good luck with that. i've found that the floppy didn't make a difference for me. then again i'm only using a single 7900
ran orthos and while testing play marvel ultimate, got bloe screen after 30 min.
i can see the +12v has changed, from 11.74 to 11.83, i know the sensor is not accurate but there is a lil bump on the 12v
nice. I mean while the sensor may not be "accurate" with regard to what you can measure 12v at at a molex, it may indeed be accurate in the sense that because of poor connections causing voltage to be that low where it's being used by the motherboard. Sorry that came out sounding really confusing. Hope you get the idea
That's good that you got the jump . Are you using sli? I never checked before and after voltages, but I went from my enhance 500w to the ultra xfinity 600w and saw a jump in 12v.
I'm 11.83-11.9 and 4.89 now. Was about 11.64 and 4.73 or something with the enhance.
I really wonder what those 3 reserved jumpers are for by the cpu socket. hmm... maybe some day I'll get my dmm out and measure it
i want to trade my p965-s for quadgt, anyone interested?
http://www.hardforum.com/showthread.php?t=1190754
proof?Go with 3 gigs, 2 gigs can't even handle Stalker without stuttering.
eWiz and motherboardPro got the board in stock... Newegg hasn't yet.
Since I am in CA, best price would be from motherboardPro, but there is one glitch;
there is no return policy on their site.
Can someone explain this if you have experience with them?
[ADDED]
Just found 'tiny' text under the spec of the board...
# Warranty
3 Years Manufacturer Warranty Only
MotherBoard Pro We will gladly assist you with the Return process!
* 15 DAY DOA
* Manufacturer Only
Do you guys think this is enough for secure purchasing?
I know I am sorta control freak but I want to make sure what I am doing.
i just realized that i never plug the floppy power connector to the board...
testing OCCT now
@3800Mhz hopefully it will pass this time
With ambient about 75F right now here's what I'm getting:
Notice I also have it OCed up to 3.0ghz, so the CPU temp is a bit higher. These actually look a bit better than they did before, maybe the AS5 is curing a bit? I still expected the CPU to be a bit cooler though with the Thermalright Ultra 120 Extreme. Judging by these temps at 3.0ghz would you guys recommend trying for more? My processor is an L640, so it's not the best for OCing.
Despite the fact that I went out and bought an asus p5b-deluxe after being impatient for this board... I just ordered one off of motherboardpro.com.
Website seems uber cheesy and they only seemed to have paypal as payment method but we'll see...
I bought the Asus from fry's so I should still be within their return period!
http://www.arcticsilver.com/instructions.htm
I made the mistake of putting on a little too much of the stuff on my first aplication, then I looked up the .pdf for how to do it right and my temps are much, much lower.
What is this...."idle period".... you speak of?Another happy OC nOOb here! I've learned a lot in the past few weeks, finally hit my target OC (see sig)...still have tweaking to do for optimization, but very pleased so far! So, are C1E and EIST linked in the BIOS? Both on or both off? After I get things dialled in, I'm thinking of turning C1E back on to lower temps during idle periods. Thoughts?
Apparently, it is the product of an antiquated mode of thought. I've been hammering my P4 1.5GHz for ~6 years doing intensive video processing, so I'm used to being at 100% all the time doing my own thing. I imagine I will now have CPU cycles to donate to the cause...thanks for the link!What is this...."idle period".... you speak of?
I'll still go with chiefvalue. I hate it when i have to enter all the information just to find out the shipping cost.
About applying thermal artic silver 5, I always though you had to spread this across the chip itself? Thats the way I have always been doing since AMD XP processors? And also I just sw a post on how to get rid of the top of the CPU to bare copper then apply to all the chip? Is this method wrong? I thought the point was to cover the whole chip itself not just the middle where the processors are?
