HardOCP News
[H] News
- Dec 31, 1969
What's up with all the high tech traffic light concepts lately? I think this one is cool because it incorporates everything into a single twisted light.
I can't imagine how expensive this would be.
don't sweat it, your insurance will cover it if you run one over...![]()
looks cool but unless that shit is going to save a city money in the long run, cities should not be tempted to spend money they probably don't have.
Another note: What of color blind people?
The Mobius Strip would just be the inspiration for the concept, not the actual implementation.It is pretty cool, but what does it have to do with a Mobius Strip?
1) Note the size of the LED screen. It would be very easy to incoporate positional/size/pattern data into the display. In fact, I don't think anyone noticed that the pedestrian display is showing a different pattern for green.1) no positional data = fail. it's not just a problem for colorblinds, it is a serious issue in certain lighting conditions for all of us.
2) countdown means taking your eyes of the road for long periods of time = fail. in normal lights you can just use peripheral vision to see any change. big countdown clock means constant changes.
3) no concession for multiple lights = fail. in normal lights it's easy to just put a few together and use lighted arrows above to indicate direction. how will it work here?
4) street light nearly flush with pedestrian light = fail. at night nobody will ever see the actual color because of glare.
5) street light has unprotected angled spill = MAJOR fail. at night the glare will absolutely demolish the ability to see anything on your front-right (or left).
6) lights usually come in pairs, one before and one in the intersection. so you need another design, higher and without the pedestrian and street light = fail.
These weird designs you see are not meant as actual products. They are made as projects for portfolios and assignments by design students.
This assumes pedestrians will be walking directly toward the post. For this to be useful as a traffic light, it would have to be positioned ahead of traffic (and to the left of a crosswalk). That does mean the streetlight doesn't illuminate the walk, though.In the Mobius strip design, I noticed that in the rain, water will fall off the top of the light on the pedestrians walking below. The twist should be angled the other way to direct rain away from the pedestrians.
The colour shouldn't be that confusing as it would presumably be 'pointing' in the same direction as traffic. I would agree that a different symbol should be displayed for pedestrians, though. Again, LED screen--simple.Also, I don't like the fact that they are using red and green for the pedestrian light, that makes it slightly more confusing. They use a different pattern, but why not just use a totally different color scheme or symbols instead like they currently do. A white stick figure would be better.
I've seen the price tags of the more standard lights that are in use. Yes, they are expensive. It depends on all the features it employs. Then the timer, sensors, and all the rest of the crap that goes with it.Would it be that expensive? It doesn't need the twist and all that. I like the idea of using one pole for everything. A cheap variant would be to use existing traffic lights, with the street lamp and crosswalk signals attached.
But yeah, a complete replacement would be expensive.![]()
just wanted geek cred from the reference.
Still it's not any better than what we have. And the cost saving benefit doesn't make sense. Just stick a street light on our existing traffic lamps. The count down idea is stupid. Also, I was looking at the comments on that site... lol @ the guys saying it won't work for the colour blind. You can't get a drivers license in MA if you can't tell red yellow and green apart..
