Install Win7 without 100MB system reserved partition?
The error is between their eyes and the screen :p cmon guys give the OP a break, he only gave attitude when people bitched at him for wanting to mess with the partition. The topic at hand wasn't whether messing with the partition was a good idea or not...but people tried to turn it into an argument about that, which they shouldn't have done.
The system reserved partition has the Boot folder stored on it & after 7 came it out, it's standard for that partition to be 300MB when you use BitLocker. MS took a page from UNIX/Linux in regards to storing the boot info on another partition. If anything, I think it's a good way to go.
Ah ha. Now that explains something, very insightful post there. So that means when you update firmware on an SSD, or otherwise end up deleting that partition, the boot loader get's deleted, and an image made from the partition to be restored, had no boot loader, hence the unbootable image.
Sounds to me like the error is with MS, not including the partition with the loader as part of the image. As to why others are not encountering this, perhaps it was fixed on later copies of Win7, as the copy I was using is one of the early ones.
Just to be clear, I did try repairing with the Win7 DVD, and fixing the MBR, etc...all the usual to no avail. Of course it's a non issue now for me.
If you give the partition a drive letter, you can include it in the image. :)
