LOL,Hey, I did, but I needed m-ATX for htpc use, so no choice as there are no Z370 m-ATX boards. As the ASUS Prime supports 3200 ram, I figured why not for $20 more.
well that serves me right I guess
Cheers
I mean, Skylake has exactly half the latency at very similar settings (looser timings a little, but same MT rate). But a whole 2Gig/sec lower bandwidth.
Another curious thing is that Skylake has way lower latencies than what AIDA has here. But i guess that's the trade-off of cache vs latency.
Biquadratic actually, if you assume that stock Ryzen consumes 9W in idle and it had 3.5Ghz clock in P95.
Let me quote someone who actually overclocks stuff:
Now compare that and what AMD shows here.
We were talking about AMD's tweet done on what looks to be Crosshair VI. If that is a shit motherboard that cannot accept the memory in your book, you already have an egg on your face. So, wipe it off and look at that watermark:Shit motherboard that can not accept the memory. If you accept Juanrga's fantasies you will have egg on your face. Wait until a proper test is done on a proper motherboard.
I talk about AIDA64 test with 3200C16. You are so fixated on trying to prove Ryzen perfect, you have stumbled on context twice already.TRhis test was done on an inferior $50 motherboard that can not process this ram properly.
People running 2 sticks hit "just" 4000 at these timings with Skylake. Samsung B-Die is a beast when you are not worrying about having to throw it out every month or two because of 2.0V voltage.And I bet those OCers that hit 12-11-11-28-1T/4200 w/Kaby Lake are running a single 4GB stick or something.
You do understand that presence of airflow makes fin area kind of more relevant than heatsink weight? Brick of copper would probably cool stuff worse than my 200g flower.I find it funny that those negging the Ryzen based on this review are blissfully ignoring the fact they were running it on a heatsink with half the mass of a Hyper 212 EVO.
Wait, didn't you pre-order x370 mobo already? You posted as much, i recall. But yeah, early issues are to be expected, i wonder if anyone will revisit it after initial reviews though.It is probably the reason for some benches being weird but I am willing to give a new chipset time to teeth in. Not like i will have a motherboard for it anyway until July
Fin count, man, fin count.Except it has the exact same structure and design.... with less mass.
Yeah, it is a tad bit more complicated because you have to consider like 5 thermal transfers.Unfortunately that's not actually how it works.
That would be defined by thickness of fin, mass is a byproduct of fin area and fin thickness, after all.Without enough mass for heat to actually spread through to those fins those fins become expensive decorations.
Actually a very tight cluster of fins can easily weight as much as a proper solid brick of same material, that's common sense, and description of server heatsinks in the same time.If it was all about fins and air flow then intel would just use less material in their stock heatsinks and make them a cluster of fins.
Ah ok.
Well without being able to read the article I could only go by what he said
But still, it means it is not the actual retailer product and context still applies it raises questions where and revision of motherboard they have (which controls the microcode).
Memory config they did/let happen is enough anyway to make me leery.
Cheers
Yes, you forget that the measured power is at the wall.We are talking about different stuff I believe.
10/10 jokes.HA now that's funny and interesting.
Where? I.e., did he actually provide raw numbers? Also, they said as much that their sample either had stability or performance issues, and they did not have fix at the time.on the engineering sample on Canard pc. Its recent tests directly contradict results seen on production samples for review:
ES!=QS, but that flew over your head as those 2 memory moments.We do not know that this anything but an engineering sample as well.
Time to dig up that old compute job on the heatsinks.Thermodynamics requires mass and a conducive shape for proper heat dissipation
Not really, as long as you can decrease the distance between them keeping thickness constant. It will rise the airflow requirements and make it way heavier, obviously, but effect is well specified. Granted, properly verifying myself requires stuff i do not have on hand (the decent model, that is), so i'll take your word for it.the more narrow they have to be
As for the Iranian drek. We do not know that this anything but an engineering sample as well. Juanrga has claimed the same crap on several other occasions and been proven wrong every time. No verification, no science.
Today, 07:21 AM![]()
Canard PC guy is stuck on the measurements he made on an early sample, he still has no final chip and is unaware of the definitive numbers.
Indeed he may have been somewhat trolled because it was clear that his sample was well below the server parts for FP in the Sandra submssion, FTR below are the scores of his sample and of a final chip :
AMD Eng Sample: 2D3151A2M88E4_35/31_N (8M 16T 3.14GHz, 8x 512kB L2, 2x 8MB L3)
Score 317,84Mpix/s
Performance 101,09Mpix/s/GHz
Multi-Media Integer 458,38Mpix/s
Multi-Media Long-int 137,10Mpix/s
Multi-Media Quad-int 2717kpix/s
Multi-Media Single-float 348,24Mpix/s
Multi-Media Double-float 201,16Mpix/s
Multi-Media Quad-float 9534kpix/s
Ryzen 7 1800X 3.62GHz
Score 461.13Mpix/s
Performance 127.31Mpix/s/GHz
Multi-Media Integer 557.85Mpix/s
Multi-Media Long-int 168.26Mpix/s
Multi-Media Quad-int 3816kpix/s
Multi-Media Single-float 546.84Mpix/s
Multi-Media Double-float 321.44Mpix/s
Multi-Media Quad-float 14127kpix/s
#54![]()
https://www.pcper.com/news/Processors/Report-AMD-Ryzen-Performance-Ashes-Singularity-Benchmark
It is also interesting to note that the processor listed in the screenshot above is (apparently) not an engineering sample, as TechPowerUp points out in their post:
"Unlike some previous benchmark leaks of Ryzen processors, which carried the prefix ES (Engineering Sample), this one carried the ZD Prefix, and the last characters on its string name are the most interesting to us: F4 stands for the silicon revision, while the 40_36 stands for the processor's Turbo and stock speeds respectively (4.0 GHz and 3.6 GHz)."
ZD doesn't mean engineering or testing sample, Qualification samples are = to retail samples.
I'm going to go throught this again.
Qualification samples are sent to motherboard manufactures to simulate what the retail samples will be for them to finalize boards, there is almost no difference if any between Qualification and retail samples.
I have here with me, ES of GPU's and had one of Intel CPU's (old P4) till last month when I cleaned out my basement. All of them are very close to retail releases.
This is not something new to me.
If you contact either AMD or Intel and tell them what you are doing, like making a motherboard, they will give you qualification samples which are retail samples without warranty. Qualification samples are the same as Retail. They have to be, because a manufacturer can not base their hardware on a chip that has unknowns.
That leaves one problem unanswered and you can not deny the board he has has to be an ancient bios. It is a bootleg motherboard not final retail with an ancient bios does that not send warnign signals about the memory throughput, since it was known that early bios had severe problems handling memory. We do not know what revision the motherboard is. it could be a pre-production board. This just doesn't smell right. But of course troll Juanrga and haters et al jump on this knowing it is far too soon to accept that Iranian report as anything to concerned about, more likely to be laughed off.
Yah doesn't look like a slam dunk decision over a 6850K. Couple more cores is about all it has over it. Worse overclocking potential. Less IPC. Gonna trade blows with a 6850K in some apps.IPC lower than Boardwell, Multithreading performance AMD is well above Broadwell.
So gaming is going to be a crap shot, win some loss some. Better for the future.
Overclocking well, the press deck says it all, 3.7 on a x1800 max on all cores, XFR 4.1 one single core.
Good thing there is way more variables either of us can control for in our heads, eh.What you seem to be saying is that if you change multiple variables you can end up with a result that seems favorable to your point.
Yeah, i know of that PDE.. To put it simply, heat transferred is directly proportional to the size of the conduit and the conductivity of the conduit.
But we do not care about noise here, do we? After all, we do not know what noise that gammaxx knock off produces.Sure you might be able to make a smaller heatsink with more fins dissipate more heat if you can push a few hundred cubic feet per minute over it, but that's a ridiculous idea when you can form a heatsink in a more optimal way and have a quiet lower flow fan.
Given the fact the 6850K isn't exactly much better it doesn't make me feel like I've made a mistake on ordering the Ryzen.
Final judgement reserved for tomorrow AM.
Not mass as much as volume and properties of material used. Yeah, nitpicking i know, but mass still has formally nothing to do with it.Good to know we're all in agreement here now that heatsink mass matters.
Mass has nothing to do with heat transfer........
Thermal conductivity, only has direct correlation, with the ability of a material to absorb a certain amount of heat quickly and that dissipating that heat quickly.
This is why water is one of the best thermal conductors, its specific heat capabilities are above most metals.
So the mass of water doesn't matter, even with little amounts of it as long as its being transported away from the heat source, can cool much better than a block of copper. Granted can't use water lol, but there are ways to "water cool", well submersion techniques that rival or get better results than LN2, by using organo-phosphate liquids.
If you want to get into semantics it's often characterized as a function of component sizes and thicknesses, which of course is the shape by the mass, but if you want to argue that I can understand where you're coming from, but I don't subscribe to it.
What? So it doesn't matter if you have a drop or a pint of water in your water cooler? Man, I hadn't a clue.
I bet this Leynar Khayrullin person is getting a phone call from AMD right about now...
