What kind of crimpers are you using? They look really nice.
http://www.cableorganizer.com/platinum-tools/ez-crimp-tools.html
Best crimpers I've used... they make a version with hard grips and soft grips, choose accordingly!
EZ-RJ45:What kind of crimpers are you using? They look really nice.
EZ-RJ45:
I like them because you can pull the wires through the connector, and then the crimpers shear them off. Normally it is very easy to see that you wired the connector correctly, but not so easy when all of the 'stripe' wires are solid white. The terminations come in 5e, 6 and shielded.
Camera and lens?<snip>
Cisco E3200 w/DD-WRT
Synology DS212J
Trendnet 5-port gigabit switch
Xbox 360
Macbook Air 13" 2012
Telegaertner J00026A0165 (shielded)Do you have a link to the specific part you're using?
But there should be other manufacturers with similar solutions...
Spent all day getting this organized.
Man that is a nice cleanup there..
Have a small update as well.. Cisco 3560e 10 gig switches. Some iSCSI goodness to be had.
i keep looking at this photo....trying to figure out where the hell you plug cables into...maybe it't just too early.
nvm: just googled - appears like there's a flap/door next to each vent.
just curious, why not go nexus 5k route for some 10gig/unified goodies? cost?
specs of the gear?
Newest version of my home setup.
Short-depth wall-mount rack.
Dell 2724 Switch
2x Hyper-V 2012 Hosts
APC 1500 (behind blank plate at the bottom)
What are the chains for? Is the rack suspended from the ceiling? Why?
What is the model apc ups and how many time do you get backup?
Should have gone 4500X man.
Are you going to fully populate the UCS chassis?, if so, what weight is the floor rated for?
