My 8700k box arrived smashed! Pics of the devastation! Updates
Discussion in 'Intel Processors' started by craigdt, Feb 27, 2018.
  1. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    [​IMG]
    [​IMG]
    This was the $313 Walmart deal.
    Came in a padded envelope.
    Is this going to be an issue?
    Do I need to send it back?
    {NG}Fidel likes this.
  2. Kwaz
    Kwaz Whine & Cheezy
    3,954
    Sep 3, 2014
    Survey says: Yes
  3. Chimpee
    Chimpee [H]ard|Gawd
    1,470
    Jul 6, 2015
    I would complain and send it back to them.
    ChoGGi and Armenius like this.
  4. tangoseal
    tangoseal [H]ardness Supreme
    8,183
    Dec 18, 2010
    I wouldn't... its just carboard. Fire that thing up and hopefully its golden!
    I am waiting to replace my 8600K with a new *Lake whatever will be better in the near future, until then I am extremely pleased with the 8600K.
    OP there is nothing in the box. There is no cooler. There is nothing to be damaged. The silicon chip its self is insanely tough for what it is. It will work 100% just fine. Enjoy your new chip. Remember all that packaging is meant to take the blow instead of the device inside it. I would say that it did its job just fine and dandy. There are no pins to break and the chip is in a static resistant clamshell that it's self is rather strong.
    Let us know how it performs you in [H] style :p
  5. If you think its damaged, I will take my chances and easily swap you a barely used 6700k ? ;)
    Armenius likes this.
  6. DeChache
    DeChache The ONE - Your Ignorance Annoys Me
    6,965
    Oct 30, 2005
    I would just use it. I got an open box 6700k that ended up floating around in a box with nothing but a anti-static clamshell on its way to me and it has been fine
  7. Master_shake_
    Master_shake_ [H]ardForum Junkie
    10,404
    Apr 9, 2012
    wow a padded envelope.
    at least some people have the decency to throw it in to a way too big box and put 2 of those air pillows in it.
  8. To be honest with you, I wouldnt be that worried about your cpu, I’d be more worried about the cat that came out the box instead.
    zerogg, AlphaQup, c3k and 10 others like this.
  9. NobleX13
    NobleX13 2[H]4U
    3,214
    Jun 15, 2010
    You should see some the shit I have purchased from eBay and Craigslist. I got a G3820 once that was packed in paper towels... Ugh.
    I also bought an i7-3770 recently from some dude in the ghetto that had a little chunk missing out of the corner... He obviously dropped it.
    Armenius and DeChache like this.
  10. pendragon1
    pendragon1 [H]ardForum Junkie
    15,250
    Oct 7, 2000
    chip looks fine. build it, oc it, post pics.
    Denpepe and kirbyrj like this.
  11. kirbyrj
    kirbyrj [H]ard as it Gets
    25,160
    Feb 1, 2005
    I wouldn't. They are likely to refund your money and not give you another one at the same price. Unless the chip was outside of the plastic packaging bouncing around the smushed box, I wouldn't worry about it.
  12. Chimpee
    Chimpee [H]ard|Gawd
    1,470
    Jul 6, 2015
    That is certainly true, but I probably imagine Walmart will just send a replacement. While it is a matter personnel preference, if I see a package this bang up, I would just return it. I do see you can just test it first to see if it works and just return it if it is broken.
  13. kirbyrj
    25,160
    Feb 1, 2005
    They aren't going to have anywhere near as stringent a return policy as electronics stores, so it doesn't hurt to test it.
    Chimpee likes this.
  14. SticKx911
    SticKx911 2[H]4U
    2,266
    Mar 14, 2004
    Test the oc. Good, keep it. Terrible, return it and try your luck again at the silicon lottery. :)
  15. Batboy88
    Batboy88 Limp Gawd
    323
    Dec 25, 2017
    the chip is probably fine dude...
    Speedeu4ia likes this.
  16. Speedeu4ia
    Speedeu4ia Limp Gawd
    392
    Aug 7, 2017
    not without replicating the deal again for store pickup
  17. kirbyrj
    25,160
    Feb 1, 2005
    99% (probably 100%) of Walmarts don't have them in stock. I've never seen CPU's at any Walmart. You'd have to work through the website to replace as if you go to the store the only option is going to be to return it.
  18. demondrops
    demondrops Limp Gawd
    423
    Jul 7, 2016
    nice deal lol they go for more like 470 here in norway :eek: if product is undamaged i guess the package did it's job? maybe u could run it and check how well it oc and if it blows just send it back haha :D
    craigdt likes this.
  19. Batboy88
    Batboy88 Limp Gawd
    323
    Dec 25, 2017
    shoulda of saved a few bucks and found any decent z170/z270 6700k or 7700k still...
  20. DrLobotomy
    DrLobotomy [H]ardness Supreme
    6,534
    May 19, 2016
    How are you going to know if someone didn't infect it with a virus?
    Oh nevermind, I forgot it comes with Meltdown enabled. Carry on....
    thebufenator, Chimpee and kirbyrj like this.
  21. matt167
    matt167 Gawd
    904
    Dec 18, 2016
    That is true, except Walmart ships things to the store for pickup, for free.
    Armenius, Speedeu4ia and craigdt like this.
  22. mothman
    mothman [H]ardness Supreme
    5,206
    May 28, 2009
    If you return it it's very likely that the replacement will come from the same vendor, in the same padded envelope, subject to the same squishing.
  23. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    Thanks for the input!
    I thought about going with the 8600k, but... I didnt want to miss out on the hyperthreading that I'm used to with my current 3770.
    At least thats how I rationalized it :ROFLMAO:
    Snowdensjacket likes this.
  24. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    Yeah, awhile back I ordered a Core 2 Duo from ebay that shipped just in the clamshell within an envelope.
    Thanks for reminding me
  25. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    She is the face of evil. In the most loving of ways.
    Deleted member 133315 likes this.
  26. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    This build was not about saving money, sadly. Depending on who you ask.
    Batboy88 likes this.
  27. craigdt
    craigdt [H]ard|Gawd
    1,040
    Oct 27, 2016
    Walmart has been advertising their online store, showing beautiful blue boxes showing up on people's door steps.
    My order from them showed up in a squished white envelope, looking like someone used it for a doorstep.
    I am greatly disappointed.
  28. deaedius
    deaedius Gawd
    970
    Jun 18, 2014
    That is a sick deal on the Proc though. 313 for a squished box beats the 410 I paid for a square box!
  29. Shintai
    Shintai [H]ardness Supreme
    5,691
    Jul 1, 2016
    Its just the cardboard and you got a picture of it in case there should be anything wrong. No need to return it for that.
    Speedeu4ia and Sancus like this.
  30. rive22
    rive22 [H]ardness Supreme
    4,611
    Mar 10, 2004
    It looks fine, the box did it's job.
    If there was a HDD in there that would be a diff story.
  31. mouacyk
    mouacyk n00b
    57
    Dec 5, 2015
    Don't waste a chance to bin it...
    mls1995 likes this.
  32. chrcoluk
    chrcoluk [H]ard|Gawd
    1,214
    Jul 7, 2008
    looks a big box, I thought K chips now came with no cooler and small boxes as a result.
    I would still try the chip, and just use the box condition as an excuse to return it if the chip is a dud.
  33. chrcoluk
    1,214
    Jul 7, 2008
    if you want to save bucks an 8600k is better than a 6700k or 7700k. hyperthreading is overhyped.
  34. rive22
    4,611
    Mar 10, 2004
    my audio, video, and rendering apps loudly assert otherwise
  35. cjcox
    cjcox [H]ard|Gawd
    1,386
    Jun 7, 2004
    Package it up (with better packaging) and mail it to me for verification testing. I'll put it through 10,000 hours of testing. Afterwards, I'll give you my assessment and send it back. No charge. I'll even pay the shipping.
    craigdt likes this.
  36. Gasaraki_
    Gasaraki_ Gawd
    617
    Oct 27, 2016
    No. It's just the box.
    kirbyrj likes this.
  37. vegeta535
    vegeta535 2[H]4U
    3,557
    Jul 19, 2013
    This isn't a AMD CPU with pins to worry about ffs. As long as you can see it is not split in half or really bent which would likely require a lot of force you should be golden.
  38. Kwaz
    Kwaz Whine & Cheezy
    3,954
    Sep 3, 2014
    Riiiiiiight.
  39. thesmokingman
    thesmokingman [H]ardness Supreme
    5,607
    Nov 22, 2008
    The box doesn't mean jack. It's the cpu inside the clamshell that matters.
  40. Mega6
    Mega6 2[H]4U
    2,638
    Aug 13, 2017
    This. It's a fkn box.
