Nenu
[H]ardened
- Apr 28, 2007
Killer discovery Ziran, for everyone. It basically deserves it's own thread. Nice work.
It's not, Gigabyte's page says you can use 2xDVI+HDMI.
Wow, it does too!
1080p is a perfect scale for any 4K set with no scaling artifact.
Uh, hdmi/dvi converters come with every video card. They don't have anything inside except wiring.
> I would stay away from any converters as none of them support HDMI2.
The converters are just simple (& short) electrical connectors.
hey guys, i just got my 55ju6500. I think I got a defective one, unless these units have an option to turn off the 1 inch purple circles that are all over the bottom half of the TV.
Anyone get something like that?
Zarathustra[H];1041698809 said:Pic?
I've certainly never seen anything like that.
IM back!
And
Now i need a bigger Desk =(.
Not sure if you even meant to reply to me? Nobody has confirmed that you could do 4k@60Hz with DVI to HDMI before that post, at least on this forum. People were buying multiple 9xx cards to use the HDMI ports just to drive multiple 4k displays.
Is the GTX960 the least expensive card that can run THIS display at 60hz 4:4:4
Sure, but the point of HDMI 2.0 is 4k@60hz support over one link so I'm not sure what dual link dvi has to do with it.
HDMI is the same electrical spec as DVI and has always been since the beginning so it's odd that it would come as a surprise.
> Correct me if I'm wrong, but my understanding regarding all this is that HDMI is only electrically compatible with single link DVI. Dual link DVI requires an active adapter which introduces lag, and no such active adapter has been released for HDMI2 yet.
Looking back at context, Ziran by "hdmi 2.0 converter" maybe meant hdmi <--> display-port, which is right. There aren't any that support hdmi 2.0, but it'll be pretty awesome if/when there are since it means folks won't be limited to geforce 900 series cards.
Zarathustra[H];1041700308 said:Well, the point of my comment is for people who want to use a DVI to HDMI2 adapter for 4K output to one of these screens. I don't think this will work, as you can't combine two links of DVI into one HDMI plug without an active adapter, and a single DVI link makes out at 1920x1200 at 60hz.
So, the point I am trying to make is that based on my previous understanding of the relationship between DVI and HDMI, is that even if you are HDMI2 after the DVI to HDMI adapter, a passive adapter will only convert one link, thus maxing out at 1920x1200 at 60hz.
You'd need a dual link DVI to HDMI2 adapter to make it work, and that would have to be active (and thus introducing lag)
I'll check to see if I have a HDMI to DVI adapter (pretty sure I have a few) and I will test it. My guess is that you want the least amount of connection points for this high of bandwidth signal, so adding an adapter introduces 2 additions connection points.
I'll post results in a bit.
Dude... >_<
You're gonna be so pissed when one of those falls off the edge of the desk. It may not be a good idea, from a structural standpoint with such a large display, to only have part of the stand supported either. But hey, it's not my money.
I set up my 7500 to automatically install the latest updates via wireless. You do it through the Support option in the main menu. The current firmware is 1219; installed itself, yesterday.I actually got mine yesterday (JU6700) and had to order an HDMI cable. I'm temporarily using an HDMI to DVI cable from Monoprice and that seems to work but I have an HDMI cable from Amazon coming today just to be safe. This is the cable I used: http://www.monoprice.com/Product?c_id=102&cp_id=10209&cs_id=1020902&p_id=2408&seq=1&format=2 which says "up to 2560x1600" but my computer was displaying 4k @ 60 Hz, unless it was lying. I did try out game mode and the text was pretty crappy, similar to the pic I posted before. Switched it back to PC mode and launched a game, looks damn amazing but a bit dark. Gotta tune it still.
Not sure what firmware is on it, how do you check that? I did get a little USB stick with the TV saying it had the "latest" firmware on it so I'm thinking it might have older firmware on it.
Nvidia cards can do 4K/60Hz at 4:2:0. You should run the 4:4:4 test just to confirm that it's actually 4:4:4 at 4K/60 rather than 4:2:0.
Zarathustra[H];1041701327 said:Using remote:
1.) Press "menu"
2.) Navigate to menu on top left of screen. Menu screen will open.
3.) Find "Setup" (the cog icon)
4.) In here, find support menu.
5.) There should be a software menu line item.
This will tell you your current firmware revision, and if it has any pending ones to install. You can also force it to check for new updates if you think there are any it hasn't discovered yet.
By default these units are set to autoupdate on the next power cycle after discovering an update though, so if you aren't on the latest, you should be there soon.
https://en.wikipedia.org/wiki/Chroma_subsamplingZarathustra[H];1041701462 said:Does anyone happen to know how the bandwidth requirements of 4:2:0 compare to full 4:4:4?
To calculate required bandwidth factor relative to 4:4:4 (or 4:4:4:4), one needs to sum all the factors and divide the result by 12 (or 16, if alpha is present).
They will be limited to 900 series cards, HDMI 2.0 still has to be on the card for it to work.
It's the signal being sent through the connection that's important.
Soooooooo .... Today Frys had the Samsung JU6700 on sale for 597 with no tax ... hahah..
Zarathustra[H];1041698671 said:bad tv - sli
No, the whole point of a DP->HDMI adapter is zero dependency on hdmi, just as they always have been. There should be one out later this year.
Did you keep the TV with the bad panel tag? Did you try SLI yet?
Sure, good luck with that. Six months at least to get a working DP to HMDI 2.0 converter that accurately throws a 4:4:4 signal at 4k/60.
No way.
Hard enough to get it to work when it has the connector heheh, let alone going through some nonsense converter from a third party.
But hey, to those who just simply won't go the easy way and do what everybody else is by grabbing a sweet sweet 980 Ti, today, and having the best of all worlds at your disposal immediately...I wish you luck.
1006 firmware on mine. You said the newer firmware had more lag but better colors, Zarathustra?
Zarathustra[H];1041702260 said:I called and told Crutchfield about it, and they immediately offered to replace it.
Later the Crutchfield head of operations called me to personally apologize and asked if I could provide a picture of the "bad screen" tag, which I did.
I let him know I didn't fault Crutchfield at all, but that it did appear as if Samsung had a quality control problem in their Mexico facility..
Zarathustra[H];1041702260 said:What's worth noting is how in many titles, two 980ti's are really challenged.
The opening scene of Metro 2033 - for instance, averaged ~45fps at ultra settings and AAA antialiasing.
