spmethod55
- Feb 18, 2009
I can play. Let's meet up online.
I know I am lame, but I tend to like the old NHL 94 controls... lol
Release Notes said:Exploit fixes:
-Prevent players from entering games with attributes that are raised beyond the level they can reach with the card they are entitled to have. Players who have elevated their attributes this way should reset their character by changing the type and reassigning their points.
-Limit the size of human goalies in OTP/EASHL games to 6'4" (NOTE: it will still allow them to be set larger, but the actual height in game will not go above the new limit).
-Fixed some problems that could cause the game to hang or go out of sync when pausing.
- Prevent use of LB to get up instantly after being knocked over.
-Reduce accuracy of shooting while using vision control to skate backwards.
-Prevent high, accurate slap shots from in close to the net.
Other changes:
-Reduced the ease of beating the goalie on the short side.
-Decrease the tendency of the goalies to use a desperation save unnecessarily.
-Strict calling of interference, though you can still clear players directly in front of the net without getting called for interference.
-Added stick lift to Classic controls using LB+X(XBox) /L1+Square(PS3). It is also on R3 (press Right Stick).
-Fixed shot targeting using the Always Up control when skating down ice.
-Added new NHL rule to locate face- offs in the attacking zone to start a powerplay.
- Prevent CPU players from getting delay of game penalties frequently while clearing the puck from their zone.
- Prevent puck from being poke checked away from the goalie when he has it covered under his glove.
-Reduced the amount of time it takes to get control of the last man back, holding RT(Xbox)/R2(PS3)
-Reduced the amount of time it takes to get control of the goalie, holding LB+A(Xbox)/L1+X(PS3)
-Reduce the range of heights on randomly generated CPU players, including goalies.
-Eliminate the ability to accelerate and maintain high speed while stick lifting.
-More penalties for high sticking when stick lifts are done from behind the opponent.
-Made the colours of the OTP/EASHL indicators more distinct (yellow and orange).
-Made face-off outcomes slightly more random and slightly less dependent on attributes.
-Added assistance to prevent one-timer and shot attempts from leading to accidental hits and interference penalties.
-Goalie tuning to increase goal-scoring a bit to compensate for taking away the easy short-side high goals.
-Improve hit stat tracking to not count all of the small bumps in front of the net.
-Increased injuries caused by CPU teams.
-Prevent puck from being launched with very high speed following a hit.
-AI tuning for superstar. The Aggression slider now affects how intense the CPU team is on that difficulty level.
