That's true. I'm glad I don't work in marketing.The thing about marketing is that Leynar doesn't have to actually exist. If it seems that a leak sprouted out of nowhere AMD can shrug their shoulders when asked by folks like Kyle and say "out of our control" even when it costs him hits.
I want something official!
Now lets get into phase changes, do you know why its worse to get burned by 100 c of water vapor than putting your hand on 100 c metal plate?
Lol, did you just finish your introductory chemistry class or something?
Specific heat matters, but it's a ratio of heat capacity to mass. The ability of a heatsink to move heat away from a source doesn't just depend on the specific heat of the substance. It matters, but so does the amount of that substance.
However we seem rather off topic and I don't want it to come across as a pissing match, so if you want to continue our conversation about this matter I'd welcome a private message, but
heat to mass means jake, as long as you can move that heat away from the piece that is creating the heat.
And no wrong class man, chemistry only part of that......
This is why cooling elements doesn't matter how "strong" they look, the only reason they are heavy or have more mass is because they need it to support themselves and fins which are needed to remove the heat from the unit.
But what you keep posting here, so guess what? BUT........
I suggest you look up 3m novec, those are the things my friend and I have worked with so I know what I'm talking about. If you have money to spend on oh 400 bucks per gallon, I suggest you try it.
No one has ever accused Jay to be the sharpest tool in the shed.
Not sure why people are insulting Jay over this, especially on /r/amd. If say, AMD is pushing out BIOS updates for better memory, then reviewers gotta work extra hard to finish before NDA. Jay states his vid will be late, but luckily major youtubers usually dont seem to suffer being late too much. Other review sites might suffer less views for being late. Speaking of updates, aside from the memory speed increases, anyone have any thoughts on what AMD keeps pushing out that changes stuff significantly?
https://videocardz.com/66745/amd-ryzen-7-press-deck-leaked
Full press deck
Just to point out overclocking lol
R7 1800X all core boost 3,7 GHz, XFR single core 4,1 GHz (slide 10)
XFR Single core!
Highlighted in orangish and red.
Yes we do
ZD nomenclature of AMD parts are not ES's, those are qualification parts. Qualification parts are final release products, and if you want to look this up please look at Intel's in dpeth documentation on how qualification is done, and how motherboard manufactures are brought into the process early on. AMD as something similar. If you are so bold just call up Intel and AMD and purchase them as well, you will need to buy them in lots.
So you are saying pc per and tech power up don't know what the nomenclature of the serial numbers are? This is the same thing Juanrga stated, so take it or call BS on everyone that seems to know what the ZD stands for.
I have been for months suggesting that XFR is single core because the only temperature dependent frequency in RyZen, F_TMAX, is a single-core boost. All the other frequencies in Ryzen are predefined and don't depend on temperature. Therefore for the R7-1800X the frequencies are:
F_P0 = 3.6GHz (base clock)
F_TMT = 3.7GHz (all-core turbo)
F_TST = 4.0GHz (single-core turbo)
F_TMAX = 4.1GHz (single-core XFR turbo, limited to 4.1GHz with stock cooler and higher with better cooling I assume).
First pair of letters in the ID string:
1D = First gen engineering sample
2D = Second gen engineering sample
ZD = Qualification sample (= retail sample for technical pruposes)
One can also check the last pair of digits on the ID string:
E4 = A-grade silicon (<-- non-final silicon used in engineering samples)
F4 = B-grade silicon (<-- final silicon used in qualification samples and retail chips).
The chip used in the review was
The decodification is
340 = Base frequency
6 = Model revision number
BA = 95W
M = AM4 socket
8 = number of cores
8 = 4MB L2 + 16MB L3
Therefore this is the QS for a R7 1700X chip.
Ch
Chips limited by bios, if they literally don't have a 28/2 press board they have a gimped bios
I believe well known poster in overclocker forums that AMD would be updating the firmware to support faster memory and improve memory performance as alot of it is locked up and can't be edited right now. May be they have been working hard around the clock on such a thing. He did say AMD was still tweaking it and there is alot of room left for improvement. So this might be it, lol.
Therefore the several leaks showing abnormally low memory scores were just reporting how the systems behave before this supposed last minute fix.
yes, from my personal knowledge bios behaviour has been tweaked significantly but still AMD are running new firmware updates like crazy, like this is a formula one testing session.
Shit 2/28? I think they got some 3/1 too.
I'm almost glad I am not going be able to touch this stuff till at least Sunday, because there'll be 3 BIOS fixes by then at this rate.
But also worth noting Steve at GamersNexus backs it up.No one has ever accused Jay to be the sharpest tool in the shed.
It has been mentioned in the past but I cannot remember, anyone know which chipset AMD 3rd partied for Ryzen?
Thanks
Anyone remember what they did?AsMedia.
Remember what they did?
Thanks
I asked which chipset as I could not rememberWhat do you mean? They do the entire chipset.
Anyway found the answer, was the Southbridge.
Thanks
I know but they were contracted to develop the Southbridge portion, its operation is similar enough even if it is onboard.There is only one chipset that's segmented into X370/B350/A320/X300 etc. And its not a south bridge either. Its a PCH or FCH.
Your arguing semantics when I am putting into context of what most of us can relate to it with regards to Intel.
Cheers
Sigh.Then its called a PCH and have been done so for ages![]()
Anandtech interview with AMD's CEO. http://www.anandtech.com/show/11177/making-amd-tick-a-very-zen-interview-with-dr-lisa-su-ceo
