What fans are those, mbondPDX? Are you getting good temperatures with your C14 setup?
I'm deciding which cooler to get and I've been looking at the C14 but I can't stand the sight of the brown Noctua fans, no matter how good they are!
Ah ok thanks for explaining. I hadn't really considered the possibly of changing out the fans TBH, but I like what you've done. I think I prefer the C14 to the Scythe Kabuto but it is more expensive. I'm assuming you don't have a fan underneath the fin stack; just the two Scythe fans on top?
I was able to snag my C14 for $40 shipped on Ebay.![]()
Ok so I've never built a PC before and I've got a beautiful V2 sat next to me. I've looked around and I think this is going to be my build. Does anyone see any issues with this?
Asus Maximus Impact VII
Intel Core i5 4690K
Noctua NH-C14
2 x Scythe Gentle Typhoons (attached to bracket)
Crucial Ballistix Sport VLP (2x4GB)
Silverstone 600W SFX
GTX 970 4GB Titan Blower Cooler
Samsung 840 EVO 250GB (Boot)
WD 1TB 3.5" Caviar Blue (Storage)
Windows 8.1
I'm not planning on overclocking it, though it's nice to have the option if I need to a couple of years down the line. The main questions I have are with the cooling and fans.
- Will the two GTs be enough to cool the CPU and general case, with a blower GPU on the bottom? I wasn't going to have any fans underneath the GPU, nor was I going to add a 120 underneath the CPU cooler. Will just those two fans be enough?
- What speed do those fans need to be? There's 1450 and 1850.
- GTs are actually quite hard to find in the UK; are there any other recommendations? Should I get PWM fans?
- Also, I was going to add the provided filters to the bracket fans, is that enough or should I buy a Demciflex filter for the bottom of the case for the GPU?
- I'm spending a lot extra for the Titan GPU blower, any thoughts on whether a cheaper ACX would do just fine?
I understand it might be hard to guess, but you've all got a better idea than I do!
Any advice would be much appreciated![]()
Intel Core i5 4690K
Noctua NH-C14
Windows 8.1
At the moment, I wouldn't recommend the VII Impact as the hands-down best board. Enough people on that board's topic have complained about quality issues, some design flaws and some irritating properties you're stuck with. The software might behave but plenty have issues with it to the point it becomes unusable or more of a pain than it is useful.
In my opinion, while owning one, I feel content with it, if it would have cost half of what it is going for now. Because I have a hard time with a $ 240 mITX motherboard when $ 120 boards don't have these issues.
I'd recommend looking at Gigabyte's and MSI's offerings too.
About the RAM: you don't need VLP, but it makes your life easier with more heatsink orientations, now or later. I'd personally recommend 16GB (2x 8GB) because DDR3 isn't likely to become cheaper now that DDR4 is gaining ground.
The 1TB 3,5" HDD seems wasted, with 6TB 3,5" drives available (and 4TB affordable), also the 2,5" 1TB drives cost about the same as the 3,5" but are much easier to install in the Ncase M1.
I wouldn't bother with 3,5" drives inside of the case either, especially seeing as space is at a premium and they probably will only add noise.The 1TB 3,5" HDD seems wasted, with 6TB 3,5" drives available (and 4TB affordable), also the 2,5" 1TB drives cost about the same as the 3,5" but are much easier to install in the Ncase M1.
All three have their merits. I suggest you look through the specifications of all three, choose which has your highest preference and choose accordingly. If one or the other is more than $20 cheaper, I'd probably go for that one.
Do you think is worth buying the Impact VI if i can buy it at half the price of the Impact VII? Or it's better to buy the latest and forget it for a long time. I will be using a 4790k
Yes, the VII is like $380 and the VI $162,5 or $195. Is a big difference..i think i will buy the VI.
Thanks!
I actually do have another GT under there but haven't done any comparisons of temps before and after adding it...
Two GTs will cool a non-overclocked system just fine. You could get by with the 1450 or even lower then that. Having a 3rd fan sitting under the heatsink will help cool the motherboard and its VRMs much better tho.
The 'Titan' 970 from OCUK is a Manli GTX 970. It's the 970 chip plonked onto a reference 980 PCB (with all the 980's power delivery circuitry) and the 980 NVTTM variant (a trio of 'fat' heatpipes in place of the vapour chamber of the original Titan cooler). You could theoretically take a Titan NVTTM and drop it straight on if you really wanted to, but unless the max TDP limit is raised considerably from the current 110%, there's no way you could even get even close to generating the 250w of heat the Titan NVTTM was designed to deal with.Thanks, although I think that 'Titan' GPU I linked originally is a refurb job from Overclockers UK, not sure if it'll be worth the extra money. I was actually wondering - although a blower is recommended - the new 970s draw considerably less power and presumably generate less heat, so could I not just get an EVGA ACX 970 and be done with it? Hard to tell without people testing it I guess
Hey every one. I recently finished a build in a v2 with two 240 rads in it, a gtx 780/water block and, an apogee drive 2. I was trying to decide if i should do a build log or not, there is so many... Would you guys be interested?
A single GTX 780 can't put out enough "load" on single 240mm radiator to go above 80°C (*) or you are overvolting the crap out of the card. My toasty stock R9 290X and stock i5-4670K in the same loop doesn't even hit 65°C with a stock H220 setup and fans at a reasonable level.Have you seen temps better than what people here have been posting for their single 240 stups?
I'm interested in seeying the build too !
The only reason I'd see use for more than a single 240mm radiator in the Ncase is lowering noise but I doubt that would help much with slim fans. You are basically extending the buffer the water cooling setup offers because of doubling the mass.
(*) I mention 80°C because it is below the level the GPU will start to throttle and it doesn't matter a thing in performance if it's -80°C or +80°C. I see many people focussing on lowering temps or going for the lowest possible temps, but hardware is not designed for this, it's designed with a 85-95°C thermal limit (depends on hardware).
Very clean build MrJerico! Surprisingly clean even.Ok guys sorry it took so long. Here it is: http://hardforum.com/showthread.php?p=1041180374#post1041180374
Very clean build MrJerico! Surprisingly clean even.![]()
