- Aug 15, 2005
I spent a lot of time on this. and due to limited options for the paintshop and an unwieldy interface, coloring those hood vents black is one of the worst things I have ever done in my life.
color swatch
and now for Chameleoneel's guide to tweaking SHIFT 2 for Dualshock 3 users (may generally apply to all gamepads across versions, but no promises)
advaned control settings in the options menu
steering deadzone 4%
steering sensitivity 0%
throtle deadzone 2%
throttle sensitivity 28%
brake deadzone 2%
brake sensitivity 50% *
clutch sensitivity 2%
speed sensitivity 80%
advanced tuning settings in the "tune" menu acessible a few places, but mainly from the garage.
brakes 54 for rear brake bias **
toe angle front and rear both set to 16 (you could go higher with these if you have a really tough to control car, but this is a pretty good universal setting)
steering lock 12
** because it seems many videogame cars understeer as a general rule, I like to tune my brakes with a bit of rear bias to help the car turn-in when preparing for corners. Its not something you want too much of and if you decide to use it, be extra careful if you additionally decide *add more sensitivity to the brakes. Making the brakes more sensitive will make then grabby and it will cause the turn-in to happen more suddenly. This can throw you...
Overall, these settings remove a lot of the sensitive twitch that cause you to throw the car everywhere. It also allows much better throttle control.
color swatch
throtle deadzone 2%
brake deadzone 2%
steering lock 12
