Shaman said:I wonder why they say the L204WT is 6-bit+FRC in the anandtech lcd buyers guide.
http://forums.anandtech.com/messageview.aspx?catid=31&threadid=1745344
Does the LM201WE3 TN panel (as used in the LG L204WT monitor) use any form of dithering or FRC to reach a true 8-bit color depth?
If not, is this the first TN panel without dithering/FRC to reach true 8-bit like S-IPS panels? Would an 8-bit TN have a higher response time than one that uses 6-bit with dithering/FRC?
Caraudiomrw said:i have SLIGHT bleeding on mine, using DVI and no banding issue, SOME pics show it a bit but the quality of the pic is poor... JEFF, it is hard to tell if this is 6 or 8bit, ive emailed and called LG multiple times and asked questions such as how many colors does this display, and on differ. calls things like how many bit colors. ive gotten 16.7M colors and 8bit true color. im not sure, but again, i think its REALLY GOOD 6bit dithering, or it is true 8bit.... all i know is for 279$ im VERY pleased. i mainly game or surf/im
Wow... what a well informed and reasoned post. You have 37 pages of discussion on the merits of the screen and that's what you come up with.BadDog said:16.2 million color display with 160 degree viewing angle? Sounds like junk to me.
Psychotext said:Wow... what a well informed and reasoned post. You have 37 pages of discussion on the merits of the screen and that's what you come up with.
Specs don't reflect quality, noob!BadDog said:37 pages isn't going to change the specs, boy!![]()
In this case, they do... bcs they show that it's a TN panel and that means only 16.2mio colors (by dithering), bad viewing angles and bad movie quality.Psychotext said:Specs don't reflect quality, noob!
What other monitors and panels have you tried to be able to compare?myckee said:Well the specs are wrong. The viewing angle is awesome on this monitor. In fact I can see everything clearly at pretty much 180 degrees ( little less so I can still see the screen). As well, movie quality is absolutely mindblowing with this monitor. It is fantastic.
I think LG made a mistake on their website regarding this monitor.
37 pages of praise from people with this screen in their hands should be enough to convince anyone that this is a fantastic screen. Why not go to your local circuit city or Futureshop and have a look for yourself?
Or maybe you don't like it because your favorite seller on Ebay says it is no good (so he can peddle some other crap instead).
HardLiner said:Hey is this monitor HDCP??
travbomb said:Suprising it uses a CPT (chunghwa picture tube panel). Looks like it is an 800:1 TN panel afterall.
Ladic said:Hi, I want to buy a my first ever LCD widescreen, this one looks good, but I'm debating over this, the ViewSonic VX2025WM , and SAMSUNG 205BW.
which you guys recommend?
Ladic said:the only thing giving me doubts is that the Samsung 205BW is actually $50 cheaper than the LG (At newegg) and it includes de DVI cable.
tiuk said:Can anyone tell me if this monitor can do 1:1 pixel mapping, as well as aspect preservation (in both DVI and VGA)?
Where do you see this option? You are talking about the L204WT?BadDog said:Yep it does, thru OSD you have the option of full, aspect and off. You will want to keep it off so you get auto 1:1 pixel mapping.
