Is it time for Nvidia to support Freesync?
Discussion in 'Video Cards' started by H-street, Sep 24, 2017.
  1. euskalzabe
    euskalzabe Gawd
    879
    May 9, 2009
    My LG 29 WK600 begs to disagree. A nice IPS monitor with 40-75hz VRR range is good enough for regular 3rd person adventure gameplay, even better when you consider I only paid $200 for it. Far from garbage, and as for LFC... if you're playing at sub-30fps, well, you're doing it wrong. Show me a single Gsync monitor that comes even close to this value.
    {NG}Fidel and Pieter3dnow like this.
  2. Nebell
    Nebell [H]ard|Gawd
    1,538
    Jul 20, 2015
    Can someone explain this to me?
    So I can run 4k at 40fps on my TV which support Freesync and still have smooth gameplay with 1080Ti?
    Will it feel as smooth as 1440p/120hz?
  3. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    sorry if my last post was abrupt, I wrote it in a hurry.
    And No, I am not agreeing with you at all. There are Freesync monitors that have full range that are way cheaper than any Gsync monitor. For example, you say that there is no Freesync equivalent of a 240Hz Gsync monitor. Well, there is. There is an Acer Predator 27 inch Gsync 240hz monitor and there is an Acer Predator 27 inch 240Hz Freesync monitor. It's the same monitor, same panel etc. Except there is over $300 between the two in price.
    You can save a lot of money buying the Adaptive Sync version of a monitor over a Gsync one.
    On that Lighter note, I am in the same boat as you. I have an Asus IPS Freesync monitor that's not on the list. I have a 1080ti so it would be great to have sync tech again. Just hope it works ok.
    {NG}Fidel, Maddness and Doc Doc like this.
  4. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    As far as I am aware the 1080Ti does not support HDMI 2.1. So it won't work with VRR.
    Also, as far as I am aware, Nvidia haven't mentioned anything about supporting VRR over HDMI. The current announcement only affects display port.
  5. Nebell
    Nebell [H]ard|Gawd
    1,538
    Jul 20, 2015
    Why would you need HDMI 2.1 for Freesync/Gsync?
    Maddness likes this.
  6. nightanole
    nightanole [H]ard|Gawd
    1,996
    Feb 16, 2003
    That sounds like an awsome monitor for $200. I wonder if you can force LFC so that you can stay in the freesync range. Here is the problem, if you drop below your 40hz, you will experience tearing and juddering. If you can force enable LFC, the video card will never feed the monitor anything below 40fps, so it will always stay in the freesync range.
    https://www.amd.com/Documents/freesync-lfc.pdf
  7. nightanole
    1,996
    Feb 16, 2003
    You are digging too deep. "VESA DisplayPort Adaptive-Sync protocol". This works over hdmi 2.0 monitors/tvs with freesync already. It is an add on. Im freesyncing over hdmi 2.0 right now on my amd.
    "when" hdmi 2.1 comes out, VRR will be part of the standard, not optional.
    You do not need a hdmi 2.1 nvidia (no 2.1 video card exists) to get freesync over hdmi. Your old gtx 970 should be just fine.
  8. euskalzabe
    euskalzabe Gawd
    879
    May 9, 2009
    Well, playing at 30fps would be borderline acceptable for me, for that I have my PS4. If I'm in an extreme case where my 1060 can't manage much more than 30fps, it's not hard to lower some settings (shadows specially, maybe resolution) to get 40fps stable. 40fps is low enough to be easily achievable. If you can't even pull that off, it's probably time to consider getting a new GPU. Even if the monitor supported VRR at 30fps, I doubt I'd want it. It's too low an fps to feel as smooth as 60fps, even with VRR.
  9. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    No I am not.. The VESA display port Standard is different from the HDMI standard. It's two completely different organisations for a start.
    VRR will be an optional standard on HDMI 2.1. Companies that use HDMI can opt to use VRR or not.
    Most newer AMD cards support VRR through HDMI as they support HDMI 2.0 and had the needed hardware to update to HDMI 2.1 with a driver. That's why your AMD GPU works.
    Nvidia GPU's don't support VRR through HDMI. People hope that Turing cards will get an update to support HDMI 2.1 down the line. But, no, Nebell's 1080ti will not work with VRR.
  10. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    For the same reason you need Display port 1.2a to use Adaptive sync.
    Freesync and Gsync are two different things. Gsync is a self contained module. Freesync is what AMD calls their method to connect to an adaptive sync monitor. To connect to an adaptive sync monitor your GPU has to support the display port 1.2a specification. There are special hardware requirements.
    If you want to connect your GPU to your TV and use VRR your GPU and TV will have to support certain requirements. Those are specified in HDMI 2.1. Some TV's that have HDMI 2.0 have the necessary hardware to support HDMI 2.1 so they just needed a firmware update. I believe some Samsung TV's were made HDMI 2.1 compliant this way.
    The same with your GPU, AMD GPU's supported HDMI 2.0b and have the hardware needed to fully use HDMI 2.1 so they can be used to connect to your TV and use VRR(If the TV is VRR capable of course) But Nvidia's GPU's don't.
  11. nightanole
    1,996
    Feb 16, 2003
    After further reading, its like you get a christmas gift wrapped like its a new bike, but its full of socks...
    Yup Nvidia will only support "freesync" over DP. This sucks because runs over 6ft with DP have drop out when you start pushing 4k 60hz or 1080p 144hz. I have tried 3 3m cables, all have sparkles or droppouts.
    And worse, VRR support is optional on HDMI 2.1, its not required. Since its not required, you will have to check every single time you buy something, you cant just assume its "VRR ready".
    All this should have been handled when DP first came out, it was suppose to solve all our DVI problems...
    I guess i should feel luck that my x470 board only has hdmi out, and it supports freesync to my viewsonic, which supports hdmi freesync in.
  12. Nebell
    Nebell [H]ard|Gawd
    1,538
    Jul 20, 2015
    It should work on my TV (Samsung Q7FN) via HDMI. It supports Freesync and it doesn't have a DisplayPort.
    Maybe if I get a DP - HDMI cable.
  13. nightanole
    1,996
    Feb 16, 2003
    That will be interesting. A DP 1.4 to HDMI 2.0B conversion. last time i checked it only worked for DP to HDMI 2.0A, because DP has 4 lanes, and hdmi 2.0A has 3 lanes, but HDMI 2.0B has 6 lanes.
  14. OFaceSIG
    OFaceSIG [H]ard|Gawd
    1,868
    Aug 31, 2009
    This latest move by Nvidia to support "some" freesync monitors is a step in the correct direction. Eff proprietary standards. Gsync, is just one of many reason I try not to buy Nvidia products. Too many shenanigans from team Green.
    euskalzabe likes this.
  15. RamboZombie
    RamboZombie n00b
    53
    Jul 11, 2018
    aww, snap - i do believe that you are absolutely right here..
    But if nV dosent support VRR over HDMI people will start looking at those rumored new Ati cards again..
    all i know is that - next purchase will be determined by hdmi standard and VRR for me.
    So no freesync/VRR - no buy - no way in hell i'll get a BFGD with those specs and prices..
    reaper12 likes this.
  16. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    Did you even read my post? Nvidia's GPUs don't support VRR over HDMI at present.
    And I don't think there are any display port to HDMI cables or Adaptors that support the HDMI 2.1 standard. IF there are, they will be very expensive.
  17. reaper12
    reaper12 2[H]4U
    2,186
    Oct 21, 2006
    It did solve all our DVI problems. But technology advances. Nvidia decided to go one route to VRR, AMD went a different route. Now they are slowly coming back together with Nvidia announcing support for Adaptive Sync monitors.
  18. sethk
    sethk [H]ard|Gawd
    1,546
    May 3, 2005
    Freesync is not officially part of the HDMI 2.0 protocol, but AMD cards pass the displayport spec signaling for freesync over HDMI 2.0 today (which is great). GeForce cards do not do this yet. Sounds like they are looking into it
