overlord20
- Feb 5, 2010
The server I am on just bypassed notches server so we can play on a test for now. Have to log in after we join the server.
So just logged in....all our stuff is gone?...What did I miss?
Without a regular reboot, the server just crashes. Notch doesn't care about memory leaks I think.. Oh well..
The HashLand server is back up. I will also be rebooting the server around 8 - 11AM EST Sunday so that the server doesn't crash mid day on Sunday when most people are at home and not working. I cannot determine when it will crash, but it is somewhere within the 12 - 18 hour mark.. The server just takes a massive shit and dies, and I gotta pooper scooper the bastard back to life..
I'm on vacation as well for those who don't go to my forums, so I am not going to be readily available for the next week or more. I will keep checking the forums and will post there any changes or updates I may add or change.
Cheers
I look forward to the day when I check this thread and everything in the Minecraft world is stable and happily moving along for days and weeks without a problem. Then I am going to start playing and begin making the epic dungeon that I always wanted to make and probably get fired for showing up to work late after staying up until 5AM.
im not sure if this is against the rules, but i do have a 20 slot minecraft server im hosting on a vps, that i would like to share to hard forum membersyou can register and get the ip at http://shrapenellodge.com
it currently is using hmod version 134 and running logblock, worldedit, worldguard and LWC (chest protector) and im using mc my admin on it
ip: mc.shrapnellodge.com
Doesn't inspire confidence if you post here for folks to check it out and then neither http://shrapenellodge.com nor the MC server are actually up.![]()
Built my first water ladder system today..pretty spiffy. Currently goes from L10 to L71 very quickly:
http://www.newoldie.com/forumpics/mcwatervator.wmv
This week, Zero Punctuation reviews Minecraft.
http://www.escapistmagazine.com/videos/view/zero-punctuation/2680-Minecraft
Hysterical review.
Oh cock!
Oh Balls!
It's safer if you start digging from your basement and add lights as you go.Played MC all day (single-player). Then the plows came by and threw up another 4 feet of snow on the bottom of our driveway. I went out to clear it and broke out last shovel.
Now I have to go mine iron and collect wood.
dogXchain found a spider spawner. Im abusing it![]()
I have a 19x19 generator that has 11 floors and it's working fine. I saw Maqzzz's mob factory and it only has 1 block of water to transport mobs into the dropper, that's not nearly enough as mobs can easily get out and spiders won't even fall in. My water is 3 blocks wide and delivers mobs to the dropper without fail. I didn't count the drops but there's a steady flow of loot once the factory gets going (takes about 3-5 minutes to start up once I position myself at the collector).
