Intel 34nm SSD will have a 60% reduction in price!
Discussion in 'SSDs & Data Storage' started by mjz_5, Jul 21, 2009.
  1. Nenu
    Nenu [H]ardened
    18,465
    Apr 28, 2007
    is gone
  2. Hypernova
    Hypernova [H]ard|Gawd
    2,034
    Jan 16, 2007
    Heh, I managed to read it when it was up, The article actually had [Embargo till 11 EST] inside the title so I guess it wasn't supposed to be up yet. People in the comments were wondering about it.
    The main point is that the new drives while having the same performance to the X-25 M's cost only half as much.
    [EDIT[
    Found the article in my browser cache:
  3. Peteman100
    Peteman100 [H]ard|Gawd
    1,466
    Oct 7, 2007
    I thought the new 34nm flash was supposed to be based on the ONFI 2.1 spec? Should be way faster than this. Maybe this is just a transition product until they can integrate SATA 6G and a better controller design.
  4. faugusztin
    faugusztin 2[H]4U
    2,620
    Mar 9, 2008
    60% compared to what ? Compared to original price at release ? And who cares about that price ? No one.
    Current price for example on newegg is $314.00. Yes, it's still "29% price cut", but $314.00->$225.00 looks less cool than $595.00-$225.00, right ?
  5. Hypernova
    2,034
    Jan 16, 2007
    You need to look at them on even ground ie launch price. Plus this means after going through the same degree of price cuts within the same amount of time the new drives will be very close to parity with raptors.
  6. faugusztin
    faugusztin 2[H]4U
    2,620
    Mar 9, 2008
    But their competition is not their launch price, no one cares about launch price from a year ago. Their competition is the current price of their own X25-M, the current price of Samsung and Indilinx drives...
  7. mjz_5
    mjz_5 2[H]4U
    3,589
    May 24, 2001
    good point :p
  8. flyz
    flyz Limp Gawd
    195
    Dec 13, 2002
    What about Gen1 X25-M? (Not that I have one :(). It would be a huge kick in the balls if Intel didn't have a firmware update for the early adopters.
  9. veritas7
    veritas7 Gawd
    737
    Nov 7, 2007
    Remember, press releases is for everyone, not just us tech junkies. Regular consumers read this to be assured that their current hardware will be supported in the future.
    Just ask any normal consumer about the Vista launch and it's early driver/compatibility support.
    Most likely the firmware will be the same across the models. In the new (speed improved) models probably we'll see at the end of the year, will start having different firmware.
  10. Megalomaniac
    Megalomaniac 2[H]4U
    2,196
    Jul 27, 2004
  11. Rebel44
    Rebel44 2[H]4U
    2,298
    Nov 7, 2006
  12. faugusztin
    faugusztin 2[H]4U
    2,620
    Mar 9, 2008
    Rebel44, if they do this stunt, then they can bet i won't buy any Intel SSDs anytime soon.
  13. DarkStryke
    DarkStryke [H]ard|Gawd
    1,408
    Sep 19, 2001
    It's very bad to do yep, but first adopters in anything tend to be the expensive guinea pigs for the rest of us.
  14. Megalomaniac
    Megalomaniac 2[H]4U
    2,196
    Jul 27, 2004
    Why are you surprised by that?
    Intel has gone though more chipset (CPU sockets) than almost anyone. With an intel motherboard you have a very limited upgrade path. With AMD you usually can upgrade to two, three of even more chips that use the same socket (not always, Slot A was a huge failure, but often enough)
    But who am i kidding, im running an intel chip now, and its fast. that why people will keep on buying them.
  15. The Hunter
    The Hunter Limp Gawd
    414
    May 29, 2002
    It does suck that they haven't said they'll do it, but it's worth keeping in mind that they haven't said they won't do it, they just haven't said they will. Given (admittedly limited) past history with their SSDs, I would expect they'll put something out for the G1s too, they probably just wanted to keep this announcement focused on the G2s. That's how marketing types work after all.
    Generally a good announcement, maybe not everything everyone wanted, but it's a strong step forward - cheaper prices for the same (maybe marginally improved) product is a good thing, and there are indications that the prices may drop even more before the end of the year, depending on what the competition does. I think it's a strong sign that the SSD market is maturing when we have fewer gigantic leaps forward, and rather strong but evolutionary steps.
  16. the_frick
    the_frick n00b
    5
    Mar 18, 2009
    Intel is definitely going to piss off more than a few enthusiasts who bought Gen1 X-25M drives if they don't push out TRIM-capable firmware... especially if there are no "technical limitations" preventing such an update (as Anand mentioned).
  17. nitrobass24
    nitrobass24 [H]ard|DCer of the Month - December 2009
    10,488
    Apr 7, 2006
  18. faugusztin
    faugusztin 2[H]4U
    2,620
    Mar 9, 2008
    The press release doesn't talk about limiting TRIM to 34nm :
    Let's hope they don't do this stunt, or they can say goodbye to many of their early adopters.
  19. Galvin
    Galvin 2[H]4U
    2,669
    Jan 22, 2002
    If the old and new drives use different controllers. Does that mean they'll have to make two seperate firmware updates for the G1 and G2 drives?
  20. nitrobass24
    10,488
    Apr 7, 2006
    Yes they would have to make serparate firmware updates....that doesnt mean they will though :(
  21. veritas7
    veritas7 Gawd
    737
    Nov 7, 2007
    Like I said, people should not be freaking out.
    Price drops. WHY? 34nm process. WHY? No other changes, just the fab process is now cheaper.
    If it was going to be the same price as Gen 1, then they would have new controllers.
    This is simply slightly better performance upgrade and capacity increase due to the fab process.
    Until someone opens up the new SSDs, I'm willing to bet that pcb/chip wise they're about the same (gen 1 and gen 2).
  22. GotNoRice
    GotNoRice [H]ardForum Junkie
    9,089
    Jul 11, 2001
    I hope these get to Newegg soon. Some of these places like ZipZoomFly make me wonder if they ever actually had any in-stock at all or just tossed the out-of-stock page up anyway in order to direct more traffic to their site. :rolleyes:
  23. serbiaNem
    serbiaNem 2[H]4U
    2,155
    Mar 6, 2005
    The new pcb is now manufactured without Halogen to make environmentally friendly companies feel better. They probably had to change it around to adjust for the decreased latencies and sizes also. I don't know why they have to wait for Win 7 to release trim support on the new drives, but at least it's coming. The Anand article clearly states that the older generation drives will not be getting it.
  24. veritas7
    veritas7 Gawd
    737
    Nov 7, 2007
    Until I see specifically from Intel that they are not going to ever release firmware for the first gen, I will not believe review sites, unless it is [H]ARD!
  25. Brahmzy
    Brahmzy [H]ardness Supreme
    4,959
    Sep 9, 2004
    Well, everyone wanting cheaper first-gen X-25M's will get 'em. I forsee a mass selling spree on eBay and other places...
    Yikes.
  26. GotNoRice
    9,089
    Jul 11, 2001
    But that's not really how most companies work. They wouldn't come out and say "this old product isn't going to receive any more updates". Instead, they will simply talk about the positive aspects of their new products and omit any mention of the older versions. They have no reason to voluntarily give themselves negative press.
  27. Peteman100
    1,466
    Oct 7, 2007
    Is no one else disappointed by the lack of ONFI 2.1 flash?
  28. Impulse
    Impulse [H]ardForum Junkie
    10,243
    Apr 5, 2001
    I'm definitely in for one of the new 80GB X25's whether it's at close to $200 or $250... I was ready to swallow the $300+ price tag of the older model by October anyway (to go along w/the Win7 install), so this price drop is very welcome. I've still got time to see what the competition does though... And they better do something or they're screwed for the time being.
  29. extide
    extide 2[H]4U
    3,265
    Dec 19, 2008
    I think you are failing to remember that s775 has been around since at least s939 and maybe even since s754. Yes, the same socket has been used from a DDR1 Prescott all the way to a DDR3 Core 2 Quad...
  30. mjz_5
    mjz_5 2[H]4U
    3,589
    May 24, 2001
    although its the same socket, using a newer 775 CPU in an older motherbaord will not work
  31. Cov
    Cov Gawd
    918
    Dec 3, 2007
    My first SSD is gonna be an 80GB Postville ... YAY !!
    [​IMG]
    ... or should I go for 160GB ?
  32. DarkStryke
    1,408
    Sep 19, 2001
    I wouldn't jump initially, as OCZ and the rest are going to have to adjust prices big time, which in turn will keep lowering the average price for everything. I think many people come October are going to be dropping the coin on these drives, since a fresh OS install (Win7) will be happening anyway, no better time to do it.
    This is the best SSD news this year so far for a consumer, even if you don't care about ever owning an intel SSD.
  33. Nenu
    Nenu [H]ardened
    18,465
    Apr 28, 2007
    I dearly want a fast SSD but none of the offerings for sale are ready for the mainstream imo.
    Even with the latest, customers are still guinea pigs for beta products.
    When they ship with TRIM support, improved write granularity (capable of smaller writes) and cost a lot less, I'll be happier.
  34. mutantmagnet
    mutantmagnet Limp Gawd
    267
    Mar 13, 2009
    They can't adjust their prices much. What Intel did to change the pricing dynamics is beyond the capabilities of these companies except for those with the infrastructure and human capitol like Samsung.
  35. Brahmzy
    4,959
    Sep 9, 2004
    Too bad man. I've been enjoying solid, blistering SSD speed for almost a year now. My SSD experiences have been nothing but awesome. Love it!!!
    Absolutely ready for mainstream and have been. Faster in every way than the fastest hard drive for consumer use...
    Posted via [H] Mobile Device
  36. Nenu
    Nenu [H]ardened
    18,465
    Apr 28, 2007
    Heh, I'm not an envious person but I do see the massive advantages, is why I want.
    I cant let myself pay that much though for such a small product (GBytes) that has non transparent technical issues and will be superseded in a few months.
    I anticipate updates and lower pricing to come thick and fast over the next year, its great there is decent competition.
    I can hang on :)
  37. Galvin
    Galvin 2[H]4U
    2,669
    Jan 22, 2002
    When are the new drives suppose to be available or was this a paper launch?
  38. nitrobass24
    10,488
    Apr 7, 2006
    Consumers are always guinea pigs for beta products now days.
    Gmail was in Beta for 5 years.
    IMO "Beta" is the new "RTM"
    Also the small random writes issues are long gone. It was not even an issue for all SSD's just an issue for certain SSD's that used a certain JMicron controller.
    People see these benchmarks for like the OCZ Solid/Apex series and see that it has 10MB/s random writes and freak out saying the world is gonna end.
    However if you ran those same test on a regular 7200rpm HDD you would likely see those numbers are less than 1MB/s
    Paper.
    I cant find any in stock.
    The problem is going to be with some retailers is making sure you get the new 34nm version, because the Product numbers are the same.
  39. - NintendoFan -
    - NintendoFan - [H]Lite
    87
    Jan 14, 2004
    Not entirely correct...
    http://anandtech.com/cpuchipsets/showdoc.aspx?i=3605
