- Apr 8, 2009
I'm kind of disappointed in 4.4/Kitkat in that it didn't do more for power efficiency. There's no reason that a 2300 mAh battery can't easily get you through a day of normal use. The Nexus 4 seems to have better battery life with older hardware and a smaller battery. Yes, the N4 is missing LTE and has a smaller, lower res display, but the S800 in the N5 should still be more power efficient even with LTE since it's all integrated into the same chip (right?). The only thing that should be more taxing on the N5 over the N4 is the larger display, which is only .3" larger. My guess is that the S800 does indeed use more power than the S4 Pro in the N4 though, either due to the LTE integration, higher clock speeds, or GPU since it's always driving a 1080p display rather than the 720p on the N4.
But if the HTC One and Moto X can make it all day on the same size battery using an older SoC (S600/S4 Pro), there's no reason that the N5 can't do it. It doesn't help that Google hasn't even implemented a native power saver feature that throttles the CPU and adjusts the display like every other OEM has built into their custom skin. They could at least give you that option to enable to help out a bit. I'm sure the S800 running at 1.5 GHz would still outperform the S600 running at similar speeds and use less power while doing it.
Power efficiency is the one last areas that Android really needs improvement. I don't see how they don't see that yet and haven't done anything about it. Performance is pretty much there now with newer hardware and software improvements, so I think they can push performance improvements to the side for the time being.
