Picked up a cheap 4GB fibre switch off eBay
Don't have the bloody login details though, and resetting it seems like I would need a default PROM password
Wonderful!
I'll answer your question in this forum since it seems most appropriate.how much sq/ft you covering with 15? i cant remember, but are these girls capable of cleanair and all the newest hot stuff? also, what controller are you using?
pics are cool. finding out how they are implemented is even better.(for me anyway)
Original Thread : http://hardforum.com/showthread.php?t=1724443
The 1131AG's I don't think can do the cleanair. Not sure.
I can't give you an exact sq/ft because they are going into different buildings. These are actually to shore up any dead spots we have in our 40+ AP's deployment.
We are using a 5508 WLC running the AP's in H-REAP mode.
That's an fc fabric switch for SAN implementation.
If it's the lightweight version I'd pay your shipping fees to send it to usI got one of those free it's in my drawer now collecting dust
Iv had a nightmare, thought it did FCIP! Oh well cost me very little not a complete loss
Should have researched it all properly first
you do know these cost 500 bones each, why not put it to good use.
Because that would be too easy
One sparkle and you have this neighbourhoods largest barbeque?
It's new insulation so doubt it's asbestos. Looks more like shredded newspaper. I always thought insulation had to have a certain fire rating, but apparantly not. May as well spray some jet fuel up there while I'm at it. The smell will make the mice go away.
We're talking milliamps here though, so I'm not too worried. I do want to find a fuse holder and fuses though to be on the extra safe side. I'll measure the actual current usage and get a fuse slightly higher. Can always throw in an extra resistor too as it will limit the current. It's all logic level electrical so really no need for much current. When nothing is hooked up the board actually goes between 0 and 1 at random since it picks up stray voltages from the air, that's how little current it actually needs.
"so doubt it's asbestos"... assumption is the mother of all fuckups
I think I will put just one for the whole house, given it has like a 400ft range. Later on when I finish up the garage I'll add one in there too. Other one to be given away to the highest bidder
i like those vertical drives on the R720's.
My last place had the R710's and R810's with horizontal drives. Probably no big difference but they just look better.
That could work too.
Anyone happen to know the shape of the signal that these provide? Ex: mushroom, oval, sphere etc... I'm thinking of putting it in the basement but I want to make sure I'll still get optimal signal above it.
Is that the long range kit or the standard one?
hah, you too eh?
I have an AIR-AP1131AG-A-K9 and an AIR-BR1310G-A-K9 with its injector (dual RG-6 Coax, fun!) sitting here...
Do quite like having Linux on my phone. Not too different than my workstation, just with fewer packages compiled for armel. Actually works fairly well for when I need to SSH/telnet into something and get some work done.
*snip*
http://209.144.20.13/misc/12100032s.jpg
If they are the 400ft version it is the standard model. I have the Long Range model and it does 600ft.
Hope that helps.
