One GPU can NOT handle physx + video: benchmarks
Status
Not open for further replies.
Not in the slightest. I've always been pro-PPU (and I did try to educate people on the virtues of PPus on forums like these), but since it didn't take off, you have to count your losses and move on. GPU PhysX has much better odds of survival.
Ok, that is something I can agree with. You have to stick with the times and move with the market. And I'm happy Ageia didn't go under, at least PhysX will stay alive. But I might rather Nvidia integrated a PPU into new cards rather than use the GPU and steal performance from the video rendering. But this GPU PhysX driver is surely a boon to developers looking to support it in upcoming games.
Your own numbers prove that FPS isn't hurt by using your GPU over your CPU. There was an increase at every resolution shown. (Even at 25x16 it was slightly better than using the CPU). The PPU is dead so we aren't even going to talk about it. I can spend my extra $$$ to get extra GPU power which means more frames in every game, those that support physics and those that don't.
The end. /thread.
Forcing a PPU on every GPU would be one way to help spread physx adoption, however for me personally I am interested in seeing how an 8600GT or 8800GT would handle physics calcs.
It doesn't work that way.
For nVidia it's probably much cheaper and simpler to just add more stream processors to their GPGPU architecture than to put a separate PPU core onto the chip/card.
And since it's all unified shaders, this extra processing power can be used for other things than physics aswell. So you get more value for the same number of transistors you use.
So really, what they're doing now is the best solution. I mainly doubted GPU physics because I wasn't sure if their GPGPU architecture could deliver the same kind of performance that the PPU did... But because of the shared cache in the G80 design, it can do the same trick as the PPU could: move data quickly from one processing unit to the next.
CPUs cannot do this, cores cannot communicate efficiently, let alone switch from one task to the next quickly. There's a lot of overhead involved. CPUs are still very much aimed at serial processing tasks. GPUs and PPUs are far more parallel.
The end. /thread.
That's certainly what I thought when I read the numbers in the first post.
I just want to clear something up because I think people are missing my point. Yes, I agree that dedicating a GTX 280 solely to PhysX will blow away a EOL PPU card from 3 years ago. I am not arguing that point. If it didn't then there would be something really wrong. I accept that the PhysX add-on card was never a success, not because it didn't work but simply because enough devs didn't support it. So PhysX on the GPU is very much a good thing and I hope it takes off.
But here is what bothers me. From the day Ageia released their PhysX product, people have been claiming it was unnecessary. People said that those calculations could be done on the CPU with multiple cores. Nvidia (and others) claimed the GPU physics would be the answer. And here we are today, with vastly better hardware then we had 3 years ago, yet the PPU still wins out. That is what I am getting at. So, at this point in time, it makes more sense to move toward CUDA and other GPU processing techniques. But that doesn't excuse all the FUD that was spread over the years that effectively *killed* the PPU and now we know that was a lie. So now we have to wait for some Octo-core CPUs and SLI PhysX drivers just to get the performance that Ageia offered 3 years ago. Does this not bother anyone else?
They were NOT a lie, because you had to buy a separate card just for physics and except for a very small minority, people would just probably invest on a more powerful CPU and be done with it. A dedicated physics card is not the way to go, especially when GPUs nowadays are so powerful and able to do much more than graphics.
Having a PPU does have its advantages over a GPU, since it's dedicated, but as we've seen in the numbers presented by the OP, on what is a mid-range card now (9800 GTX), the difference between GPU physics and the PPU is not that great and as you improve your graphics card, these numbers will just get better. And when you compare the numbers of GPU physics to CPU physics, then the advantages are even more clear. You can buy the most powerful CPU on the planet (which usually is extremely expensive) and it still won't yield you better results than this mid-range GPU. Buying a PPU card has its advantages in terms of performance, but it's more expensive than just having the GPU (and the performance difference is not that big) and it occupies another slot, while being another component sucking more energy.
Also, as I mentioned before, out of CPUs with multiple cores, PPUs and graphics cards, what is the most important and mandatory component to play a game ? That's right, only the graphics card.
Even the games that say they recommend a dual-core, usually run on a single core. PPUs are not necessary, since physics can ultimately be done the CPU (even if it usually becomes a bottleneck). A graphics card however, is fundamental and if you have power to spare, why not enable GPU physics for a much better gameplay experience ?
I dont believe modern gpus have much (or any) spare idle time, the GPU's are programmable and can be dynamically assigned to different tasks on the fly, not like the older GPU's which had bits of hardware dedicated to different tasks like pixels shaders seperate from vertex shaders etc.
On top of this physics needs a dedicated thread all the time, it can't just borrow idle time now and again, its going to need to be in use all the time, you can't just disable physics when the card suddently becomes strained and have all the physics enabled objects pause in their path, you need constant calculations, so when theres hits to frame rate when something visually intensive happens you've got problems...
Yes again, CPU's are not as good at calculating this stuff, of course in comparison they're going to seem underwhelming, but you have to understand its not about sheer numbers, theres more that factors in to this, usability, accessability, future scaling etc.
Besides what I saw in the Alan wake CPU tests on teh quad cores, way back when it was first shown off, was quite impressive, a tornado tearing apart a gas station with many objects whirling around.
For developers making ACTUAL GAMES, and not running benchmarks, people that have real world considerations, the additional cores on CPU's is a much more attractive prospect, the fact that sucessful companies like Valve are doing a load of research into multicore optimisation for their engines so they can push physics is a good example of this.
The moment you add dedicated hardware into the mix you immediately scare off develoers, there's simply no way PPU's or multi card setups are ever going to be popular, and developers will never put effort into coding for that setup unless it's got a large market. That leaves doing physics calculations on GPU's as the only other solution which is always going to impact frame rate...
But these tests prove you wrong.
Test prove me wrong that I buy a video card to be a video card? Tests prove me wrong that games are going to be widely taking physics to CPU cores? Dude. Okie dokie.
Ding ding ding....we have a winner.
A simplified case to illustrate:
Just think about the difference between arithmetic and texturing operations.
If the texturing is too heavy, your arithmetic units will sit idle waiting for the memory to respond, and vice versa. With physics you can at least run extra arithmetic when your graphics are too texture-limited. Or fillrate-limted for that matter... and what do you know... games use a lot of shadowmaps these days, which are very fillrate-intensive yet use virtually no arithmetic at all.
Since a high-end quadcore is about 75 GFLOPS, while a high-end GPU is about 1 TFLOPS, you only need about 8% processing power of the GPU to outperform the CPU.
Look into the threading system that nVidia employs in the G80 and up. They can have tons of threads 'in flight' at any time, where the next 'warp' of instructions is selected by which instructions are currently ready for execution (as in not waiting for operands or other states to resolve). It's like a massively exaggerated form of HyperThreading/Out-of-order execution.
The odds are in favour of GPUs in every way.
But you've never seen the same thing running on a GPU, so you cannot make a direct comparison.
With 3DMark Vantage or UT3 we can make direct comparisons, and a GPU is far more powerful than a CPU at physics workloads.
Why would it be a more attractive prospect? It's harder to develop for, quadcores are more expensive and less widespread, and the performance is worse.
Valve is not a good example, because they developed their engine years ago, under the assumption that the CPU would do all physics. They're just making their existing codebase more suitable to multicore processing. I'm quite sure if they were to design an engine from scratch, they'd prefer GPU support.
UT3 was already designed with PPU/GPU in mind, and is now reaping the benefits.
CPUs impact framerate far more than GPUs, and are more expensive, so GPU is the way to go. If nVidia is right, and we'll have some 12 to 15 titles with PhysX support next year, everyone will be convinced of this. Problem now is that people seem to be in denial. The facts are right in front of them, but they can't or they won't understand them.
You yourself are an excellent example of this, blatantly ignoring that a high-end quadcore limits a mid-end GPU to 30 fps, regardless of resolution... While a mid-end GPU can reach 30 fps *while also performing the full physics load of the CPU* even at the highest resolution it supports. At lower resolutions it blows the CPU completely out of the water because the GPU physics don't limit the rest of the game as much as the CPU physics do, even with a high-end quadcore.
I've spelled it out a dozen times by now. What seems to be the problem with accepting these simple facts?
Come on Frostex...Valve ?
These are articles from 2006 and 2007 and nothing of what they promised actually happened. Episode 2 barely uses a second core, much less a third, fourth or more.
Also, Source Engine's physics is powered by Havok, which ultimately only uses CPUs this far, so it only makes sense that they keep it that way, given the engine's age.
Another important note is that Valve considered PhysX "horrible", when it was powered by an Ageia's PPU and not when it can be done on a GPU, as is what NVIDIA is pushing right now.
Wow your amazing ability to focus soley on benchmark numbers and nothing else, is outstanding.
I've clearly stated that this exceeds the pure facts and figures down on paper of how efficient GPU's are at these sorts of calcultions, it matter what is attractive for developers and what can be sold to customers, what makes money. Please PLEASE try and understand this.
The developers of games like Alan Wake are smart, they're designing their engine to work multicore, that's the future of CPU's now we're leaving the era of scaling speeds and moving into the era of parallel processing with multiple cores. All this optimising for multithreaded processing is going to have to happen anyway.
It's not easy to get right first time, Valve have clearly stumbled trying to get it working because they've delayed releasing anything significant on this, but their multicore physics benchmarks clearly show that you get almost perfect scaling on multicore CPU's
So our game logic in something like a FPS game just isn't really that demanding right now, I'm pulling a peak of 700fps in the CSS benchmark and about 340fps average with my new setup thats at 2560x1600 8xaa 16xaf, and the game isn't really using anything significantly more than 1 core.
Now I have 3 core sitting there idle doing nothing, and here come the guys making alan wake, and they're shooting for a physics engine which works on the unused cores on quad core CPU's and they've got pretty damn good scaling, and they've got it for free, theres no performance hit.
OR i could do all them calculation on my GPU which is already running at practically 100% load all the time, and see my frame rates drop in the game, which means turning down settings to get a playable FPS.
It also means it scales like ass, because I want to add 50% more obecjts and suddently the video card has to render 50% more objects AND do the physics calcualtions for 50% more objects.
Theres other issues as well, they dont have to worry about how those objects affect the game state and synchronising the data from the GPU back to the rest of the game code to tell if a large brick has just smacked your character upside the head, gabe newell has spoken about this sort of thing in interviews about how physics objects important to the game world becomes a real problem, how do they make the AI (which is run on the CPU also) interact with the objects, how do they push something out of the way or dodge something that might kill them, how do we decide when something breaks into smaller pieces and how does that effect the game states, having the CPU wait for an external source to send it back this data causes issues.
Simply pointing to a graph and saying, "this one is faster" isn't enough.
Frostex,
No sense in arguing with the guy, he thinks he knows it all............even though the benchmars show when GPU is loaded = no gains
ok so the benchmark was UT at max res but the point still stands......GPU under load = no time for physics
Let's see... they can choose to use the PhysX API, which means their code will work on consoles, multicore CPUs, GPUs and PPUs.
So for a PC game there will automatically be a multicore CPU path as fallback, and for the ~50% of all gamers that use nVidia GPUs, there can be GPU acceleration if they choose to enable this in the drivers.
Sounds pretty attractive to me, as a developer.
Pffft, Alan Wake has been in development for years. They just tried to ride on the wave of multicore hype when the first dualcores were on the market, and the advent of quadcores was announced.
Might have seemed impressive at the time, but various games have introduced multicore optimizations since, and both Havok and PhysX are multicore-optimized anyway. Alan Wake has just been superceded by the advent of PPUs and GPU-accelerated physics.
I've Now I have 3 core sitting there idle doing nothing, and here come the guys making alan wake, and they're shooting for a physics engine which works on the unused cores on quad core CPU's and they've got pretty damn good scaling, and they've got it for free, theres no performance hit.
Your logic fails at the part where you assume that a CPU can handle that kind of physics *at all*. Any game (including Alan Wake) has pretty light physics, except for the few special cases like the PhysX levels for UT3.
You don't lose fps because the physics are neutered for CPUs. GPUs can easily run those physics as quickly as a CPU and not drop any frames. The UT3 results show that even the PhysX levels can run at high resolutions without being slower than a high-end CPU.
So there is absolutely no factual base for your assumption that CPUs would be adequate for physics.
Also, your assumption that modern games leave the CPU as idle as CSS does, is wrong. Better graphics also means more CPU load, as does better AI. So even without including physics, modern games are already much heavier than CSS.
No, but you're not making sense. I'm a developer here, I've dabbled with multicore optimizations and GPU-accelerated algorithms. I know how they relate. You just make asssumptions that show you are not smart enough to realize how little you know about the subject. I'm not arguing with you, I'm trying to teach you the basics of how a modern CPU+GPU system work in a game engine, being an experienced developer myself.. You're just too stubborn to take any of it in.
<snip>
The issues you mentioned are exactly why CPUs are being the bottleneck in this regard, which is one conclusion reached, in the article. The CPU is so slow processing the physics data, that it hurts performance overall and GPU is left waiting to render everything after the calculations.
Now, with one of your examples in mind (for example AI reacting to some object flying towards it) and GPU physics being used, the overhead to send data back and forth is there too, but since calculations are done much faster than on the CPU, there's really not a big penalty in performance.
The Alan Wake example is obviously a good point towards more CPU cores, however what's the status with Alan Wake ?!...
As you, I was impressed when I saw it running on Intel's newest Quad-Core processors and I thought we were finally going to see something out of multiple cores in games. But nothing happened. Valve promised much with HL2 Episode 2 in terms of multi-core support, but they didn't deliver and as reviews showed, most of the other games, barely take advantage of the second core and only a handful even goes beyond that.
There's also the fact that Quad-Core processors are not exactly "main-stream" yet, in terms of price that is. To pressure Intel, AMD has some appealing options below $200, but they are still slow for physics calculations, just like even Intel's most powerful Quad-Core, when compared to GPUs.
And this is just a feature. If you are really against using it, for whatever reason, you can always disable it in the drivers and let physics run on your CPU, regardless of how many cores it has. If you have GPU power to spare, enable it. If not, disable it.
Also, many PhysX games are coming:
http://www.legitreviews.com/article/733/1/
hench why nehalems are needed for gaming but some people think otehrwise
Nehalem is not going to be faster than a modern mid-range GPU processing physics either. Faster CPUs are always welcome, but when something else can do some calculations better than them, they should be used, even more so, when that "something else" is a common (and actually mandatory for gaming) component like a graphics card.
You are completely ignoring reality though. Lets look at the current state of gamer hardware: http://www.steampowered.com/status/survey.html There is only 4% of the gamer market with a quad core, the majority still has a single core. However, the most popular video card is the 8800 (9.37%), with cuda-capable cards capturing about 19% of the total. As such, GPU physics are vastly more attractive due to their higher market share. Please, PLEASE try and understand this :eek:
Don't assume developers are smart, even of big name games. The Alan Wake engine has also been in development long before this was even announced, and as such is completely irrelevant. Even though the game isn't out yet, its still last gen tech in terms of physics.
Um, congrats. Next time stick to the topic at hand, not some random CSS benchmarks that don't even use physics.
But its NOT free. Even if you dedicate 3 CPU cores to physics, it is still going to get its ass handed to it by GPU physics. The GPU can do rendering+physics faster than the CPU can do just physics. So if you up the physics load, the CPU becomes the bottleneck. That is the entire point. If you need proof, just look at the benchmarks in the first post.
Also, just because you have a quad core does not mean that others do. As I said above, developers will only be able to safely assume that a dual-core is present, which means 1 core for physics. Of course, this then means that physics will have to be neutered to make it playable. Or, they could use PhysX, up the physics in the game, and everyone is happy. You can disable hardware acceleration and watch your FPS tank because your CPU will suck at physics, while others will leave hardware acceleration on and enjoy a physics loaded game.
No. If I add a BILLION objects to a scene, but none are moving or being interacted with, I won't have to do ANY extra physics calculations. Hence, your argument doesn't make any sense. The same thing applies currently, that is why there are little sliders in the options panel to control quality/objects, so that you can adjust the game so that it plays smooth on your card :rolleyes:
Uh, no. Simply no. The use of the GPU instead of the CPU is completely transparent to the game, that is the entire point of an API. What you just said would apply every bit as much to CPU based physics as it would to GPU based physics, and really it is an argument against using physics in games at all - which is just stupid.
No, actually that is the entire point. The faster solution in this case is the better one, plain and simple.
If 9800GTX is not a fast enough GPU to handle PhysX AND graphics together, what about the majority of the cards in the market? Most people don't have a GTX 280 in their system and I doubt that anything higher than 8800GT is the norm. Let say that a 8600GT or 8600GTS is the average of what most people use, why would developers waste their resource to develop a game for the high end market? I don't think that Crysis sales is higher than CS:S sales. My $0.02.
The assumption that the 9800GTX is not fast enough to handle PhysX and graphics together is incorrect, as shown by the benchmark results in this thread.
Therefore the question is irrelevant.
So 9800GTX is fast enough to handle PhysX and graphics together, what about the majority of the cards in the market?
I don't understand the question.
All 8000 series and higher are basically the same architecture as the 9800GTX. These tests already show that PhysX and graphics workloads can be run in parallel efficiently on this architecture.
Other cards mainly differ in price and performance levels, the basic architecture is identical.
You scale your game detail level up or down to suit the performance level of your hardware. Whether or not it's fast enough depends on what kind of performance levels and game detail you desire.
And as already pointed out, the feature can be disabled, so should you have a really slow videocard and a really fast CPU, you can still choose to run the physics on the CPU, if that would be faster.
So how is your question relevant in any way whatsoever? I don't understand it.
The question is relevant because developers won't create a game for the minority of the market. Ageia failed because there are not many titles that support PhysX. The situation won't change soon with CUDA since for the majority of the market, the GPU is still the bottleneck of the system and I doubt that people or the developers will sacrifice graphics performance for PhysX.
As soon as you want to add less-than-trivial physics, the CPU becomes the bottleneck. The GPU allows you to add much more complex physics with a much smaller performance impact than a CPU.
Hence developers will love adding more detailed physics.
They're already doing that for CPUs anyway. Crysis offers no less than 4 different levels of physics detail.
Do you even understand what you just said?
Raw processing power in terms of GFLOPs or TFLOPs is only good for folding or other tasks such as encoding which require a lot of processing power.
Games, physics, and textures do not rely as heavily on this as they do on threads. What Frostex said was absolutely correct and unarguable (well, you can try, but you will fail).
The problem is is that the GPU only has a finite amount of processing power before it becomes overwhelmed. Granted, a high-end quad-core may only have a fraction of the overall processing ability potential, but it can always have a dedicated core to running physics, where as a GPU cannot.
My GPU has 800 cores in it, but each one of those core individually is far less powerful than one core of a quad-core processor. So if all 800 cores are needed for graphics, then the physics just gets shut off (and then a blue screen appears). Games can't operate like this and the programming is very difficult. 99% of all PC/Mac users are not using dual/triple/quad graphics cards or GPUs, so as Frostex said, the programmers do not want to make games that rely on these kinds of setups. However, almost all of today's modern processors have two or more cores, so dumping the physics onto one or more of those cores is a much more efficient/reliable method that can be used for all of today's machines on a mass scale.
No, we have someone who hasn't done the math.
No, I think you don't understand what the fuck you are talking about.
It's time for you to ask Kyle and Frostex for forgiveness. :D
What he means is what about the OTHER cards in the market. i.e. not 8800's. What about people using 8500GT's, or a HD2400XT's to play games?
You think those kind of cards are going to be able to handle physics? lol
Go back to school. :rolleyes:
I'm calling bullshit on this. Have you EVER tried to run physics on a GPU? From the lowliest 8400GS to the GTX 200 series, the cards WILL become overwhelmed at some point.
Look at me, I'm running a 9800GTX with physics loaded to the GPU. I'm so cool, even though I can only play my game at 1024x768 to get 30fps. lawl :D
It doesn't matter because the same API targets CPU, PPU, and GPU all in one. The game doesn't give a damn whether the physics runs on the CPU or GPU - it is programmatically the exact same. Hell, the game could even just have a checkbox to enable hardware acceleration for physics and leave it up to the user to decide (I believe UT3 does that). That is the beauty of PhysX - it'll run on anything.
One point that everyone seemed to miss is that we are only looking at UT3 benchmarks. The game engine or Nvidia's drivers could have specific optimizations we have no idea about. I'd like to see some benchmarks with the bare-bones PhysX demos (like 10,000 rigid body cubes, cloth or fluids simulation, etc.). I mean, would you buy a video card based on a benchmark in only one game? I think we should wait for some more comparisons before taking those numbers as gospel.
Actually, no, in this case FLOPS matters as physics calculations uses floating point math - which is exactly what FLOPS measures.
The CPU only has a finite amount of processing power too, it also happens to have a hell of a lot LESS processing power. One CPU core towards physics won't do shit once you exceed trivial physics (such as fluids and cloth).
That is about as far away from correct as you can get. The load will be balanced, just as vertex and pixel shader loads are balanced now...
Actually its very easy. Its the same level of difficulty as physics on the CPU using an API. It is literally just a checkbox feature, and the library handles the rest. The developer doesn't have to do shit to support GPU acceleration.
As was shown very very clearly by the benchmark, a SINGLE $200 card is up to the task. You don't need two, you don't need three, you certainly don't need four. A SINGLE midrange card is all you need. Also, as I pointed out early, MOST gamers (as per steam) still have a single core, so your assumption is dead wrong. It also doesn't matter if you dedicate 1, 2, or 3 cores towards physics, it is still the SLOWER of the two! What don't you guys understand??? It is like arguing that you want your virtual RAM full because otherwise isn't being fully loaded - who cares? ITS SLOW!
Neither do you, but that hasn't stopped anyone.
So when running PhysX on a previous generation card you can get more than 65% more FPS and at worst it runs the same as if you were running it on the CPU. I'm seeing some great design and an accomplishment by nVidia, what did the OP miss?
True, but we only have one game to support it at the moment. Its all we got. The GPU will easily win on the bare-bones PhysX demos, as is shown by 3dmark Vantage.
So when running PhysX on a previous generation card you can get more than 65% more FPS and at worst, it runs the same as if you were running it on the CPU. I'm seeing some great design and an accomplishment by nVidia, what did the OP miss?
No idea, but somehow there are a lot of people here that don't seem to get it...
I hope AMD supports PhysX in hardware soon - this would probably go a long way towards improving adoption. No third party really wants to support a single vendor API (which is not to say that no developers will support it - I bet the TWIMTBP program will get a few converts).
Yes I've read about the CUDA/PhysX hack for ATI cards but that's not something that would really guide developers into using PhysX - it needs official support.
Status
