Looks like newegg could have got rid of this monitor? It says deactivated item, doesn't even show as out of stock anymore.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824255001&Tpk=L2410NM
again, for those people also having similar problems: what are your ambient room temperatures like?
I'm considering buying this monitor off of a member on the forums as I've heard that the image quality is great...however after doing some reading about it, I'm questioning the build quality.
Being a 2nd hand item...I would not be entitled to the warranty. He says he's had it for 6 months.
Should I buy this monitor...or is it too risky?
I can't speak for others, but besides the black screen issue (which hasn't happened in many days, maybe a week) I've had no problems.
I guess it comes down to how much you'd be buying it for.
So you're saying this monitor will more than likely have some sort of problem?
i just got 2 blackouts within 10 seconds of each other (ps3 --> hdmi)..... this monitor is starting to get on my nerves.
Just a thought, but most monitors' temperature will be reduced based on lowering of backlight (brightness), so those who feel it's running too hot might want to reduced the brightness to 20 or 30 and see if that helps. I know this can induce the "whine" but around 30 to 35 I found it to be quieter in general.
Good luck.
The only thing I don't like is the blue screen when you leave your comp alone for a while..., but other than that, its cool.
