I am in the same country, and was able to get a replacement from my retailers (Digitec, Steg, ...) with the couple defect mobos or HDD I had bought.I am in Switzerland, and unfortunately for me, there is no law protecting the customer in Switzerland. Retailer can sell material without giving any direct guarantee, so we have to handle with manufacturer. Usualy, manufacturer applies direct RMA and I never had any trouble with that. I tried RMA with Canon, Onkyo, Philips, Asus, and all the time manufacturer was able ti deal with enduser.
For me, I smells like the end with Gigabyte.
My bad, only just seen the pics. Looks clear that you can use two 3.5" drives in the HDD cage but I'm still not sure which side mount you are referring to that is being blocked.![]()
im still waiting for the NCASE manual to be made
The "tall" heatsink, as seen in the photos, occupies space that could accommodate a second HDD cage. Instead, I put the second cage on the floor of the case, which then blocks the (unneeded, in my case) PCI-E slot.
So, if your question is "can I fit a tall HSF, two HDDs, and a video card in the case?", the answer is "yes". As long as you use a SFF PSU. I think if you use an ATX PSU you wouldn't be able to use the HDD cage on the side mount where I have mine. But ncere would know for sure.
As iFreilicht suggested it, you better call or even go see them if possible.
At what shop did you buy your Gigabyte motherboard?
Shame on them indeedThe shop was Techmania. I called them, I wrote to them, and they dont want to hear anything but to deal with the manufacturer directly. A shame.
Sehr geehrter Herr
Die Überweisung zu Ihrem Auftrag xxx, wurde soeben vorgenommen.
Kingston KHX6400S2ULK2/4G Fr.76.80
Da wir das in File mache und immer am Freitagmorgen abschliessen, werden Sie den Betrag am Montag oder Dienstag auf dem Konto gutgeschrieben haben.
Wir möchten uns nochmals für die allfällig entstanden Aufwände entschuldigen und freuen uns, Sie bald einmal wieder auf www.techmania.ch begrüssen zu dürfen.
Ihr techmania.ch-Team
Administration
Doris Meier
The next version will indeed be designated V5, and the only change is the front USB ports will be black and have a slightly cleaner appearance (no front edge flanges).looks like i'm waiting on the next production run
hope it's not too far away. are there likely to be any changes from the v5?
Nox
And from what I can tell, that is how most people do it.
You could get an adapter like this one:
http://www.amazon.com/CablesOnline-20-Pin-Motherboard-Adapter-USB3-AD23/dp/B00EAXISZW
Moved my server into the ol' M1 V1 last night. The Noctua NH-D9L, as expected, allowed me to fit a slim 140mm Prolimatech Ultra Sleek Vortex fan above it as intake.
Yeah, just an aesthetic change. The revised cable is a drop-in replacement, so we can offer them separately if there's interest.so just aesthetics? is there going to be an option to upgrade to this for older cases?
Asus GTX960 Strix fans and shroud removed - replaced with 2x Noctua P12's. One running off GPU fan header, the other running off Mobo fan header.
Tested with 5 mins of FurMark (1080p)
With factory Asus fans/shroud (and 1 Noctua fan in bottom of case):
GPU 73deg (graph flattens out at 72deg after 2mins)
Asus Fans = loud, Noctua fan = near silent
With only 2x Noctua fans in bottom of case:
GPU 80deg (graph flattens out at 80deg after 2mins)
Fans = near silent
So, this should be acceptable for gaming if stress testing has the GPU max out at 80deg. With the benefit of no more Asus fans spinning up to loud levels.
http://i.imgur.com/nU3I8lvl.jpg
http://i.imgur.com/usbUGaBl.jpg
http://i.imgur.com/MjJvenzl.jpg
Nox -nox said:... looks like i'm waiting on the next production run. :-(
And the USB 3.1 specification makes no distinction between Gen 1 and Gen 2 Standard-A, other than specifying stricter requirements for Gen 2 cable assembly signal integrity: http://www.usb.org/developers/docs/usb_31_102015.zip (USB_3_1_r1.0.pdf in that file)
Oh god, even stricter? Does that mean the front panel cable will get stiffer still? Because right now it's pretty much unbearable already, at least for really small cases.
