Sounds like you are running it under a lower than native resolution and there is some scaling going on.
OR, that you use the VGA or Component cable or VGA connection on your graphics card and you need to fix the geometry yourself.
First make sure you are running at 1920x1200. Then the rest and let us know.
Nah I am running it at 1920x1200 using the HDMI to DVI cable. I am just talking about how the actual screen itself doesnt fill up all the way to the bezel and there is the little black area between it and the bezel. It just seems a little bigger at the top so it seems like the display as a whole has been pushed down. It's not that noticeable but it bothers me nonetheless.
