vick1000
- Sep 15, 2007
I see that one can pre-partition and format a drive to prevent Win7 from creating the recovery partition. My question is if I use Shift+F10 to bring up the command prompt and use diskpart to partition and format the drive, will the partiton table still be aligned to the 4K allocation desireable for SSD performance?
Plus, it seems the 100MB partition somehow messes up any attempt to restore an image with the Win7 built in imaging tool.
Or do the SP1 discs not force the install of said partition anymore?
