I have a couple of those media converters, they work well for their price and what they are...MC220L or something!?
I'll take ladder rack over false floor any day.
after you pulled most of it out and put it in the colo? Too much fun.
So yeah, I present GH1 and GH2, SAMP and Minecraft testing servers.
GH1 is set up so it can be remoted onto anytime, I have people in Serbia and the Netherlands jump on there to test. It's a long story but whenever we wanted to test it was too late my time to fire the ML server up, the netbook is perfect as it's not loud and doesn't use much power. I think it has an uptime of about 2 weeks now, should do some updates. - Specs, Acer Aspire One 751h, Intel Atom @ 1.33GHz/2cores, 2GB ram, 160GB hdd, 2K8 Enterprise 32bit.
In other news, I've been experimenting with different ways of achieving a long run time UPS solution.
Hooking up batteries to an existing UPS, using inverter/relay combos etc... and at the end of the day, ended up buying a Tripp Litte Inverter-charger for simplicity when I scored that find on ebay. Ordered it today. It's hard to find an inverter charger that can switch fast. All the ones I was finding switched in seconds, not milliseconds, and were modified sine wave.
And in case anyone ever wondered, a typical inverter does not sync the neutral to ground. That's kinda what foiled my original plan. I could not find a DPST 3 way relay which I would have needed in order to switch hot and neutral at same exact time to the inverter.
I'll probably end up getting a metal shelf of some sort so I can properly locate the inverter charger and batteries.
I sure hope you are at least running that on a seperate vlan...
Not yet. I't something I want to have a mess around with though. I don't have the equipment to do it since it's all switch based iirc?
And anyways, the people that do go on there are people I can trust. Everything over the lan is protected/passworded, there's no open shares or machines without a password, I made sure of that. The account they use is also locked down; it can only access folders I want t to on the 'server'.
And if they DO get somewhere where they shouldn't be, the hub they're plugged into is under my desk, so it's no biggie to pull the plug on them.
Oh boy.....
Don't you mean "whoops, I own a Tz210?"
woops,
the screws fell out of my SonicWall Tz210
Sonicwalls arn't bad, I've played around with them. I only found they were expensive compared to other solutions but that was a long time ago, things could have changed since then.
Oops you voided the warranty...
Have having a pro 2040 (sonicwalls gen 4 family) I understand why people despise them so much... But really in my opinion the gen 5 models are solid. I compared them to a fortigate and found the sonicwalls to be cheaper for 3 years than 1 year of the fortigate.
Only comes with 1 year warranty on hardware anyways
I can actually setup a sonicwall now properly and with out issues. I've found them to be nice and easy NOW, but when I was starting out and didn't understand them FML i hated it with fire!
If i ever get a decent chunk of change i might get a NFR 2400..
hmmm I was looking at one for a VPN appliance for home ala your idea dash
the netscreen 50 maybe? so sa-1000...they any good? also looked at previous gen fortigates, or an older pix that supports encryption
already did
that tz is way out of my budget
yes I have been thinking about it
i could esxi it or reuse some of my pile of hardware I have laying around
