CrimsonKnight13
Lord Stabington of [H]ard|Fortress
- Jan 8, 2008
The game doesn't even start till cruel imo, since you don't regularly see 4L / 5L items or truly challenging mobs until then.
I'll give it a try
I must say I'm getting tired of the excessive spell effects when in a full group, which in turn rapes my fps. One would think a 6870x2 + i7 @ 3.5ghz would be able to keep up...
It's not the amount of effects that's the problem. It's their poor optimization and bugginess. I won't group with anyone using ice shot if I have a choice.
The one effect i will say that i don't enjoy, is the poison shot (or whatever it's called). When the chaos dmg poison is up, you can't see shit.
I joined a random group yesterday and someone looked to be using GMP LMP poison arrow. Needless to say I left that group pretty quickly.
What's wrong with Ice Shot? Me and my buddy built around him using ice shot and me using ice spear with cold penetration and projectile weakness curses.
I mean to say, i've seen him use it A LOT. I never noticed anything bad about it.
It causes extreme choppiness. Lightning arrow as well, but not as bad.
Are you saying that greater and lesser multiple projectiles can stack?
I'm like 99% sure they can, I don't see why they couldn't; They're different support gems. GMP adds 4 projectiles, LMP adds 2. The mana cost would probably be pretty high but I don't see why you couldn't do it.
Have you guys had any issues recently with dying from desync? I had a level 46 witch go up in flames because everything stopped moving and then I was dead...
Ouch. 83 is a pretty good run, though.
I just died at lvl 83 doing Vaal runs as a service for currency. It was like my 10th one, and I wasn't paying attention and was way too casual. Got one shot lol
you seem to be taking it a lot better than I would. Guess that's why I don't play hardcore.
some people have a different definition of fun than i do.
It's actually no where near as bad in this game as it is in something like Diablo 3. In PoE, the same currency is good from lvl 1 to lvl 100, so you're still finding good stuff while you level up.
Yea this is one of my favorite things about this game. Time spent with new or different characters is not time wasted, and if you're working on an alt, you are also farming for your main.
In a way that's true, but at the same time finding a 5L level 28 item isn't nearly as valuable as finding a 5L level 63 item or something. The currency is worth the same no matter what, but the items aren't.
Either way I still find leveling alts fun in this game. Of course having a Silverbranch kinda skews that a bit...it's something I recommend everyone buy and keep in their stash
Because it is a level 1 item with good DPS and you can twink new characters with it?
Speaking of level one uniques, do all of them follow this pattern? (or are there high-level uniques too?)
I got a unique in act 3 cruel which was itemlevel 52, but has no minimum level requirement, and also has really poor evasion rating.
Uniques have set stats. Some stats have a range but it doesn't change based on itemlevel. I don't think itemlevel makes a difference for uniques at all aside from maybe socketing/linking possibilities. There are high-level uniques based on higher-level armor/weapons. Silverbranch in particular is useful for starting new characters because it can be used by any level 1 character and grants +2 to the level of bow gems socketed in it, which is particularly powerful for certain bow gems(poison arrow in particular). You can cruise on silverbranch+poison arrow for quite some time.
Gotcha thanks.
I know i asked this before, but it still confuses me. All white belts/rings/quivers/amulets will have the same exact range of possibilities regardless of itemlevel, correct?
Also, why does the energy shield belt give half as much as the HP belt? (i've seen a 40 HP belt)
They'll have the same range of their implicit stat; That is to say, a Leather belt at level 8 and a Leather belt at level 68 will have a maximum base hp stat of +40. The random stats(the item affixes) are restricted by itemlevel, and you can get much better affixes on higher ilevel items.
I'm not entirely sure, although it may come down to the amount of +ES% you can get(because you can get global ES% on gear I believe) and the way ES works(super fast regen after the delay is up). That's just the way they chose to design things I guess.
Thanks much. I understand a lot better now!
I am allready bored with path of exile it's just a diablo 3 for the most part and boreing.
been trying this game and got to the last part of act3 and lost.
how do you get across the bridge?
I think I have done every quest and can not find how to break the seal or go around or what?
