i7 930 overclocking thread
Thanks for the realtemp suggestion, I had missed that. It seems to be about the same as everett- I hit 90C max with 10 runs of linx testing at 185x21 @ ~1.200V reported, 1.235 set in bios. Doesn't that seem hotter that it should be, especially for the voltage that I'm running at?
I followed Cecil's guide, but then was scared off after i saw a core1 temperature reach 95C (1.35V, ~4.1ghz). I'm kind of confused on what I should run my Vqpi? Cecil says increase it to 1.3 - 1.35 or so, however post #2 says around 1.1V. My Vqpi is 1.24V currently.
I have turbo mode off, speedstep off, and HT off (should make it 10C cooler right?).
I used a thin coat of AS5 (small rice grain size, and spread with CC). Perhaps it is my wimpy push / pull fans that I have on the radiator? Also the ambient temperature here is around 30C.
That's unusually hot.. what cooler are you using? Id do a reseat then TRIPLE check all of the fans to make sure they are pointing the right direction and plugged in
From my limited experience, 0.02v to go from 3.8-4.0 and 0.04-0.06v to go from 4.0-4.2.
All of this greatly depends on the CPU you have. Out of the three CPUs I've had, going from 4.0-4.2 required the largest voltage boost.
From two i7 920s that I have experienced, it takes .9 to get from 3.8 to 4.0. Ive never tried 4.2 though.
User Name: MissJ84
CPU: i7 930
FPO/Batch #: 3004B176
Store: Microcenter Tustin, CA
Purchased In: August 2010
OC: 4032Mhz
Stability: Pass (20x Linx/Prime95 for 24 hours)
Temp (Idle / Load): 36c / 67c
Hyper Threading / Turbo Boost / Multiplier: No / No / 21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: Idle 1.188/Load 1.200 CPU-Z (1.18125 BIOS)
Cooling: Water
Cooler brand/model: Corsair H50 Push/Pull Exhaust Gelid FN-FW12BPL's
Motherboard: eVGA X58 3x SLI Classified (E760)
Bios Version: 74
Operating System: Win7 x64
RAM brand & type: G. Skill PI Black 3x2GB DDR3
RAM Part #: F3-12800CL8T-6GBPI-B
RAM rated speed: 1600 MHz
RAM actual speed: 1524 MHz
RAM Latency: 8-8-8-21 1T
RAM Voltage: 1.65V
I hit around 76c with HT on and have concluded the H50 just can't take advantage of the FT02's positive pressure like a high end air cooler would.
User Name: SlowReload
CPU: i7 930
FPO/Batch #: 3002B024
Store: Newegg, City of industry CA
Purchased In: June 2010
OC: 4.20ghz
Stability:12hour Everest system stability test
Temp (Idle / Load): 32 / 70
Hyper Threading / Turbo Boost / Multiplier: Yes / No / 21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.29vdroop off (bios)/ 1.28 (in os)
Cooling: Water
Cooler brand/model:Custom DD i7 multi core block/ EK full board water block/ 2x DD xtreme 2x120 rad
Motherboard: EVGA X58 Classified E760
Bios Version:74
Operating System: Win7 64
RAM brand & type: Patroit Sector 7 1600mhz
RAM Part #:
RAM actual speed: 1650
RAM Latency: 8-8-8-24-1t
RAM Voltage: 1.66
Hi, I just got a new I7 930 but I can't find this batch # 3014A791 on here ???
Mind posting how it clocked? I just got a 3013A572 and have been looking around for more recently packed batches (the third and fourth digits indicate packing week). The most recent ones I find consistently are weeks 1-3 of 2010 and I've found virtually none from this week 13-14 batch.
Don't have my board yet so I can't test it myself.
User Name: Enphenate
CPU: i7 930
FPO/Batch #: 3011B067 (pack date 7/01/10)
Store: Microcenter, Irvine, CA
OC: 3.8Ghz
Stability: Prime95 2 hour FTT test
Temp (Idle / Load): 38/57
Hyper Threading / Multiplier: Yes/21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.184v
Cooling: Water
Cooler brand/model: Corsair H70 water cooler
Motherboard: Asus P6X58D-E
Bios Version: 0303
Operating System: Windows 7 64-bit
RAM brand & type: Corsair XMS3
RAM Part #: TR3X6G1600C9 G
RAM rated speed: 1600mhz
RAM actual speed:
RAM Latency: 9-9-9-24 2t
RAM Voltage: 1.65
Just passed two hours of stability
Note temps are a lot higher than normal as i forgot to open my room door and windows and it was a miserably hot california day today so my room was pretty toasty.
I must have got a new batch I cant find anything on the web about it. Once I install it. I will see how it overclocks.
User Name: sderden
CPU: i7 930
FPO/Batch #: 3951B004
Store: Newegg
Purchased In: 8-13-2010
User Name: sderden
CPU: i7 930
Store: Newegg
Actually an old batch, it's just that most people don't post about this sort of thing. The 951 part of the batch number indicates that it was fabbed in 2009, week 51.
So do you know if thats a good batch? I have it overclocked to 3.2 right now just a easy overclock, havnt had time to stress it, but it seems to be running hotter than my old C0 920 did @ 3.6. I have the same watercooling as before..
Edit: as you said 2009, week 51 made in Costa Rica
User Name: hamfist
CPU: i7 930
FPO/Batch #: 3004B177 (pack date 6/02/10)
Store: Microcenter, Rockville, MD
OC: 4.268Ghz
Stability: LinX 4096MiB 100x runs passed
Temp (Idle / Load): 31/68
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.284v
Cooling: Water
Cooler brand/model: EK Supreme HF Nickel, Swiftech MCR320, 3xYate Loon D12SM-12, MCP355, XSPC Dual Bay
Motherboard: Asus Rampage III Extreme
Bios Version: 0901
RAM brand & type: G.Skill Ripjaws
RAM Part #: F3-16000CL9-2GBRH
RAM rated speed: 2000 MHz
RAM actual speed: 1620 MHz
RAM Latency: 9-9-9-27 1T
RAM Voltage: 1.60
I can get the RAM stable at 2000 MHz, but I have to run the QPI at 1.55V, which I think is unreasonable for everyday use. So I set my limit at the Intel specified max of 1.35V for QPI. Even though the 930 has more headroom, the memory wont go past 1600 MHz without more voltage on the QPI.
User Name: gpitpitan
CPU: i7 930
FPO/Batch #: 3004B521
Store: Newegg
OC: 4015.8mhz
Stability: 24hrs prime stable
Temp (Idle / Load): 50c/73c
Hyper Threading / Turbo Boost / Multiplier: No / No / 19x)
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.243v
Cooling: Liquid
Bios Version: 9102
RAM brand & type: Corsair Dominator GT
RAM Part #: CMT6GX3M3A1600C7
RAM actual speed: 1690 MHz
RAM Latency: 7-7-7-20 1T
RAM Voltage: 1.76v
Hi, Sorry I don't have this cpu on the Mobo yet. I was just checking to see if anyone has this chip overclocked ..... :confused:
User Name: 2OFTS
CPU: i7 930
FPO/Batch #: 3951A694
Store: Newegg
Purchased In: March 2010
OC: 4.042 GHz
Stability:20 runs LinX
Temp Idle/Load 36c / 81c
Hyper Threading / Turbo Boost / Multiplier: Yes / Yes / 21x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.31250V
Cooling: Air
Cooler brand/model: Noctua NH D-14 (Both Fans)
Motherboard: ASUS Rampage II Gene
Bios Version: 1104
Operating System: Win 7 Pro 64-bit
RAM brand & type:Kingston 3x2GB DDR3
RAM Part #: KVR1333D3N9K3
RAM rated speed: 1333 MHz
RAM actual speed:
RAM Latency: 9-9-9-24 1T
RAM Voltage: 1.67V
Upgraded to the cooler 2 weeks ago and was able to test higher OCs for the first time.
No over clocking at all with stock heat sink on i7 930 and after a few moments of running Wprime this CPU quickly gets hot enough for me to cancel the benchmark.
I'm going to be working on the bios settings and adding a Corsair H50 for improvements.
It looks like something is very wrong with your system :) Check that the heatsink is seated properly and check the voltage settings in the bios. I'd download cpu-z and run that while testing out your system. It gives some useful info.
User Name: Zoson
CPU: i7 930
FPO/Batch #: 3001B461 (pack date 6/09/10)
Store: Microcenter, Westbury, NY
OC: 4.269Ghz
Stability: LinX 8192MiB 200x runs passed
Temp (Idle / Load): 53C/96C
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.363v
Cooling: Water
Cooler brand/model: EK Supreme HF Gold, 2x GTX-120 + GT Stealth 120, 3x Enermax Magma @ ~1000RPM, MCP655-b - see sig for rest of parts in loop.
Bios Version: 1005
RAM brand & type: Mushkin Ridgeback 12GB (3x4GB), 2000MHz 10-10-10-27
RAM Part #: 998953
RAM actual speed: 2035 MHz
RAM Latency: 9-9-9-25 1T
RAM Voltage: 1.65
http://valid.canardpc.com/show_oc.php?id=1389427
Code:
Target CPU Frequency                  4268MHz
Target DRAM Frequency                 2035MHz
LN2 Mode                              [Disabled]***
QPI Loadline Calibration              [Enabled]***
Sync Mode                             [Enabled]
AI Overclock Tuner                    [Manual]
OC From CPU level Up                  [Auto]
CPU Ratio Setting                     [Auto]
CPU Turbo Power Limit                 [Disabled]
>CPU Configuration----------------------------
C1E Support                           [Disabled]
Hardware Prefetcher                   [Enabled]
Adjacent Cache Line Prefetcher        [Enabled]
MPS and ACPI MADT ordering            [Modern ordering]
Intel(R) Virtualiyation Tech          [Enabled]
CPU TM Function                       [Disabled]
Execute Disable Bit                   [Enabled]
Intel(R) HT Technology                [Enabled]
Active Processor Cores                [All]
A20M                                  [Disabled]
Intel(R) SpeedStep(TM) Tech           [Disabled]
Intel(R) Turbo Mode Tech              [Disabled]
Intel(R) C-STATE Tech                 [Disabled]
C State package limit setting         [Disabled]
BCLK Frequency                        [203]
PCIE Frequency                        [100]
DRAM Frequency                        [DDR3-2035MHz]
UCLK Frequency                        [4069MHz]
QPI Link Data Rate                    [7308MT/s]
Memory Configuration Protect          [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency                          [9]
RAS# to CAS# Delay                    [9]
RAS# PRE Time                         [9]
RAS# ACT Time                         [25]
RAS# to RAS# Delay                    [Auto]
REF Cycle Time                        [132]
WRITE Recovery Time                   [Auto]
READ to PRE Time                      [Auto]
FOUR ACT WIN Time                     [Auto]
Back-To-BackCAS# Delay                [Auto]
Timing Mode                           [1N]
Round Trip Latency on CHA             [Auto]
Round Trip Latency on CHB             [Auto]
Round Trip Latency on CHC             [Auto]
WRITE To READ Delay(DD)               [Auto]
WRITE To READ Delay(DR)               [Auto]
WRITE To READ Delay(SR)               [Auto]
READ To WRITE Delay(DD)               [Auto]
READ To WRITE Delay(DR)               [Auto]
READ To WRITE Delay(SR)               [Auto]
READ To READ Delay(DD)                [Auto]
READ To READ Delay(DR)                [Auto]
READ To READ Delay(SR)                [Auto]
WRITE To WRITE Delay(DD)              [Auto]
WRITE To WRITE Delay(DR)              [Auto]
WRITE To WRITE Delay(SR)              [Auto]
CPU Differential Amplitude            [Auto]
CPU Clock Skew                        [Auto]
IOH Clock Skew                        [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode                        [T-Balanced]
PWR Volt. Control                     [Auto]
Load-Line Calibration                 [Full Calibration]
CPU Voltege OCP                       [Enabled]
CPU PWM Frequency                     [1000KHz]
Extreme OV                            [Disabled]
Extreme OC                            [Auto]
CPU Voltage                           [1.36875]
CPU PLL Voltage                       [Auto]
QPI/DRAM Core Voltage                 [1.49350]
DRAM Bus Voltage                      [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA          [Auto]
DRAM CTRL REF Voltage on CHA          [Auto]
DRAM DATA REF Voltage on CHB          [Auto]
DRAM CTRL REF Voltage on CHB          [Auto]
DRAM DATA REF Voltage on CHC          [Auto]
DRAM CTRL REF Voltage on CHC          [Auto]
IOH Voltage                           [1.17925]
IOH PCIE Voltage                      [Auto]
ICH Voltage                           [Auto]
ICH PCIE Voltage                      [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum                   [Disabled]
DRAM Spread Spectrum                  [Disabled]
***on-board jumper dependant
User Name: GTOViper
CPU: i7 930
FPO/Batch #: 3951A687
Store: Microcenter, Santa Clara, CA
Purchased In: April 2010
OC: 4.209Ghz
Stability: LinX All-100x runs passed
Temp (Idle / Load): 43C/78C Ambient ~30C
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.35000v
Cooling: Water
Cooler brand/model: EK Supreme HF All Copper Nickel Plated, HwLabs SR-1 280 w/ NB-PK2 x2 Pull, ThermoChill PA120.3 w/ Scythe GT-AP14 1450RPM x6 Push/Pull.
Bios Version: 1005
Operating System: Windows 7 64-bit Ultimate
RAM brand & type: Corsair Dominator GT PC-16000, 6GB (3x2GB), 2000MHz
RAM Part # CMG6GX3M3A2000C7
RAM actual speed: 2000 MHz
RAM Latency: 7-8-7-20 1T
RAM Voltage: 1.65
After a couple days of tweaking around and stability testing, I finally got it stable at 4.2GHz with 100 passes of LinX 0.6.4 with the latest Intel Linpack Binary at full memory load.
Within a very short time of testing, the ambient temp went from 27C to 31C and as high as 33C in my computer room... The Forge dissipates an enormous amounts of heat very quickly...
fc5f97b8ca8147bc8566c0efd02343ff
Here is the stable BIOS 1005 setting for the Rampage III Extreme:
Code:
Target CPU Frequency		4209MHz
Target DRAM Frequency		2002MHz
LN2 Mode:            		Disabled***
QPI Loadline Calibration:    	Disabled***
Sync Mode            		[Enabled]
CPU Ratio Setting        	[21.0]
Intel(R) Virtualization Tech    [Enabled]
A20M                		[Disabled]
BCLK Frequency            	[200]
DRAM Frequency            	[DDR3-2002]
UCLK Frequency            	[4004]
QPI Link Data Rate        	[AUTO]
CAS# Latency              7	[7]
RAS# to CAS# Delay        8	[8]
RAS# PRE Time             7     [7]
RAS# ACT Time             20    [20]
RAS# to RAS# Delay         	[AUTO]
REF Cycle Time            98 	[AUTO]
Timing Mode               1N    [1N]
Round Trip Latency on CHA       [AUTO]
Round Trip Latency on CHB       [AUTO]
Round Trip Latency on CHC       [AUTO]
CPU Differential Amplitude    	[900mV]
Load-Line Calibration      	[Auto]
CPU PWM Frequency        	[Auto]
Extreme OC            		[Auto]
CPU Voltage        	  1.349 [1.35000]
CPU PLL Voltage           1.828 [1.8285]
QPI/DRAM Core Voltage     1.556 [1.60000]
DRAM Bus Voltage    	  1.654	[1.65625]
IOH Voltage        	  1.244 [Auto]
IOH PCIE Voltage    	  1.508 [Auto]
ICH Voltage        	  1.111 [Auto]
Here is my OC log for anyone that could use this information to help their own overclock with an i7 Proc. Happy Overclocking guys!
Orange value indicates what had changed from the previous OC attempt.
[Google Doc] The Forge i7-930 Overclocking Log to 4.2GHz
Here are the parts:
[Asus Rampage III Extreme X58 LGA1366]
[Intel Core i7 930 LGA1366 Batch# 3951A687]
[Corsair Dominator GT PC-16000, 6GB (3x2GB), 2000MHz, 7-8-7-20 CMG6GX3M3A2000C7]
The Rig:
Check out more pictures at the Case Mod Gallery thread if anyone is interested.
omg who knew there was a thread - running my i7 930 at 4.2 on gigabyte x58-ud3r 2.0 - using eco coolit it cooler..it screeeeam. :) and i lovesit.
I'm thinking about getting an i7 930 and would like to OC it to 4Ghz on air, but I'm on a budget. What's the cheapest motherboard and RAM that I can get? Thank you.
MSI x58 pro-e or Asus p6t are probably the best x58 mobos under $200. Gskill for cheap RAM but I saw ocz and kingston DDR3 going for really cheap last week. Id take Gskill over ocz or kingston any day though.
gigabyte X58A-UD3R is a super solid OCing board.it has taken all my cpu.s beyond 4.5GHz with ease.
nice to see the potential of this beast and how high you can take it before needing additional cooling
User Name: Zoson
CPU: i7 930
FPO/Batch #: 3012A752 (pack date 7/07/10)
Store: Newegg
Purchased In: September 2010
OC: 3.820GHz
Temp (Idle / Load): 44C/82C
Hyper Threading / Multiplier: Yes/20x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.275v
Cooling: Water
Motherboard: Gigabyte X58A-UD3R
Bios Version: FA
RAM brand & type: G.Skill PI Black 6GB (3x2GB), 1600MHz 6-8-6-20
RAM Part #: F3-12800CL6T-6GBPI
RAM actual speed: 1528 MHz
RAM Latency: 6-8-6-20 1T
RAM Voltage: 1.60
Built this for a friend... Someone was asking about this batch earlier... IT SUCKS. Default ViD is 1.275v. Tj max is 97C, not 100C! Does 3.8GHz on default voltage, but won't even do 4.0GHz with 1.4vCore. I even tried this one on my R3E that does 4.2 with my other chip.
Moral of the story: STAY AWAY FROM THE CURRENT BATCH AT NEWEGG!
I run CPU-Z. Doesn't help cool my cpu though. Stock heat sink isn't working well for me. I'm going to try some diamond thermal paste on the stock heat sink to see
if it helps.
Intel actually uses more power than AMD
And they're faster too. The more important question is how much specific power consumption. For example, how many kW-hrs (or Joules) to encode a 30 mins movie. If company X takes 1 hour to do it and consumes 100Watts while encoding, and company Y takes 2 hours to do it and consumes only 75Watts, company X is consuming less energy than company Y's chip to do the same task. It's something that's often over looked by reviewers.
Now don't get me wrong, power is important too as you must design your heatsinks to deal with TDP.
if it helps.
But CPU-Z will give you voltage info which could be part of the problem. It's just a guess, you haven't given us much info to go on.
This is still a work in progress:
User Name: [H]ocusPocus
CPU: i7 930
FPO/Batch #: 3003B140
Store: Intel Online Store
OC: 4009.1 MHz
Stability: 100 runs LinX (all mem) and 20+ hrs Prime95 (blend)
Temp (Idle / Load): 33c / 71c
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.3V set in bios, 1.288V reported by cpuz
Cooling: Air
Cooler brand/model: Zalman CNPS10X Performa
Motherboard: ASUS P6X58D-E
Bios Version: 0303
RAM brand & type: OCZ 3x2GB DDR3
RAM Part #: OCZ3G1600LV6GK
RAM actual speed: 1527 MHz
RAM Latency: 8-8-8-24 1T
RAM Voltage: 1.64V
Ok got a Corsair H50 on it last night and began to get into the BIOS to learn how to OC it.
Without much effort I was able to get 4.2 GHZ wtih some voltage bumps.
Here is my CPU-Z for 4.2GHz.
http://valid.canardpc.com/show_oc.php?id=1403462
With the H50 temps are much cooler than before.
CPU: i7 930
OC: 4009.1 MHz
Stepping: 5
Revision: D0
Cooling: Air
Bios Version: 0303
RAM Voltage: 1.64V
That is a sweet stable OC.
I'm still learning my i7-930 and MB BIOS. I'd like to tune mine with 1.3v or less for stable 4GHZ. Very nice.
Thanks. I'm working on trying to stabilize 4.2 Ghz now, but not there yet. I may also go back to 4.0 Ghz and play around with a few more settings to see if I can tighten things up just a bit more and maybe bump the memory speed up a notch.
Update to show improvements of Corsair H50 on same system. Huge improvement with H50 from stock heat sink.
User Name: NewbieD
CPU: i7 930
FPO/Batch #: 3945B474
Store: Amazon
Purchased In: Sept 2010
OC: 3800 MHz
Stability: 15 IntelBurn/10hrsPrime95
Temp (Idle / Load): 38c / 67c (RealTemp)
Hyper Threading / Turbo Boost / Multiplier: Yes / No / 19x
Stepping: 5
Revision: D0
Vcore/Core Voltage: 1.14375V(bios)
Cooling: Water
Cooler brand/model: Corsair H50 P/P (GT AP-15)
Motherboard: P6X58D-E
Bios Version: 0303
RAM brand & type: Corsair Dominator 3x2GB DDR3
RAM actual speed: 1603 MHz
RAM Voltage: 1.64V
NewbieD very nice voltage on your overclock. Must run very cool and could possibly be over clocked much faster. Looks golden. :cool:
