- Pentile screen looks ok to me (after changing horrible default power settings to make it not grey).
What's this you speak of?
Default power saving setting make screen appear very dim, just need to bump up brightness.
Anyone else notice the default Text msg notification is really quiet? I've turned up the notification volume but might just need a new ringtone for it.
Secondly, any good apps for ringtones that don't download a ton of crap to your phone. I've seen some that request access to your contact etc..screw that.
I've heard the speaker on this phone is super quiet. One of the few flaws I guess.
As for the menu button, yes, it appears as a part of apps now, but i am used to having it in a static place and was using it pretty often. Maybe wont bother me after a couple of days or a mod.
The phone is the best android phone period, BUT there is one thing that pisses me off. The hardware is lacking compared to the Galaxy s II's, especially my GS2 Tmobile version which rocks a much faster 1.5Ghz Qualcomm chip, but more importanly the GS2 has the new Qualcomm graphics chip compared to the Galaxy Nexus which shares the same graphics chip as the Nexus S(seriously Samsung wtf!!!) Major bummer and it shows. The Tmobile GS2 is fast fluid and eats everything thrown its way, while the Galaxy Nexus still has some slight lag. (might be do to first release software but we'll see)
This right here is the irony of the world. I really liked the Nexus at first, but once I found that out.... The GSII which has a tiny 800 x 480 screen has the Mali-400, but the Nexus with its epic 720p screen... has the SGX540 from the Galaxy S. Like what the hell were they thinking?!?
So is there a way of getting unlimited data (incl 4G) if you are not already on that plan. I've read that Verizon reps can do this if you have an employee discount based on your employer?
The tmobile galaxys II on tmobile and the att skyrocket has an evn faster graphics chip then the mali,its the same as the iphone 4s
Dont understand samsung and googles logic here unless they have a galaxy s3 out very soon
So far, I think people have focused too much on synthetic benchmarking. We'll see in real world tests when the S2 gets ICS.So now the OMAP4460 is getting quite a lot of scrutiny, even though it isnt exactly a new chip. This dual-core SoC is clocked at 1.2GHz, and uses ARM Cortex-A9 architecture, just like the Exynos. Thats not a problem, but the older GPU, the PowerVR SGX540 is. We were hoping for a step up in the graphics department.
Why did Google choose the OMAP for its new Nexus? Well, it might not live up to the high graphical standards set out by the iPhone, but it is a solid chip in its own right. The OMAP4 platform makes use of an additional hardware accelerator called IVA 3 that makes encoding and decoding HD video a snap. The Galaxy Nexus has an HD screen, so this hardware focus on video is a big plus.
Google engineers were likely also drawn to the OMAP for its use of a dual-channel memory controller. Androids multitasking system means that data is constantly being moved into, and out of, active memory. This is definitely a strength of TIs OMAP parts.
Can someone help me figure out this power modes or power saving settings thing? I feel so dumb because I can't find any setting for it. Thanks.
Volume problem can be fixed by downloading Volume+ App and set it to +8 or so
You guys who are saying the screen isn't bright enough are just out of your minds.
You guys wait....wait until you get a proper CM build going....you have no fucking idea how fast that device you have can be with proper code. Samsung is notoriously bad with sloppy code
And the GS2 with CM will then be slower....? There's a reason why we were all bummed when the final specs were released- let's face it, the Nexus isn't awesome because of its hardware which is reminiscent of devices released this past summer. The NFC, while cool, is totally useless without something like Wallet. The Nexus is cool because it's running ICS, and will receive quick updates going forward (like today!). Saying stuff like "just wait until we have some optimized code!" doesn't change the fact that we didn't get a OMAP 4470 (or comparable) like we were all hoping for.
The thing that's making me consider returning mine is the fact that it's not "next gen" hardware per say. It's like building a new PC today and putting a I7 920 in it. Might be a bad example, but I think you get the idea. Kinda seems like this phone wasn't thought out completely. They should have paired the highest possible current hardware with the newest version of Android. But they used older hardware instead, and are trying to sell it by pushing ICS.
I can see a really bad ass phone, hardware wise, being released soon, getting ICS, and being THE android phone. And GN adopters would be left with a lackluster phone with ICS. Like I stated earlier, I really like the phone, but it's just not that big of a difference over my Droid X with Liberty on it.
Pretty much what Ive been saying. Everyone who says "Eww Nexus screen is so not crisp" or that its not bright enough, I swear you must have a rough fucking life being so outrageously anal. I consider myself moderately picky and I think this phone is amazing.
