Hi everyone
Thanks to Wahaha and Necere for making this absolutely amazing case possible. I love it. want to know how much? I am taking this over my original reservation for the Murderbox M2
Aw, poor Murderbox. Charles actually dropped us an email a few months back congratulating us on the project. Thought that was nice of him.Thanks to Wahaha and Necere for making this absolutely amazing case possible. I love it. want to know how much? I am taking this over my original reservation for the Murderbox M2
Probably the toughest build you could do in this case. Hope you're in for a challenge!Anyway, after getting my order in for rev2, I've been combing through this thread and have more or less made up my mind about my summer build. I'll be upgrading from an 2500k based build to a 4790K with full watercooling. and by full watercooling, I mean dual 240mm rads, one with mid-high fin density on the side, and a thin fin one on the bottom with the 15mm prolimatech fans.
I hadn't heard that the AD2 had a high failure rate... it's more or less an upgraded Laing DDC, which is one of the most commonly used pumps for watercooling out there. I'd be very surprised if water temps were getting anywhere close to 60C in any loop.I think the apogee drive II would be a better option than the H220 to drive the whole loop, but I've noticed more than a few users having problems with the apogee (the H220 has it's own problems). I dug a little deeper and saw on the spec sheet for the Apogee drive II that it is only rated to function at up to 60 degrees Celcius, could this be why so many users are seeing their Apogees fail?
http://www.swiftech.com/ApogeeDrive2.aspx#tab3
There's a build with an EK res in the user build gallery (black/white/blue, about halfway down). The rear mount is a standard set of 92 and 80mm fan mounting holes, so any res with a suitable bracket will work. Koolance has tube reservoirs with a bracket that should work.The other common problem with water cooling in the Ncase seem to be the poor quality of the custom rad. So I was wondering if something like the EK X3 res would work on that slot? people have mentioned that they were using it, but I could never find any pics, especially regarding the mounting. would the vent holes on the back of the Ncase or some of the fan holes line up perfectly for the EK X3?
This for this build to happen, I noticed two concerns: I think the apogee drive II would be a better option than the H220 to drive the whole loop, but I've noticed more than a few users having problems with the apogee (the H220 has it's own problems).
For some reason it's a typo that happens a lot. He meant "res," of course, and the FrozenQ M1 res specifically.Not sure what you mean here, could you elaborate?
Phoenix, I guess I"ll be joining you in the double rad club once all my hardware are ordered and sitting in my den.
I really liked the refinements Intel has done on the i7 4790K, and figured that a double rad setup will really show me its full potential. on the GPU side I'll be rocking my trusty 7970 (I think it may even be a first edition, got it in January of 2012 LOL) until Maxwell comes along. just felt better about getting an $100 waterblock for it and wait, rather than go through all the trouble (and cost) of getting an 780 ti now and be all jelly of the maxwell folks come 2015
The rads will fit but the tubing might be hard to run down to the GPU. There's a build in the gallery with a CLC on a short GPU.Is it possible to mount two 120mm AIOs (h60) in the place of the 240mm rad space? Or anywhere else?
W360 wants to keep the number of SKUs down for the Taiwan-originating shipments. So other parts may not be available until later.Will there be kits like the new side bracket that allows 3.5" HDD to be mounted in both positions, or the new 2.5" brackets?
Yes, the panels are interchangeable between V1 and V2. Correction: V2 top panels are not compatible with V1 front panels. Other panel combinations are okay.So the "screwless no ODD" can be placed on a version 1 without issue ?
*finger on the order-button*
Phuncz, I'm sorry, I made a mistake. There were some very minor adjustments to the panel dimensions between V1 and V2 so they fit a little better, but one of the side effects is that the V2 top panel is slightly too wide for the V1 front panel. None of the other panels are a problem. If you've ordered it already and want a refund on it, just drop us an email requesting it.Yes, the panels are interchangeable between V1 and V2.
The ironically fortunate limitation of needing to save some more for my build means I'll be ready to buy parts when Broadwell is out and Maxwell is likely to be released - if not close enough where waiting is justified. In the interim, I've been giving layout and part selection a good amount of thought, but my experience with watercooling is quite limited & dated. I have plenty to learn!
Not at this point, I think. It complicates things from a logistics point of view.Is it possible to add the panels to are existing orders to save on shipping?
The panels will be produced alongside the M1, and shipped at the same time. We do plan on ordering more than are ordered before June 22nd, which will be sold through the website once they get to the US.are these panel orders completely separate from the current Ncase rev2 production?
what I mean is: will the panel orders still be available after June 22nd? and have you guys basically ordered a panel bundle from LL, and they'll be sold while supplies last?
Yes, as noted in the disclaimer I've added to the order page.A full V2 kit will still work on a V1 case though right?
M1 Panels Kits/Top Panels
By popular demand we've added panel kits and individual no-ODD top panels to the site for preorder. The order page can be found here.
That aside, there are rumors that Intel may skip desktop Broadwell and go straight to launch Skylake at Computex or later in 2015, which could make sense since the main delay for Broadwell was the move to 14nm process, and production of mobile chips will make sure that the process is mature when Skylake production starts![]()
though all in all, the power savings from a 14nm CPU plus 20nm GPU will probably make our double 240mm rads seem overkill
Are the weld deformations obvious? IMO you really have to be looking for them in the right lighting to see them at all. But there's no change to the process or material thickness, so I guess if it bothers you now the new ones won't be any better.About the V2 panels, any chance they will have less warping?
What about the spot welds for the pins, any chance they will be less obvious on the outside?
It looks like they didn't move the socket or the south bridge at all. I can see EK slapping a new certification on their VI block :crossedfingers:
The new Fractal Design Kelvin AIO liquid coolers have standard G1/4 fittings and look like a decent alternative to the Swiftech H220/CM Glacer 240L for expandable loops:
Pic from Sweclockers
The 240mm rad at 275mm x 30mm should fit nicely in the M1 (specs).
As for warping, again, the process and materials haven't changed. What has changed are some small adjustments to the panel dimensions which make any warping that is present less apparent.
Made with enthusiast-grade components in cooperation with Alphacool
To avoid Galvanic corrosion of the water cooling loop, the Kelvin Series water cooling system is constructed with pure copper in the radiator
Available with a triple fan radiator, a 30 mm thick 360
The top panel is about 0.5mm wider, which pushes against the side panels when they're on. If the side panels are slightly bowed, it will push them flatter. The front panel is also slightly wider, which minimizes any apparent bowing out at the ends of the side panels.Can you explain a bit more about the adjustments to make any warping less apparent?
