- Aug 7, 2004
It really doesn’t age. Until OLED there wasn’t a screen that I got exited about after each power-on.My CX is over 2 years old now. Time really flies. Still love the thing.
Yeah that’s why I keep thinking 42” will feel like a downgrade, for immersive gaming at least. Been playing cyberpunk with a 4090 on it at max ray tracing settings and it’s glorious. It really is a great size for gaming and watching movies, at about 1m away. It’s my fave monitor of all time and I’ve put thousands of hours of gaming and productivity work on it now.FPS is epic on a big OLED unless you want a competitive edge for multiplayer then yeah I can see 48" being a little problematic. I'm enjoying Crysis Remastered on my CX with Auto HDR and maxed out RT on a 4090 and it's amazing.
BUT, I do find it a bit too large occasionally. I can’t see the full screen at 1m when playing FPS so I have to look around to see hud elements. I’m pretty used to it now (have 400 hours playing DRG on it for example) - but it can be annoying sometimes. I basically can’t full screen apps at all on it either, which is annoying 1% of the time for screen sharing at work.
Maybe I should invest in an ergotron HX so I can push it farther back when I need to. It’s sort of hard to justify a £250 arm though when the C2 is on sale for £700. 42 would be better ultimately as a pc monitor I think - would lose some immersion but it is a more practical size.
Okay, I convinced myself to cancel my 42" order and look out for a used HX arm.
When I moved, I was thinking of originally selling my CX 48" but it happened to be a great size for our small living room. But I was actually happy to go back to a smaller LCD for desktop use. The CX was good but I was often not using its full desktop, instead using maybe like the bottom 2/3rds instead, sort of like a 3840x1600 display I suppose. Even 1m viewing distance I found it a bit large otherwise even though it was lovely for media and games. I think the 42" size would be more desktop friendly.
I tried putting the CX on a monitor arm initially but the problem is that it is of course limited by the depth of your desk. I bought a cheap floorstand for it instead and that's a more practical solution though not very adjustable. I figured that I am not very interested in moving the screen back and forth but will instead find a good spot and leave it there.
At this point there is not much reason to buy the C2 42" if you have a CX/C1/C2 48". It's pretty much the same thing but smaller. Wait for C3 to be unveiled to see if it brings anything new at least.
What I am really hoping LG would do is a fixed curve C3 that is not much more expensive than the flat C3. To me the motorized curve of the LG Flex is a stupid feature. You will play with it a bit and then probably park it on one setting. LG should just make a 42", 4K 240 Hz version of the 45GR95QE (the curved 45" 3440x1440 OLED).
That's kind of why I was hoping they would focus on things like increased refresh rate and a fixed curve model. It's hard to sell a C3 if it's just the same thing as the C2 but more expensive unless they delay release until C2 supplies are depleted.I expect the C3 to be exactly like how the C1 was to the CX, basically the same thing and not worth it over a heavily discounted C2. After that in 2024 maybe we'll get the next big thing for WOLED but I'm pretty sure LG's main focus for their TV's isn't the PC gaming/desktop crowd so instead of giving us higher refresh rates or a curve, they'll probably be releasing that MLA panel that supposedly increases the brightness significantly and even that may not hit the C series but instead be limited to larger sized G series TVs. I think we reached the end of the road here for WOLED TV's but hey at least LG is actually making monitors now starting with that 27" 240Hz so hopefully we'll just get a 32" 4K 144Hz+ WOLED monitor next year or in 2024 and never have to bother with using TV's as a monitor again.
Does anyone know of anyway to send a command to the PC whenever you press a certain button on the LG remote?
What I'm trying to achieve:
1. Hold button 2 to run Emby shortcut.
2. TV run Emby and notify PC (this is the part I'm trying to figure out).
3. PC run script to pause Wallpaper Engine.
Or the opposite:
1. Hold button 1 to return to HDMI1 shortcut (PC).
2. TV goes back to PC mode and notify PC of that.
3. PC run script to unpause Wallpaper Engine.
Edit: Figured it out using Home Assistant (with LG webOS integration) + HASS.Agent.
I've had the CX48 since launch. Just recently I bought the 42C2. You might laugh but I'm returning the 42 and keeping the 48. Don't get me wrong, the 42 is beautiful but dare I say....too small. Picture wise they are exactly the same.
I am seeing the same thing going from the 65" C9 in my living room to the CX 48". C9 seemed to get brighter overall.That's why I skipped the 42C2 as well, the picture quality isn't getting an upgrade from the 48CX and the size, while being closer to the ideal 32" that I prefer, is still not there anyways so it's yet another stopgap to 32". What sucks is that the smaller the screen gets, so does the brightness. The 42C2 is less bright than the 48CX and that 27" WOLED monitor coming out is going to be even dimmer. So when a 32" finally lands, I'm not sure if I even wanna upgrade to that if the brightness is going to get significantly nerfed compared to my CX. We need some 4K QD-OLED options in the monitor space! Or for LG to stop making smaller WOLED's lose brightness compared to larger ones.
I was definitely tempted by Black Friday deals for the 42C2 but I knew that like the CX 48" it would be less than ideal. I'm using a Samsung G70A 28" 4K 144 Hz as an interim solution and feel like a 32" 16:9 or 40" 5120x2160 would be ideal for me but since neither has that great options regardless of tech, I'm hoping for some improvements in the 42-43" size.
I found the 48" size too tall for me and often ended up using the bottom 2/3rds of the display. 42" would probably have been just that little bit smaller to be appropriate for me.
If LG could make the 42" C2 at a higher refresh rate, similar brightness to 48" CX and with a fixed 800-1000R curve they would have a real winner because a big part of why the CX 48" needed so much viewing distance was that seeing the sides and corners of the display is awkward if it's too close. Curve would bring them more towards you and thus make it easier to manage the size. I would probably buy the LG Flex if it wasn't literally just the C2 with 3x price tag. Just too expensive for what it is.
As the TV notifications have been alluding to for a week or two, LG finally released an updated firmware for CX GX series today: v04.40.70
[Web OS] 2020 LG OLED AI Latest Software _OLEDxxCXX_GXX_RXX_WXX_O20). Ver.04.40.70
change log:
1. The voice recognition feature has been improved.(China)
2. TBD
Can anyone do me a favor and check something? So I've decided to make my CX a permanent BFI screen and what's happened is that with OLED Motion Pro (BFI) set to HIGH, my CX can now only output 78 nits fullfield with OLED light at 100 and 6500k whitepoint. I swore this thing could do just over 100 nits at the same settings when it was brand new so maybe it's degraded quite a bit after over 2 years of use. Wondering what kind of brightness output you guys are getting with BFI set to High, OLED light at 100, and whitepoint at 6500k. I would ask some of my friends who also own a CX but none of them have colorimeters to take readings.
Just wondering, why would you want this?
Reduced brightness & contrast, no HDR, no VRR. Sure, your 4090 is stout, but is it locked 120fps ultra setting stout?
Legit question
Are you at 60hz? That’s what those numbers seem to indicate.
Ooh yeah that is low…120Hz.
I think that sounds about right. I never measured it, but visually switching between my calibrated 120 nits brightness in SDR vs turning on BFI and setting OLED light to 100 gave similar brightness level on the "medium" or "auto" setting. "High" to me was unusably dim even when the display was new. With most games I play being HDR capable these days, I have found no use for BFI.Can anyone do me a favor and check something? So I've decided to make my CX a permanent BFI screen and what's happened is that with OLED Motion Pro (BFI) set to HIGH, my CX can now only output 78 nits fullfield with OLED light at 100 and 6500k whitepoint.
My understanding is that these displays should have some reserve brightness so when the pixel refresh algorithm runs, your display should retain its brightness. How long, I don't know. I really can't say if my CX is dimmer after 2.5 years or not as I don't have anything for comparison.
Here’s to hoping. If not that’s a pretty substantial drop in just a few years.I measured the brightness when it was brand new and high BFI only dropped it by a few nits compared to my non BFI 120 nits calibrated SDR setting so this doesn't sound right at all. Perhaps there's a setting that I forgot to change I'll have to investigate more later.
How many hours? Do you have an idea?I set the Contrast from 80 to 100 and that was able to boost the brightness up from 78 nits to 99 nits. Otherwise the rest of my settings look fine so I guess there isn't much else I can do to get it any brighter, let's just say after 2.5 years the max luminance with BFI on high has dropped from ~120 nits down to 100.
Out of curiosity, what video setting do you guys use for movies in windows?
I have mine set to HDR user for games and it hit me that I might want a a different setting for movies.
What do you guys switch to? I know in Netflix, and the video apps it auto switches.
Thx!
Damn that really isn’t a lot. But like you said you’re running full tilt so I guess that has to have counted for something.It's only at 2339 hours so that's really not a lot given that some owners have already crossed the 10k hour mark! But like I said I did disable ASBL within the first week and It's been running OLED light 100 the whole time so perhaps that contributed something.
Your being a continued die-hard CRT user giving the screen these accolades is worth more than you realize. Congratulations on your purchase.Got my CX up and running now.
For work and personal use.
Fonts seem fine with Better ClearType Tuner with grayscale font-smoothing activated.
Disabled automatic dimming (TPC & GSR) to keep from getting blasted by white screens when I move stuff around.
Running 4K/120Hz/10 bit/Game Mode/BFI High on my personal machine. (My work machine basically the same, except it doesn't appear to support 10 bit. Also use some scaling there for myself and for screen sharing.)
I use very low OLED light in my relatively dim home office/bedroom. (As is my natural preference anyway.)
And aggressively use screen savers along with other mitigations. (Similar to how I treat CRTs.)
Wow...Amazing panel!
Obviously I'm very late to this party. Here after countless firmware updates and folks documenting their experiences and advice. Many thanks to everyone here and in the larger community!
You don’t have to convince me. My Viewsonic XG2431 has similar (probably a little better) persistence at 60hz and only if I’m nitpicking do I care about motion clarity still not being up to par with CRT. I can only imagine what it would look like if it had those OLED blacks to go with.I'm telling you man, a BFI OLED is the next best thing after CRT. On paper 3ms persistence vs 1ms persistence of CRT it doesn't look like the OLED would fair well but in real world use you will be hard pressed to notice that. A 240Hz BFI OLED would probably fully close the gap but until we have that, the CX/C1 are the go to displays for motion clarity + image quality combo.
