Main2 said:peo, could you do us all a favor (including yourself) and reply with
something like 'you should have more info...' blablabla.. blalblalb
like with what you said 'they should have more info'......
i get the idea that we get set off yes
please go after it.
I guess we need people from europe that bought this monitor to go into the service menu and see wich panel they got. There should be a good amount of europeans in this thread.peo said:Tried to ask LG directly about it and got this response.
Would think they would have more information than the very little thats on the website.
Don't realy like companies to treat me like a second class customer when I pay the same so if the panels arn't identical and the one sold in europe is "artificially" boosted to reach similar specs it's not likely i'll buy it. Afterall I have to pay the equivalent of 400$ for the screen in Sweden.
Shaman said:I guess we need people from europe that bought this monitor to go into the service menu and see wich panel they got. There should be a good amount of europeans in this thread.
Main2 said:@123Lanoix please select a white background in windows (instead of wallpaper)
and make a picture with your digicam (while the light is out)
MaricMecca said:I just bought mine the other day and picked it up yesterday from Circuit City. But there was a dead pixel which is really small however it's right in the middle. I could see it when picture is all black and gray. I am still debating whether or not to keep it since it's the only one left in stock in my area unless I want to drive 2 hours back and forth. I drove about 40 minutes just to pick this one up and was the last one left.
Another thing is I think this LCD killed my video card. When I first installed the LG I left the settings how they were. Everything was fine. Then I decided to change the resolution to 1680 x 1050 which then produced flashing red particle lines on my black desktop and white particle lines when surfing on yahoo home page which has a white background. The lines are like the ones you see on visiualization when playing say music on media player.
I first thought it was the drivers that I hadn't installed so I decided to update LG drivers. It corrected the problem and played some battlefield on widescreen. I then powered down battlefield 2 a couple of times and then those lines started coming out again. So I updaed the latest ATI drivers for my 9800 Pro but still kept producing the those particles lines. I even change the resolution to old resolution it had. Finally the particles were all over the monitor covering everything where I couldn't even see my desktop so I quickly powered down my computer and still have not powered it up yet.
I opened up my desktop and it was it covered full of dust. So tommorrow I am going to get some dust cleaner to clean up my desktop to see if that was the problem. But I have a feeling that it might be the video card given the signs. What most likely happened?
mojoicus said:I have another problem with this monitor when i try to connect it with the supplied dvi cable the monitor just goes into digital power saving mode
When its connected with the dv ito vga adapter at the pc end and vga at the monitor end its fine
anyone have an idea why
My graphics card is a XFX GeForce 7950GX2 500M
The dvi cable has 9 small pins then a space then 9 small pins then a small horizontal pin
Do i need a different cable for that card im baffled anyone??????
Caraudiomrw said:could be ur video card, same cable i have and no problems here, could be a bad monitor too, try it on another box or ur friends.
