how does this 23" nec compares to my u2410?
Do I misunderstand, or are you actually claiming a 23'' screen is tiny and praise a 20''?It's junk. Has the worst anti-glare coating I've ever seen on a monitor and it's also extremely tiny. Besides those issues, it doesn't look anywhere near as good as a NEC 20wmgx2.
I suppose I knew that, but I wanted someone to prove me wrong. It's too bad, I was keen on buying 2 identical displays, but I can only use HDMI and VGA. I think I might follow your recommendation, if I end up going that route.In my experience, connecting a high end lcd over vga is counterproductive. If you are limited to vga source, save some money and get a $100 dollar tn panel like aoc.
I have both the EA231WMi and the 20WMGX2 and I'm quite happy with each one. I plan on replacing the 20WMGX2 with another EA231WMi actually. I've had both evaluated by a few picky friends and they would agree with my choice. For the price, the monitor really is hard to beat.
The EA231WMi and the Dell 2209WA both have the same exact coating. I agree that the coating is a bit harsh, but the 2209WA is just as bad. I don't know why people are seeing differences that aren't there. Some people even said the NEC was better. I had multiple units of each, and there was never any variance in the coating.
Yea right. The ea231wmi looks worse than the Dell 2209wa and the 20wmgx2 looks far better than either of them. The 2209wa has a much better AG coating and doesn't have backlight bleed from all four corners.
I wish i had paid 300$ for it, but not everyone lives in the US. It cost me 350 euros which is more than double the price of an acceptable 23" monitor with a tn panel. What did i pay double for if not for the better colors? Most tn panels i've seen lately are more uniform that this.
I have never found anything amazing with any TN panel, personally I find them borderline unusable. TN image quality is trash compared to even mediocre IPS, don't get me wrong though, mediocre IPS wasn't a reference to the EA231wmi.amazing TN panel
Is the image from the laptop screen cloned in the external monitor? If so, you have to change from clone to extend the working area. What OS are you using?What are the basics to using two screens? I had my laptop set up as one screen and the monitor as the other and wasn't able to move from screen to screen, it must be some simple trick. Does the mouse go from screen to screen, I couldn't get it to? Can I view an excel in one window and a web page in the other? how do I get the mouse to go to the other one to do stuff?
Man, the 23" looks so small at 16:9 next to the 16:10 Dell.
Thanks a bunch, I've gotten 83hz working perfectly. I don't really know what timings to use and how they affect LCDs (I kind of understand how it works for CRTs though). How would I figure out what values to use for 80hz and 75hz?
By the way, for anyone with a 5xxx series card (and you can't use powerstrip), here's the driver. I've only tested it on Windows 7 + HD5850 + displayport. If for some reason it doesn't work, at worst you'll have to either boot in safemode and uninstall the driver or switch to a dvi cable temporarily to uninstall it.
Edit: Aahhhhhhhhhhhh, no more tearing in any games anymore (with vsync off). Even Dirt 2 is tear-free now.
So my 2nd NEC arrived and again it arrived without a single dead pixel or any manufacturers defect, but I noticed the colors on this 2nd one are a bit better than the one I received 2 weeks ago. I have both of them on "standard" and Srgb and cant get them to match. The first one's colors look just a tad bit washed out compared to this new one. I tried to use the window7 color calibrator and cant get them to even out. I can return the first one and hope the next one I order will better match the colors on the 2nd but it seems like such a big hassle to go through when this monitor would be considered perfect to the average pc user.
Anyone out there using more than one of these or going eyefinity? Should I return or just live with this issue? Shouldn't 2 or 3 monitors from the same manufacturer be able to match up with some slight calibration or am I asking too much?
Oh yeah, one is on display port and the other is on dvi. I swapped onnections and that didnt make a difference.
Anyone compared this monitor to the Asus vw246h? I'm thinking of going with the EA231WMi since it seems to be the better monitor but it more money than an Asus.
Maybe it's just me but my EA231WMi gives me serious eyes strain!
I have to take breaks from stairing at it when I work during the day. I'm not sure it's a by-product of the newer IPS technology or my refresh rate? My older S-PVA screen didn't have this problem at all and I could stair at it for hours without an issue. I'm seriously thinking about selling it because of this reason. Anyone else have this issue?
