Yes. But adding fans make a lot of unnecessary noise. The issue is not being able to control them basdd on GPU temps. Under heavy load it's going to make a lot of noise anyway, but it will make for a more noisy experience when not gaming, which is when the noise is most bothersome anyway.
It'll work, but are you planning to shorten the cables? Because trying to stuff them in the case is absolutely awful and is the reason I don't recommend ATX+long GPU. Mod the cables or don't do it, IMO.Hey guys, what do you think about this psu for my build: FSP Group AURUM S 600W ATX will it fit inside the M1 v3?
Also I think it's 140 mm deep so I should be able to use a long gpu with it right?
I'm looking for a good and quiet ATX PSU that can power a 4790k + GTX 970 both OC'ed on air, to hold me at least until the SS SX500-LG arrives, since the only good SFX one right now seems to be the SX600-G but it has noise issues i've heard...
The ST30SF quite happily runs my E3-1240 and 970 at idle with no audible noise (well below the H75's pump noise, which is the only audible sound source at idle). The no-fan-at-low-load function actually works unless you've been running at high load recently (takes 10-15 minutes after full-load running before the fan shuts down again).I think it's sad we have to advice people to get an ATX PSU just for some noise-free and quiet SFF computing in idle
I'm personally hoping the SX-500LG is going to put an end to this "there is no quiet SFX PSU"-issue, even though it's SFX-L. I think it's sad we have to advice people to get an ATX PSU just for some noise-free and quiet SFF computing in idle, but we can't deny the problems with the two most viable SFX options: the Silverstone ST45SF-G and SX600-G.
So with that cable the GTX 970 would control say a Noctua NF-F12 industrialPPC-2000 without any issues?
Urelure, I agree with your suggestions, getting a short GTX 970 and fit a 120mm fan under the heatsink. With an adapter cable you're even able to utilize the GPU's fan control with a PWM fan.
it seems, the 24,14 was for the insured package.
seeing as you are having a 3.5" HDD you will not need 4 120mm fans, and what are you doing for CPU cooling?
-Fans: According to the M1 site, there are 4 120mm mounts, and 2 80/92mm mounts. I was thinking of replacing all the stock fans with Noctua's, or in the very least, maxing out my fans. Any advice on the brand/number of fans?
Will recieve my GTX970 this week and just realized my Silverstone ST45SF-G doesnt have the 2x PCI-E cable, ie. the one that splices into two 6+2 connectors.
Ive got the tools to make my own cable with two 6pin plugs at one end by using the included cables but is this the recommended procedure or would it be better to share the load from one of the other outputs?
waiting for my v3 case... ETA late december. the wait is killing mestaring at my components is rough, you guys.
Guys, what would you recommend for a completely quiet (but still air based, so quiet to an extent I guess) NCASE build? I just pre-ordered v3 and I'm slowly completing the rest. I'm having trouble deciding which fans to order (noctuas seems to be most efficient, but there's a lot of them to choose from), I'm not sure about the exact fan placement as well. Looks the case has a lot of spots to mount the fans. It's been a while since I builded a PC. Many thanks for any kind of feedback.
I know the feeling! Really hope you spent the extra few bucks for air delivery instead of the slow boat![]()
Don't repeat my mistake with the ASUS Maximum VII Impact. I think we documented it a lot in the ASUS Maximum VII Impact thread. I would get the MSI Z97I GAMING AC if I were to do it over again, and I would recommend that over the ASUS M7I definitely. There's just too many issues with the daughterboards and quality control. For the price premium over the MSI and others, I would have expected ASUS have better QC.Guys, what would you recommend for a completely quiet (but still air based, so quiet to an extent I guess) NCASE build? I just pre-ordered v3 and I'm slowly completing the rest. I'm having trouble deciding which fans to order (noctuas seems to be most efficient, but there's a lot of them to choose from), I'm not sure about the exact fan placement as well. Looks the case has a lot of spots to mount the fans. It's been a while since I builded a PC. Many thanks for any kind of feedback.
Edit: I was thinking about the airflow and components as follows:
Motherboard: Asus Maximum VII Impact
Storage: Samsung SSD 850 EVO 512Gb
PSU: Silverstone SFX 600W
CPU: 4790k + Noctua C12P SE14
GPU: GTX 980 reference blower
Bottom fans: 2xNoctua F12 low noise adapter
Rear fan: Noctua A9 92x92x14 low noise adapter
+ a set of dustfilters from http://www.demcifilter.com/c220/NCASE-M1.aspx
More details: not planning to overclock, probably going to mount a temporary 750ti and wait for 980ti / 390x to come out.
Would that make sense, along with aiming for the lowest noise possible? Additionally, I think that the 980ti / 390x should fit without issues into M1 v3.
that's pretty interesting. serious (noob) question, wouldn't having the bottom intakes with fans help with a positive airflow?I think many folks here pointed out that it didn't do much for the temporary.
I don't exactly know the physics of it, but it might be that the case is too small in the first place, too small to make a difference. But I'm just going by other people's temperature reports.that's pretty interesting. serious (noob) question, wouldn't having the bottom intakes with fans help with a positive airflow?
