- May 5, 2006
Still holding out for november OLED deals but in the meantime I moved my whole rig to a different wall in my spare room.
It seemed like taking apart a space shuttle control center and putting it back together because I have so many peripherals and wires. It was a much needed overhaul since I had been adding things gradually over time over my existing wire management. So it is a lot nicer now. However I did knock a nice very heavy chrome base banker lamp over with my head which broke the heavy frosted glass shade so that was a loss. Then I moved my TCL 43" S405 screen on it's ergotron arm with not enough slack in the hdmi cable which resulted in the metal end of the hdmi plug getting broken 90 degrees. I tried a longer 18gbps cable I had laying around but the screen would blink occasionally, very annoyingly. Now half of the screen is dim. I tried doing a full system restore on the tv and I dug up a shorter ~ 10' 18Gbps hdmi cable. It's not blinking anymore but it's always dim on the right side. I looked it up on google and it seems like some of these cheap TCLs die like that in 1.5 - 2 yrs. However the PC move probably contributed to it's demise. Incidentally I also hit the top of my head on the corner of a wall shelf which resulted in a small goose egg and a tiny bit of blood in my hair.
So now I'm deciding if I will get another NU6900 Samsung 43" to match the other 43" monitor in my array. There is still a few brick and mortar stores within 20 mins of here that have some and they are better than this year's model. I screen shotted some layouts with one or two 43" 4k screens alongside a 48" or 55" oled using a monitor layout calculator but I'm still undecided on my layout.
I just measured out 42" across on the middle of my display desk to represent the width of a LG 48" CX and locked my tape measure there. Then I moved each 43" display in portrait mode just to the edge of where the ends of that 48" TV would be, one on each end. It seems like a good setup once I rolled my peripheral desk and chair back a little more and set the 43" displays to 125% scaling and tweaked a few things. I'd been considering putting both 43" displays in portrait on the same side of an OLED so that I could rotate to one side to do all desktop/app things when not focusing on what the media/gaming OLED stage is running but I think I will start with the bookends type setup I'm more used to first and see how it goes.
~ 42" wide is still a very big screen if the best buy dimensions are accurate. (The 55" one is ~ 48.5" wide according to their site).
I played around with the idea of doing this with a really tall pole stand for two cheap 24" displays above the OLED butI wouldn't buy into that for awhile.
The 5 and 6 are just parts of a single 43" display in this example if anyone is wondering.
43" VA TV = monitor 1, monitor "5&6"
48" OLED TV = monitor 4
24" 1080p LCD = monitor 2, monitor 3
So at first it'd be the "rabbit ears" without #2 and #3. I'm using my setup right now with the 43" screens that far apart. I think the extra 3.25" distance on each end to each 43" screen if using a 55" would be pushing it too far so I hope the questions about the 48" CX all pan out on the 3000 series gpus with hdmi 2.1. I think my setup is looking good in this orientation - just missing that centerpiece I'll pick up in a few months.
