uuugh amd, get your shit together ffs. Its barely faster that my GTX. fucking pathetic.
Well the Radeon 7 sits right between the GTX 1080ti and the RTX 2080 so that's pretty good. It would be nice to see some frametimes or min frames of those.
as far as the RTX On vs OFF video posted earlier...I saw people jumping up and down saying it's a night/day difference...you guys need to get glasses or I'm guessing you have an RTX card currently so you need to defend your purchase...
yeah if you have a 2080ti you really need a 4K or at the very least a 1440p monitor to take full advantage of it...otherwise all you need is a GTX 1070 or 1080 for max 1080p quality
Indeed. Once my taxes come in I'm going to pick up a 1440p standard or ultrawide monitor. I'd rather go 1440 high refresh rate than 4K 60hz and most over 60hz 4k panels are 27", more than I want to pay for a monitor, or have TN panels (all the above in some cases). Just not worth it right now unless I want to put a TV on my desk again.
as far as the RTX On vs OFF video posted earlier...I saw people jumping up and down saying it's a night/day difference...you guys need to get glasses or I'm guessing you have an RTX card currently so you need to defend your purchase...the biggest differences in that video came from the Exodus built-in benchmark and cut-scenes...in normal gameplay the difference is not anything special...yes it looks more realistic but there was a lot of variance from scene-to-scene...character close-ups with light bouncing off the snow look a lot more realistic...but overall it's not anything jawdropping that 90% of people would notice while playing
I just bought the code off CDKeys but can't preload it on Steam! Guess I have to wait until it goes live on the Epic Store tonight.![]()
If you're in the US, you just got ripped off. The game is only $50 on the Epic store vs the $56 CDKeys is charging right now.
Hardly a "discount". The issue is that for some reason third party key sellers are actually charging MORE than $50 for their epic keys.
I was hoping to get a good experience outta this game on my 65" c7 oled but it looks like my 1080ti may struggle a bit, as expected. I wonder too how much the extra inevitable input lag with this tv will bother me.
If I made more money I'd buy a 2080ti and an X27 just for this bitch.
Still super pumped.
Shading rate isn't super-sampling per say. I had to look it up, and it's a bit different, but basically that's what it is.
I'm not sure what AA is being used outside of DLSS. I know it's being used - Because the performance difference between DLSS On and DLSS Off is fairly noticeable @ Ultra settings @ 4k. Unfortunately because of the HDR issue, i'm having to run DLSS off, which lowers performance enough that I have to drop shading rate to 80% if I want to keep ray tracing enabled.
This page is good reading. Good tips already.
I bought the game from Epic.
So far I have had no issues with the purchase.
I opened up the library page this AM and there was the game.
My download speed this AM at 6.45 EST was about 75% of what I generally see, but hey, I'm at work and the game will be ready tonight.
Anybody know if this game supports SLi??
DLSS renders the game at a resolution lower than your selected resolution and then upsamples the image to your chosen resolution using a deep learning algorithm. What resolution the game is rendered at is not disclosed. With how blurry the implementation is in BFV I would imagine it's 1920x1080 or even lower. NVIDIA locks out DLSS to certain resolutions based on the model of your video card, so DLSS only works at 4K on the 2080 Ti. The 2060 and 2070 can use DLSS at 1920x1080 and up. DLSS is only officially supported for 16:9 resolutions up to UHD 4K at this time.can someone explain DLSS for those without RTX cards...in Exodus there's no AA option at all...in the previous 2 Metro games there was an SSAA option...does that mean that any game that comes with DLSS will not have any other AA method available for those without RTX cards?...and if another AA method is available (if I have an RTX card) can I choose both DLSS and whatever other AA option there is (for example TAA + DLSS)?
there is a 'Shading Rate' option in Exodus which I guess is the same as super-sampling
I don't know, I was just answering your question of what DLSS is. Does forcing AA through the NVIDIA control panel work? Using an injector like SweetFX?but will there be other AA options available for those without RTX cards?...Exodus doesn't have any AA options...the previous 2 games had SSAA (even if it killed performance at least it was available)...and will people with RTX cards be able to use DLSS + another AA setting like TAA together?
the DLSS implementation is just as blurry in Exodus from pictures I've seen...
https://www.guru3d.com/articles_pages/metro_exodus_pc_graphics_performance_benchmarks,8.html
A Russian site yesterday had a small Q&A with one of the Metro devs...they stated that SLI/Crossfire will be available soon with a driver update since DX11 has to be turned on with the video card companies. mGPU support will be available in a few months once the DXR/DLSS issues are worked out and tweaked. I am trying to find the article since it was posted on Twitter yesterday.
