Erasmus354 said:Well I have decided to get back into Folding after a brief stint a few years ago. Since I have watercooling I dont have to tear my ears out from the noise of aircooling a computer running at 100% all the time. Anyways I currently have it installed on my Opty165 which I have tuned down to 2.6GHz for added stability in folding. I plan on installing it to my parents computer a 2.6C P4, setting up an old 700MHz Athlon, and possibly my 2.4C P4-M Laptop. I also have a 3200+ which I plan on turning into an HTPC when I go back to school in a month...
So that would be 5.2GHz folding right now with another 8 or so coming soon possibly. Hope that helps some.
About the parents computer...is there I way I can install F@H so that it runs even if no user is currently logged in? Since it is a family computer there are multiple user accounts and often times none of them are logged in and it sits at the login screen. So does anyone know if it is possible to keep F@H running?
sure, thats easy. You need to install it as a service. Just download and run the console client instead of the graphical version. Its got a simple option to install it as a service. All you have to do is reboot then and it will be running as long as Windows is booted properly on the computer. If you need more instructions just post here and we can explain how to do the above.
