had same issues some times, switched to Freepbx![]()
CUCM / CME
Good Ole 3CX.. I played with that a couple of weekends ago. Had an IP330 that wouldn't ring when called & an ip430 that still refuses to connect to this day.
Good times
This has to be my favorite bad cabling photo of all time:
Not even if it looks like this ?
LOL!
LOL!
Took me about a day to figure it out. I have a 330 a 650 and two soft phones working fine. I also have SIP trunks going to iCall without issue.
EDIT: I should also note that I configured the auto-provision to update the software on the phone (application + bootrom). I also properly configured the system to disallow connections outside of the LAN subnet. As it will be multi-site when deployed. It's doing well so far, I've only put an hour or so personal call time in/outbound across the 3 types of phones. The server survives reboots just fine also, after about 5 minutes or so, everything is re-registered and it gets back into the proper cycle.![]()
Maybe you'll want to PM me how you got the damn things to ring. Maybe if you had an IP430 laying around too![]()
I hate printers! This picture makes me rage just thinking about having to disassemble the whole bloody thing.
Cutting steel conduit with a chainsaw?
LOL WUT
That's Die Hard, right? The face shield is a nice touch.
Finished my Lack Rack project.
Roughly 16U of Rackable space for the cost of 15 euros
9.90 for 2x tables and rest goes to random materials
Otherwise a retail product exept legs, removed the bottom ends of the legs and put in 2 pieces of 20mm thick plywood (sized 43mm x 350mm each)![]()
where does the fiber go to ?
is that a HP 1800-24?
http://koti.mbnet.fi/ipe91/b/lack/1.jpg
I'm kinda partial to the Dually on top with the mismatched coolers, the cardboard MB tray and the amazingly transparent case![]()
*snip*
Is that usb header custom or something you can get 'off the shelf'?
We've some physical security keys which I'd like to stow 'neatly' without any Heath Robinson cables!
My little home lab for tinkering
i :heart: network ports!
What happens to the people that mess with your cables?![]()
BOOM HEADSHOT!![]()
