Like I said, I'm pretty sure it's an intentional leak. MS has a history of these "accidental" leaks at the beginning of major product launches. The keys never get deactivated.
If it was intentional, I'd expect them to require outlook.com addresses since they've been pushing people to migrate to outlook.com.
I think you're expecting a lot of the Office division to try to push adoption for the Outlook.com folks
Are these single licenses? Could I install it on my PC and also my laptop without issue?
according to the FAQ its either 2 PCs or 2 MACs https://www.microsofthup.com/hupus/faq.aspx?culture=en-US
Deal is dead, don't bother trying.
Slickdeals thread seems to have been deleted rather than moved to their dead deals section, wonder if MS shot them a message?
If you use the 64 bit installer on a 64 bit OS or 32-bit installer on a 32-bit OS, it'll be in Program Files\. If you use the 32-bit installer on a 64-bit OS, it'll be in (x86).
I use Office 32-bit just to make sure there are no compatibility issues between my desktop, laptop, work computers, and school computers. Really no downsides to doing so.
The SD thread is still there.
Where'd you get Visio?
This deal is not dead.
If you have a valid company code it still works.
I just tried it with my wife's employer and I was able to get Office, Project and Visio.
I was able to use my hotmail account, and i got a email with a link, but when i try to add to cart, it just takes me to the checkout window telling me i need to add somthing to the cart so i can check out
When I click "add to cart", a popup tells me I must first search or browse for an item. Any suggestions?
So I jumpoed on this the other day, and well I really want a way to switch this back to a traditional interface.. This fucking blows..
Yeah, move on. The deal is dead unless your employer has a code you can use for this.
They do. Where would I find said code????
Click on the "I don't know my code" link and it will then let you just enter your work email address.
You will then receive an email from MS in your work email provided that your company is signed up for it.
