the settings you want to use, and whether your system can handle outputting such a high resolution effectively.
...(snip)...
One option of course is to run the game at a lower resolution and let the screen scale it. That's probably the most sensible option in most cases and we know that the interpolation of lower resolutions like 1920 x 1080 is actually pretty good on this model. It does kind of defeat the point of having a 4k resolution in the first place though. If you have games which can natively support this resolution properly, they would look fantastic given the very high resolution and large screen size. External games consoles running at 1080p will still look fine of course, and the image is interpolated well, but you will certainly want to be sitting a normal TV viewing distance to play those we're sure.
Seems like you should - like me - ask yourself whether your computer room can be adjusted to support a greater viewing distance.
