pixelbender
- Apr 13, 2005
I have a launch-time DreamCast and a ton of games I bought during and after its lifetime... this thread has reminded me of it, sitting all alone on its shelf, yearning to be played again. Time to go google this "VGA mod", it sounds interesting!
EDIT: Apparrently there are pre-made cables that work the same way... does anyone know of a reputable vendor to get one from? Also, where can I get a lightgun for it? I still have 3 original controllers and the unit + a buncha games, but I'm looking to expand.
I know racketboy sells them, but the website says they don't have many left so you should hurry. However those are just VGA cables and not the breakout box that also allows S-vid. I currently have a breakout box but the signal gets degraded and the it just isn't the quality it should be.
FYI if you really want VGA - I bought the only microchip needed brand new on eBay for $6 shipped. All I need now is a VGA plug from Radio shack, a few resistors and transistors, wire and solder. I think it'll be cleaner and give a better signal (not to mention be cheaper).
I'll post pics whenever I get the mod done. I also want to put S-vid, composite, and RCA stereo ports on the DC as well but it is going to be a tight fit so we'll see. Anyone know where I can get a 4-pin DIN to use for the s-vid port? RS doesn't seem to sell one.
