I have looked at the detailed spec for GPU compatibility and not previously noted the limitations on 2.5 width cards. My card is 302.5x110.5 and 2.5 slot. I think it should just fit - can anyone else comment and confirm they agree?
https://m.imgur.com/5fktEW1
It’s the ‘maximum length of card in slot 3’ dimension which is troubling me. Does this mean ‘maximum length of a tall card in slot 3’?
It’s not a massive problem if the card won’t fit but if I can stick an Accelero on it - at the very least it will reduce the 2.5 to 2.
Thank you I managed to find a source but it doesn’t seem to be picked up by pcpartpicker which is odd.
