It's worth noting that the fan control/rpm setup will be different between the cards. You'll want your exhaust fan specs to fit with those in the BIOS of the card.no real difference between a blower and founders edition right?
looking at one of those(Pny blower, zotac blower, 1080ti founders) or the armor oc for the accelero.
I installed the Accelero on a FE card and had to flash it with the SC2 BIOS to get any proper fan control since the blower has way higher min/max rpms. Using one of those (silly) fan control apps often won't be enough. Using a physical device to modify the PWM signal is also a route. I really miss the previouis genereation's BIOS editor which would give you full control.
Here's my setup of the Accelero IV w/backplate:
https://imgur.com/a/13nsI
